sbuc(at)hiwaay.net Guest
Posted: Sat Jan 14, 2006 8:45 am Post subject: EZ Pilot Autopilot |
Charlie Kuss wrote:
Quote: |
Sam,
You you explain to me what a "stepper" motor is and how it differs?
Charlie, you are asking the wrong person for insight on the design of
stepping motors! This is beyond my scope of expertise.
Here is a link that might help:
http://www.cs.uiowa.edu/~jones/step
As I understand it, the stepping motor can be controlled via digital
signals in order to command very precise and repeatable rotation and
parking positions of the motor shaft. The analog motor that most of us
are familiar with doesn't have discrete "stops" in its rotation and
needs some sort of feedback sensor in order for the control head to
determine the position of the motor shaft.
There, I have made an idiot of myself by diving into an area in which I
have no real knowledge. But hopefully some of the actual motor experts
on the list will jump in and straighten out my mess.
In the real world, I can't tell any difference in the performance of the
analog system in the Navaid servo and the digital stepper in the AlTrak
servo. Both servos work extremely well at driving the control surfaces
in very small, precise increments.
The first time you move the stick on the ground in a plane with the
DigiTrak servo you will notice the servo motor dragging through the
steps since it doesn't have a clutch that disconnects the servo drive
when it isn't engaged. But the drag isn't noticeable in flight. The
Navaid servo has a solenoid that disengages the gear train when power is
not supplied to the servo.
Hope I haven't muddied the water too much.
Sam Buchanan
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
SSampson.SLN21(at)london. Guest
Posted: Sat Jan 14, 2006 10:15 am Post subject: EZ Pilot Autopilot |
Sam - thanks for the input. Any idea when Tru track bring out their new
servo. I havnt bought them yet and hate to buy just before things become the
'old' model. Thanks, Steve.
shempdowling2(at)earthlin Guest
Posted: Sat Jan 14, 2006 11:12 am Post subject: EZ Pilot Autopilot |
You could purchase the tru track alt hold regardless of your a/p setup. I
have the Navaid and tru traks alt hold and love it. I would put the alt
hold in before the wing leveler. Its really nice when you're by yourself.
GO BEARS
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
sportav8r(at)aol.com Guest
Posted: Sat Jan 14, 2006 11:21 am Post subject: EZ Pilot Autopilot |
Both functions are VERY nice to have (I can say that from experience, now that I have both). For x/c, the alt hold is the most desirable of the two, but for an inadvertent IMC encounter (not that I've ever had one , the wing-leveler is more helpful, IMO.
-Stormy
GO, TRIO
lwalters2(at)cfl.rr.com Guest
Posted: Sat Jan 14, 2006 11:32 am Post subject: EZ Pilot Autopilot |
Charlie, a stepper motor doesn't 'run' like a linear motor. Apply power
to a linear motor and it runs, and after power removal the motor will
coast to a stop .... depending on the load, of course. A stepper motor
is 'pulsed' (best way I can describe it) and moves a few degrees, or
portions of a degree, depending on it's design, for each pulse. If you
have one of each (stepper and linear) you can tell the difference by
twisting the rotor. A stepper will have a definite 'hump' and stop at
the 'step'. Kinda like pulling a prop over compression. The linear
will just rotate freely. A DC linear motor will have two wires, and the
stepper will have 4 or more depending on how many field coils it has.
Steppers need a 'controller' that generates the pulses in the proper
phase for rotation and direction. The linear motor only needs a switch.
The advantage of the stepper is the ability to move in fine, incremental
steps while the linear motor just comes close to a position.
Hope this helps.
Linn
Charlie Kuss wrote:
Quote: |
Sam,
Charlie Kuss
snipped
>The TruTrak servo is indeed a nice looking and hefty unit. It uses a
>stepping motor instead of a linear motor and clutch. However, I have
>heard that a new version of this servo is in the works that has a clutch.
>The Navaid servo is much lighter than the TruTrak and based on analog
>technology that has been around for many years. In spite of its dated
>appearance and light weight, the servo has an excellent field history in
>service with both Navaid control heads and more recently with the
>EZ-Pilot heads. This servo incorporates a clutch that releases the gear
>train when power is removed from the servo.
snipped
Posted: Sat Jan 14, 2006 12:03 pm Post subject: EZ Pilot Autopilot |
Steve, sorry I don't know, but I bet a call to TruTrak would provide you
with that and any other info you need.
Sam Buchanan
Posted: Sat Jan 14, 2006 12:32 pm Post subject: EZ Pilot Autopilot |
Thanks!! Steve.
ptrotter
Joined: 10 Jan 2006 Posts: 28 Location: Westchester County, NY
Posted: Sat Jan 14, 2006 12:37 pm Post subject: EZ Pilot Autopilot |
Both stepper motors and servo motors have their own advantages and
disadvantages. As Lynn stated, steppers have a definitive, known, rotation
per pulse. This makes them easier and cheaper to control, but has the
disadvantage of jerky motion (probably not an issue for an A/P) and the
fineness of control is limited by the number of steps per revolution (again
probably not an issue for an A/P). Servos have continuous motion and need a
feedback circuit to determine their location. This is more expensive but
give much smoother control and can be positioned in virtually unlimited
fineness as opposed to steps. In the case of an A/P, I think either will
work just fine and the differentiating factor between A/Ps being the
features of the electronics rather than the motor type. Steppers and servos
are use extensively in the CNC industry, with lower end equipment using
steppers and higher end equipment using servos. My little CNC mill has
stepper motors and you can really see the limitations due to the steps. Of
course we are talking thousands of an inch here, which is just not necessary
for an A/P.
I think both Tru-Trak and Trio are great products. Right now I'm planning
on using Trio in my 8, but I could very well change my mind by the time I
get to that point. I like the clutch idea on the Trio servo, but it doesn't
take much effort to override the Tru-Trak stepper. I believe Trio is now
shipping the same servo for both the EZ-Pilot and the EZ-1 altitude hold
units.
Paul Trotter
RV-8 82080 Fuselage Kit
_________________ Paul Trotter
N801PT (reserved) |
Dan.Beadle(at)hq.InclineS Guest
Posted: Sat Jan 14, 2006 12:41 pm Post subject: EZ Pilot Autopilot |
A stepper motor is computer controlled. They basically have windings
that are offset. When you energize one set, the motor moves a fraction
of a turn in one direction. If you then engage the other set, it
continues to move the same direction for another step. Alternate them,
and the motor turns round and round. If you change the order - the
phase - of powering up the windings, it moves the other direction.
Step motors are the basis for a lot of CNC machines. By counting steps,
you know where the head is. And steps can be very small.
On nice thing about most stepper motors is that if you don't engage
either set of windings, the motor will free wheel. (It takes energy to
hold it on the current step - no energy = free wheel). This is a nice
feature that
eliminates the need for a separate clutch. If
the autopilot is not engaged, just let the motor freewheel.
Posted: Sat Jan 14, 2006 12:47 pm Post subject: EZ Pilot Autopilot |
In my response to Charlie, I pointed out a benefit of steppers. The
linear motors also have a benefit, especially in an autopilot. The
stepper has inherent drag, because of the stepping nature of the beast
where the linear motor doesn't. Given the same gearing, the stepper
will have more drag than the linear motor. However, both systems will
have drag due to gearing, and the addition of a clutch in the system
will remove the drag from both.
Sorry if I've confused anyone!!!
Linn
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sat Jan 14, 2006 1:14 pm Post subject: EZ Pilot Autopilot |
Quote: | I looked inside one of these servos at OSH and the engineering and
materials look first class; should be a worthy component for their
excellent autopilots.
Sam Buchanan
It the new 'Servo' for EZ-Pilot a stepper or a true (analogue) servo?
I had discounted the EZ-Pilot previously because it had a stepper. I could not get my mind around
how they delt with overtorquing the stepper, I suspect they have needed to resort to another
micro-controller within their new 'servo' to keep track of the actual position.
Doug Gray
Posted: Sat Jan 14, 2006 2:43 pm Post subject: EZ Pilot Autopilot |
> Sam Buchanan
Quote: | Is the new 'Servo' for EZ-Pilot a stepper or a true (analogue) servo?
I don't know, Doug.
Quote: | I had discounted the EZ-Pilot previously because it had a stepper.
Nope, Trio's EZ-Pilot has been using the Navaid servo which is *not* a
stepper setup. TruTrak uses a stepper design with their systems.
Quote: | I could not get my mind around how they delt with overtorquing the
position.
There is *no* way I am going to speculate on the specifics of Trio's new
servo design!
Here is what Trio has on their web site about the new servo:
http://www.trioavionics.com/servo.htm
It appears to be a well thought-out design which is what I have come to
expect from the Trio guys.
Sam Buchanan
mannanj(at)alltel.net Guest
Posted: Sat Jan 14, 2006 4:16 pm Post subject: EZ Pilot Autopilot |
Steve:
Check with Tru Track to be certain, but I think I remember that they will
let you upgrade to a newer or better version for just the difference in
price between the two.
Mannan Thomason
RV-8 Tru Track installed, hoping to fly this spring.
