Rear Spar Troubles
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Piper-List
lowell23@msn.com
PostPosted: Tue Jul 19, 2011 9:44 am    Post subject: Rear Spar Troubles Reply with quote
During this years annual it was found that at some point someone had put a lucite 'inspection panel' on the inside right wing - just ahead of the flap. When they had done that, they ran five screws into the rear spar cap, and possibly into the spar itself. Does anyone know of an approved spar repair?
Thank you,
Lowell Johnson
- The Matronics Piper-List Email Forum -
http://www.matronics.com/Navigator?Piper-List
 Filesize:  100.05 KB
 Viewed:  6455 Time(s)
grosseair(at)comcast.net
PostPosted: Tue Jul 19, 2011 10:33 am    Post subject: Rear Spar Troubles Reply with quote
What kind of aircraft are you talking about?
lowell23(at)msn.com <mailto:lowell23(at)msn.com>
July 19, 2011 12:44 PM
Thank you,
Lowell Johnson
http://forums.matronics.com/viewtopic.php?p=347061#347061
http://forums.matronics.com//files/rear_spar_200.bmp
lowell23@msn.com
PostPosted: Tue Jul 19, 2011 10:50 am    Post subject: Re: Rear Spar Troubles Reply with quote
I should have mentioned it is a 1952 PA-22.
Lowell
Kellym
PostPosted: Tue Jul 19, 2011 12:51 pm    Post subject: Rear Spar Troubles Reply with quote
One approved method is to replace the wing with a serviceable used
one.....minor repair, log book entry only.
Otherwise you are probably looking at getting Piper or DER to engineer
an approved repair to present to FSDO for field approval as a major repair.
Kelly
A&P/IA
Thank you,
Lowell Johnson
Kelly McMullen
KCHD
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Piper-List All times are GMT - 8 Hours
