Posted: Sun Jul 17, 2011 6:02 pm Post subject: Over Voltage Protection for Internal Regulated Alternators |
At 03:17 PM 7/17/2011, you wrote:
If my IR alternator ever goes belly up I'll move to an externally
regulated one, but for now it is what it is.
I have a 40A internally regulated alternator. I am rewiring my RV-8
to Z-11 standard and want to include OV protection. I have read up
on the forums and on AeroElectric Connection. I just want to
confirm the latest thinking on OV protection.
1) use a Cb-OV-14 crowbar protection circuit on the Master switch
and
2) a S701-1 B-lead contactor
That works.
Alternatively, you can go inside the alternator
and modify it in the same manner that Plane-Power
does so that you have EXTERNAL control of the
field supply conductor while retaining use of
the internal regulator.
| Quote: | I am also installing a 60 amp ANL in the B-lead between the
alternator and the starter solenoid.
This device has nothing to do with ov protection . . .
only protection of the b-lead wire in case of shorts
in the diode array . . . a very rare event.
Bubblehead
Joined: 26 Oct 2007 Posts: 48 Location: N. Richland Hills, TX
Posted: Mon Jul 18, 2011 4:23 am Post subject: Re: Over Voltage Protection for Internal Regulated Alterna |
I agree and understand the ANL has nothing to do with OV protection.
Where would I find information on going "inside the alternator and modify it in the same manner that Plane-Power does so that you have EXTERNAL control of the field supply conductor while retaining use of the internal regulator. "
_________________ John
Keller, TX
RV-8 N247TD |
