		psm(at)att.net Guest
				 Posted: Sat Jul 09, 2011 2:06 pm    Post subject: First Flight. |
				I completed the first flight of my XL today.  It went just fine, but
 there were a number of small squawks to fix.
 I wound up flying in the middle of the day and the sky was clear but the
 air was unstable.  I was not able to hold an attitude to do precise
 measurements of airspeed or other parameters.  Takeoff and landing went
 just fine.  I used 1/2 flaps for takeoff and full flaps for landing.
 The nose was a little sticky on takeoff, so next time I think I will try
 doing it with full flaps.
 I think I had the tachometer setting on the Dynon EMS wrong.  It
 indicated I was doing 3800 RPM in a low cruise which just doesn't make
 any sense.  I had it set for 4 counts per revolution (the suggested
 value in the Dynon book) and I think I will try 6 next time.  I
 controlled engine power by watching the cylinder head temperatures.
 That left me at perhaps 1/2 power max for most of the flight.
 I climbed to 5,000 feet and tried to do a couple of stalls - one with
 and one without flaps.  In both cases I was unable to get the nose to
 drop, but the plane mushed and lost altitude much in the style of a
 Piper.  Indicated airspeeds in the mush was something around expected
 values of 38 dirty and 45 clean.  Again I couldn't maintain any airspeed
 for long enough to be sure of the exact reading.
 I also learned I need to install a trim tab on the rudder.  I had to
 hold left rudder for most of the flight to keep the ball centered.  I
 also need to darken the skin/panel above the instrument panel to improve
 visibility when going toward the sun.  The reflections made it hard to
 see out front.
 All in all it was a fine first flight.  It will probably be a couple of
 days before I am ready to try it again.
 Paul
 Camas, WA
 XL in flight test - N773PM
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		merlin
  Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
				 Posted: Sat Jul 09, 2011 2:17 pm    Post subject: First Flight. |
				Don't use any flaps for takeoff. Full flaps will only make the nose heavier for takeoff.
 & congratulations on the 1st flight...hope you have many more.  I hope to be there in about 2 years.
 JW
 Sent: Sat, July 9, 2011 6:03:28 PM
 Subject: First Flight.
  --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net (psm(at)att.net)>
 I completed the first flight of my XL today.  It went just fine, but there were a number of small squawks to fix.
 I wound up flying in the middle of the day and the sky was clear but the air was unstable.  I was not able to hold an attitude to do precise measurements of airspeed or other parameters.  Takeoff and landing went just fine.  I used 1/2 flaps for takeoff and full flaps for landing.  The nose was a little sticky on takeoff, so next time I think I will try doing it with full flaps.
 I think I had the tachometer setting on the Dynon EMS wrong.  It indicated I was doing 3800 RPM in a low cruise which just doesn't make any sense.  I had it set for 4 counts per revolution (the suggested value in the Dynon book) and I think I will try 6 next time.  I  controlled engine power by watching the cylinder head temperatures.  That left me at perhaps 1/2 power max for most of the flight.
 I climbed to 5,000 feet and tried to do a couple of stalls - one with and one without flaps.  In both cases I was unable to get the nose to drop, but the plane mushed and lost altitude much in the style of a Piper.  Indicated airspeeds in the mush was something around expected values of 38 dirty and 45 clean.  Again I couldn't maintain any airspeed for long enough to be sure of the exact reading.
 I also learned I need to install a trim tab on the rudder.  I had to hold left rudder for most of the flight to keep the ball centered.  I also need to darken the skin/panel above the instrument panel to improve visibility when going toward the sun.  The reflections made it hard to see out front.
 All in all it was a fine first flight.  It will probably be a couple of days
		vk3eka(at)bigpond.net.au Guest
				 Posted: Sat Jul 09, 2011 2:46 pm    Post subject: First Flight. |
				Paul,
 I agree with Jeffery, I don't use flaps on take off. Full flaps on landing
 makes for a nice approach and landing.
 Well done on the first one.
 Cheers
 Peter
 Wonthaggi Australia
 http://zodiac.cpc-world.com
				 Posted: Sat Jul 09, 2011 2:59 pm    Post subject: First Flight. |
				Paul,
 Regarding the rudder, if you find that rudder is needed for most of the
 flight, you might find that the rudder cables need adjusting to keep the
 aircraft straight when the nose wheel steering rod attachments are in the
 vee of the nose gear bottom bearing.
 I have found that the rudder is not used much in general flight.
 Peter
 Wonthaggi Australia
		jlatimer1(at)cox.net Guest
				 Posted: Sat Jul 09, 2011 3:28 pm    Post subject: First Flight. |
				Paul
          Congratulations!!!!
          Jerry
          HDS 912 100 hrs
		bryanmmartin
				 Posted: Sat Jul 09, 2011 3:34 pm    Post subject: First Flight. |
				I usually take off with no flaps and just pull back on the stick at 60 MPH to rotate and it flies off fine.
 On Jul 9, 2011, at 6:03 PM, Paul Mulwitz wrote:
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus re-drive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
				 Posted: Sat Jul 09, 2011 3:57 pm    Post subject: First Flight. |
				Thanks to everyone for the nice comments.
 Peter, your comment about the rudder cables seems like it makes sense.
 I couldn't figure why a full flying rudder would need a trim tab.
 Perhaps I will try tweaking the cables first instead.
 I guess I need to try taking off with no flaps as well as full flaps.
 After all this is test flying.  The Jabiru is a large engine for this
 plane and makes it so overpowered I don't think it will have any problem
 climbing with full flaps.
 Paul
 On 7/9/2011 3:57 PM, Peter W Johnson wrote:
  Paul,
  Peter
  Wonthaggi Australia
		rsteele(at)rjsit.com Guest
				 Posted: Sat Jul 09, 2011 4:23 pm    Post subject: First Flight. |
				Paul, Congratulations!
 I hope it was worth all the difficulties.
 So how does it fly compared to the Echo?  Do you think the Echo
 prepared you for first flight?
 Ron
				 Posted: Sat Jul 09, 2011 5:02 pm    Post subject: First Flight. |
				Hi Ron,
 Yes, it was worth all the difficulties.  I flew a plane today that would
 have never existed if not for my efforts over the last six years.  That
 makes it the longest project I have ever done.  (Well, I've managed to
 stay married to the same woman for 41 years . . .)
 I can't really say how the Zodiac compares to the Echo.  Today's flight
 was not my best.  The turbulence and my lack of familiarity with the
 actual plane meant it was a pretty sloppy flight - at least by my
 standards.  In the large scheme of things I guess the two planes are
 very similar.  I'll try to do a detailed analysis of differences I noticed.
 It took considerably more runway to get into the air than the Echo
 takes, and still the nose jumped up rather than a nice smooth transition
 from rolling down the runway to a nice climb profile.  Takeoff (with
 flaps) in the Echo is a matter of smoothly adding power and rotating as
 soon as the power is in.  With just one person it lifts off in around
 300 feet of ground roll.  I would estimate the runway needed today to be
 closer to 600 feet in the same configuration and with a lot more
 horsepower available.
 One noticeable difference is the position of the main gear.  The Echo
 has the main gear located nearer to the CG than the Zodiac does.  On
 landing it is very easy to keep the Echo's nose gear in the air until
 almost stopped.  Holding the nose up after landing the Zodiac was a lot
 harder.  I managed to do it for a few yards (maybe 20 or so) but the
 nose really wants to come down.  I think this has a lot to do with the
 low wing vs. high wing configuration.  If the main gear were in the same
 relative place on the Zodiac then stepping on the step to climb up on
 the wing would cause the tail to hit the ground.  I've seen some designs
 that deal with this problem by putting the step in front of the wing
 instead of behind it.
 I think the Zodiac has a higher climb rate.  This is only a guess since
 the incorrect tachometer kept me from using full throttle and having
 consistent power.  A Jabiru powered Zodiac should climb a lot faster
 than a Rotax powered Echo.  There is 30 percent more power available to
 convert to climb rate.
 Visibility of the surrounding area is much better in the Zodiac.  The
 bubble canopy means everything above the horizon is easy to see and only
 the wings and nose interfere with the view downward.  In the Echo you
 sit with your head at the same level as the wing roots.  That means you
 can't see much of anything to the side because the wings are in the
 way.  You really need to roll right to look for traffic before making a
 left turn in the Echo.  This is not an issue in the Zodiac.
 I found it difficult to hold the Zodiac in the exact attitude I wanted.
 This is just probably a "Training" issue.  I also had difficulty doing
 turns at the bank angle I wanted.  I tended to roll too steeply into the
 turn.
 Oh . . . and the Jabiru sounds so much better than the Rotax engine.  It
 starts smoothly while the whole world shakes and rattles when starting a
 Rotax.  After you get it going, the Rotax seems to have a significant
 ancestry in the sewing machine community while the Jabiru sounds just
 great.  Of course, this is just my opinion and I am certainly biased.
 I suspect I will be able to do a much better comparison after I have
 logged a few more hours in the Zodiac - especially if I get a nice calm
 day to fly.
 Paul
 On 7/9/2011 5:20 PM, Ronald Steele wrote:
  Ron
		carlossa52(at)gmail.com Guest
				 Posted: Sat Jul 09, 2011 5:31 pm    Post subject: First Flight. |
				Paul, congratulations on your achievement.
 How did the Jabiru behave in the temperature department?
 Carlos
 On 9 July 2011 18:03, Paul Mulwitz <psm(at)att.net (psm(at)att.net)> wrote:
   [quote]--> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net (psm(at)att.net)>
				 Posted: Sat Jul 09, 2011 6:54 pm    Post subject: First Flight. |
				Hi Carlos,
 Thanks for the kind words.
 The Jab seemed to cool pretty well.  I don't know how much power I was
 generating, but each time the engine showed cylinders getting too hot
 (over 350 F) I reduced power.  I understand it will not generate as much
 heat as the engine gets more broken in.
 Paul
 On 7/9/2011 6:28 PM, Carlos Sa wrote:
  	  | Quote: | 	 		   Paul, congratulations on your achievement.
  Carlos
		Ron Lendon
  Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
				 Posted: Sat Jul 09, 2011 7:48 pm    Post subject: Re: First Flight. |
				Congratulations Paul,
 I know it has been a long and tiring process getting this airplane airworthy for you and I have much respect for the way you have gone through these details.
 Fly Safe,
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
				 Posted: Sat Jul 09, 2011 8:39 pm    Post subject: First Flight. |
				Thanks, Ron.
 Yes it has been a long path - one with treacherous curves.  I'm afraid I
 made a lot of enemies along the way.  Perhaps now some of them realize I
 wasn't just out to make their lives miserable.
 Hopefully we can all be happy Zodiac owners and fliers now.
 Paul
 On 7/9/2011 8:48 PM, Ron Lendon wrote:
  Fly Safe,
		PatrickW
  Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
				 Posted: Sun Jul 10, 2011 4:22 pm    Post subject: Re: First Flight. |
				Magnificent accomplishment, Paul.
 Thanks for sharing your experience.  Looking forward to hearing about Phase 1...
 - Pat
				 Posted: Sun Jul 10, 2011 6:53 pm    Post subject: First Flight. |
				Thanks, Pat.
 For now I am thinking the best thing for me to do is work on my pilot
 skills and integration with my Zodiac.  Yesterday I could barely control
 the airspeed and attitude and I need to get a handle on that before I
 can do any real testing.
 I spent today fixing most of the squawks from yesterday's flight.
 Perhaps I will fly again tomorrow and see how all the fixes came out.
 One point of interest.  I have a wood propeller and it really needed to
 have its bolts retorqued after the first flight.  Each one took a bout a
 quarter turn to get back to the desired torque - 18 ft. lbs. in my
 case.  The Sensenich data said this would be necessary but I didn't
 think it would take so much.
 Paul
 Camas, WA
 XL with one whole hour of flight logged.
		Afterfxllc(at)aol.com Guest
				 Posted: Sun Jul 10, 2011 7:28 pm    Post subject: First Flight. |
				Paul
  Before you re torque you should loosen the bolts and let the wood  relax and then re torque you will be surprised to here it pop and crack when you  do. If you torque it when it is humid the wood swells and then when it is  dry they will lose some torque also.
   In a message dated 7/10/2011 10:54:11 P.M. Eastern Daylight Time,  psm(at)att.net writes:
   	  | Quote: | 	 		  -->    Zenith601-List message posted by: Paul Mulwitz    <psm(at)att.net>
 Thanks, Pat.
 Paul
 Camas, WA
  	  | Quote: | 	 		   -->  Zenith601-List message posted by:    "PatrickW"<pwhoyt(at)yahoo.com>
  - Pat
  Patrick Hoyt
  601XLb/Corvair
  N63PZ - 99.999%    done....
  Read this topic online    here:
     http://forums.matronics.com/viewtopic.php?p=345831#345831
		don.honabach(at)pcperfect Guest
				 Posted: Mon Jul 11, 2011 10:03 am    Post subject: First Flight. |
				Paul,
  	  | Quote: | 	 		  > I found it difficult to hold the Zodiac in the exact attitude I wanted.
 On my 601HDS, I found that it was sensitive to altitude changes as well. One thing I noticed is that the stick is very easy to bias with your hand. In all fair weather cases, whenever altitude hold is an issue for me, I always find that I'm pushing or pulling the stick and not noticing since the controls are so light. I've eventually found that steering with my hand holding the bottom part of the Y leads to super easy altitude holds, as does just using my finger tips ...
 Congrats on your first flight!!!
 Don
				 Posted: Mon Jul 11, 2011 10:13 am    Post subject: First Flight. |
				Thanks, Don.
 That sounds like good advice.  When I had non-pilots try to fly the
 Tecnam I had I told them it was a 2 finger airplane.  That tended to
 work quite well.
 I'm sure I will be fine with a few more  hours.  I am just paying the
 price now for not getting a checkout before flying my own plane.  It was
 unreasonable for me to think I could just jump in and fly it like I was
 born in it.  I don't feel like I had any safety issues to fix, just a
 lack of perfection on the first try.
 Paul
 On 7/11/2011 11:02 AM, Don Honabach wrote:
  	  | Quote: | 	 		   Paul,
  Don
				 Posted: Mon Jul 11, 2011 10:27 am    Post subject: First Flight. |
				Hey Paul,
 Where are you based? Probably too close to do your 40 hours and go to Oshkosh this year for you (???).  Any thoughts on flying out next year?
 BTW, took me ~11 years to finish my 601HDS. I thought it was funny that you hinted that 6 years was a 'long time'. For me, you are Mr. Speedy     I'm still trying to figure out how I managed to take a '400 hour' build time and stretch it to 11 years!!!
 Don
				 Posted: Mon Jul 11, 2011 11:01 am    Post subject: First Flight. |
				Hi Don,
 I am indeed going to Oshkosh this year.  I will not be flying my Zodiac
 there.  I'm taking Delta Airlines to Appleton.
 My Zodiac will probably be ready to fly to OSH next year, but I'm not
 sure I will.  It is around 2500 miles each way.  That is a big trip in a
 seat that fits more like a suit of clothes than a lounge chair.
 I originally decided to go because I had a lunch date with Sabrina, but
 she seems to be mad at me about something or other and is giving me the
 teenaged-girl cold shoulder.  I guess I'll have to find other folks to
 have lunch with.
 I signed up for the electric symposium again.  I went to the one last
 year and didn't learn much of value for a home builder considering
 building an electric powered plane.  Perhaps this year's effort will be
 more on target.  At last year's symposium I did get talked into joining
 the ASTM F37 committee which deals with LSA standards.  That has been
 interesting - to say the least.
 I'll be accessing email in the evenings while at OSH, so if anybody
 wants to get together for lunch (or to beat me up for all my
 transgressions over the last few years) then email is the way to contact
 me.  I also ordered tickets for the Heintz dinner Wednesday night but
 I'm not sure I will have the nerve to go.  Perhaps if I find some body
 armor to wear . . .
 Paul
 Camas, WA
 On 7/11/2011 11:26 AM, Don Honabach wrote:
  	  | Quote: | 	 		   Hey Paul,
  BTW, took me ~11 years to finish my 601HDS. I thought it was funny that you hinted that 6 years was a 'long time'. For me, you are Mr. Speedy;-)    I'm still trying to figure out how I managed to take a '400 hour' build time and stretch it to 11 years!!!
  Don
