Gear
BobbyPaulk(at)comcast.net
PostPosted: Mon Jul 11, 2011 6:45 am    Post subject: Gear Reply with quote
Paul
I built my 601 with the gear flat side forward. The CG was o.k. normally but with a passenger and light fuel the CG would go to far aft. ( you might check that on your A/C ). CG goes aft as fuel is burned. With a 200 pounder in the right seat I would have to land with about 14 gal. of fuel to stay in range. I also did not like having to get over 50 mph before lifting the nose. The nose would also slam down with the CG forward ( full fuel ). I turned it around and it made all the difference in the world. I can hold the nose off on landing, raise it on T.O. and let the plane fly itself off when it gets ready. The CG is also better - I can not aft load it out of range without going over gross - which I do not do. The prototype photos in our kit showed the gear flat side forward so that is how we installed it on two aircraft. We both have turned them around when doing the "B mod".
much, much better.
Bobby
120.4 hrs.
601 "B"
3300 Jab.
psm(at)att.net
PostPosted: Mon Jul 11, 2011 10:08 am    Post subject: Gear Reply with quote
Hi Bobby,
I'm confused.  I thought the flat side forward moves the wheels forward.  That way the wheels are closer to the CG and raising the nose should be easier.  Did I miss something?
I appreciate your story.  Which engine do you have?
Paul
On 7/11/2011 7:42 AM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote: [quote] p { margin: 0; } Paul
much, much better.
Bobby
120.4 hrs.
601 "B"
3300 Jab.
Afterfxllc(at)aol.com
PostPosted: Mon Jul 11, 2011 11:04 am    Post subject: Gear Reply with quote
It also wouldn't change the CG of the aircraft by much at all. It does help rotate the aircraft for take-off but the actual CG in flight would remain the same or am I missing something?
I had an airplane I did the upgrade to that had a 2 inch spacer on the nose gear and when I did the weight and balance I checked it with the nose high (with spacer) weight on the ground and then leveled it and weighed it again for the true cg and what I found was the 2 inch spacer on the ground shifted the CG 65 lbs aft but when leveled the 65 lbs shifted forward. But what this did was allow the pilot to hold the nose off better than I had seen on any 601 yet. The point is the spacer has no effect after the plane is airborne but a big effect on the ground.
jeff
In a message dated 7/11/2011 2:09:13 P.M. Eastern Daylight Time, psm(at)att.net writes:
Hi Bobby,
Paul
much, much better.
Bobby
120.4 hrs.
601 "B"
3300 Jab.
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
bryanmmartin
PostPosted: Mon Jul 11, 2011 4:12 pm    Post subject: Gear Reply with quote
What you describe hear is nearly exactly what I experienced except I originally had my main gear installed with the flat side forward and then turned it around flat side aft. Putting the flat side aft moves the main wheel assemblies (tires, tubes, wheels, brakes and axles) about 4 1/2 inches further forward and the CG of the 40 lb main spring about 2 inches forward. This puts the mains closer to the aircraft's CG so it requires less elevator force to rotate for takeoff and less force to hold the nose off during landing.
I think maybe you misstated this?
On Jul 11, 2011, at 10:42 AM, BobbyPaulk(at)comcast.net wrote:
Paul
much, much better.
Bobby
120.4 hrs.
601 "B"
3300 Jab.
Bryan Martin
do not archive.
psm(at)att.net
PostPosted: Mon Jul 11, 2011 4:44 pm    Post subject: Gear Reply with quote
I'm really having a hard time with this.
I think the issue in my mind is whether or not the spring is bent at 90
degree angle to the edge. That would put the wheels closer to the flat
side than the angled side. On the other hand, if the bend is made at an
angle (to the center line of the spring) then it would all depend on
what the angle was.
Paul
> Paul
> much, much better.
> Bobby
> 120.4 hrs.
> 601 "B"
> 3300 Jab.
zodiac601
PostPosted: Mon Jul 11, 2011 6:24 pm    Post subject: Re: Gear Reply with quote
I'm not sure what angle you are referring to... when looking at the gear from the wing tip, the axle is nearer the straight (flat) edge of the gear. If you flip the gear around, the axle moves forward as stated above.
psm(at)att.net
PostPosted: Mon Jul 11, 2011 7:14 pm    Post subject: Gear Reply with quote
I think that is consistent with my understanding of the whole "Flat
side" question. However, it seems several posters are saying they moved
from the "Flat side forward" to reverse the position to "Flat side aft"
and got the results of moving the wheels forward.
I wonder if there is more than one interpretation of the meaning of what
the "Flat side" is . . .
Paul
PostPosted: Mon Jul 11, 2011 10:47 pm    Post subject: Gear Reply with quote
As you can see the "flat part is aft in the original design so if you reverse the gear the flat side would be forward and the wheels move forward also.
In a message dated 7/11/2011 11:14:57 P.M. Eastern Daylight Time, psm(at)att.net writes:
--> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net>
Paul
I'm not sure what angle you are referring to... when looking at the gear from the wing tip, the axle is nearer the straight (flat) edge of the gear. If you flip the gear around, the axle moves forward as stated se the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
 Filesize:  7.42 KB
 Viewed:  8510 Time(s)
psm(at)att.net
PostPosted: Tue Jul 12, 2011 12:19 am    Post subject: Gear Reply with quote
PostPosted: Tue Jul 12, 2011 11:12 am    Post subject: Gear Reply with quote
Paul,
My gear was installed with the flat side to the rear at first. ( old man's disease ) Anyway I moved the wheels forward roughly 6" by turning it around. I weigh 185 lbs. all up flying weight and the nose does not come up when I enter the plane. My drawings say to install it flat side forward but the picture in my kit shows it aft.
I am glad i changed it.
Bobby
3300 Jabiru
601 "B"
120 hrs.
psm(at)att.net
PostPosted: Tue Jul 12, 2011 12:34 pm    Post subject: Gear Reply with quote
Hi Bobby,
Thanks for the message. That is the way I installed my gear to begin with.
I think this is all just proof that each model airplane flies a bit
differently from all the rest. The Tecnam I was flying had the main
gear very close to the CG, and that allowed rotation early on takeoff
and holding off the nose on landing until the plane was just about stopped.
The Zodiac XL is more nose heavy on the main gear. I think this means
you need to get it going faster on the runway before lifting the nose.
Perhaps you can take off at the same pitch attitude as you get rolling
on all three wheels. So, it takes more runway to take off. This is not
a big deal since even twice as much runway means about 600 feet instead
of 300. I don't think there is any public airport that would be too
short for a Zodiac and it was never meant as a bush plane.
Paul
On 7/12/2011 12:09 PM, BobbyPaulk(at)comcast.net wrote:
Paul,
Bobby
3300 Jabiru
601 "B"
120 hrs.
