Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27955 Location: Toledo Washington (KTDO) USA
Posted: Sun Jul 10, 2011 7:04 pm Post subject: Reusing 3/8" Flares... |
Dear Listers,
I pulled out all of the fuel selector valve and fuel pump goodies from the old fuselage today. I disassembled all of the various flare ends and cleaned up all the Fuel Lube with lacquer thinner making sure not to get any in the pump or valve or transducers. All but two of the fuel lines seem to be reusable and don't show any signs of damage from the Mishap. I really don't want to have to recut, rebend, and reflare all of these if I don't have to.
What's the common knowledge on reusing the flares on the fuel and brake lines?
Am I just asking for a bunch of leaks if I put these back into service now that I've unscrewed them?
Thanks!
Matt
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
133.43 KB |
3100 Time(s) |
151.55 KB |
3100 Time(s) |
_________________ Matt Dralle
BGray(at)glasair.org Guest
Posted: Sun Jul 10, 2011 7:45 pm Post subject: Reusing 3/8" Flares... |
As long as the flares and the B nut are undamaged, they can be reused.
Bruce
WWW.Glasair.org
ralphmariafinch(at)gmail. Guest
Posted: Sun Jul 10, 2011 7:51 pm Post subject: Reusing 3/8" Flares... |
I don't have definitive answers to your questions...but this is important
enough to get some. Call John Schwaner of Sacramento Skyranch and ask him to
be sure. He won't commit to an answer (liability), but just ask for his
opinion...what he might do.
That said, here's a couple of thoughts. First, on flared connections, I
don't think fuel lube does a thing. Doesn't hurt but doesn't help the seal.
Second, I'm *guessing* Al is malleable so it can be reused...up to a point.
If the flared end is tightened and relaxed in a lot of cycles you will
fatigue it.
But call John or another real experienced expert for the right answer.
Ralph Finch
dave.saylor.aircrafters(a Guest
Posted: Sun Jul 10, 2011 8:24 pm Post subject: Reusing 3/8" Flares... |
Matt,
As long as they're in good shape you'll be fine. This being the first
time off I wouldn't worry too much about them being worn out. Look at
the recent thread about brake lines, but something tells me you've
already got hoses to the calipers.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sun, Jul 10, 2011 at 8:02 PM, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
I pulled out all of the fuel selector valve and fuel pump goodies from the old fuselage today. Â I disassembled all of the various flare ends and cleaned up all the Fuel Lube with lacquer thinner making sure not to get any in the pump or valve or transducers. Â All but two of the fuel lines seem to be reusable and don't show any signs of damage from the Mishap. Â I really don't want to have to recut, rebend, and reflare all of these if I don't have to.
Thanks!
Matt
chaskuss(at)yahoo.com Guest
Posted: Mon Jul 11, 2011 3:12 am Post subject: Reusing 3/8" Flares... |
Matt,
Generally, you can re-use the fitting. If in doubt, you can add conical, copper sealing washers between the flare and the AN fittings to improve the seal. See
http://lastminutemall.com/secoseals/SECO_7_Copper_Seals.html
http://www.ap100.com/
or go to Aircraft Spruce's site and do a search for : 04-05006 DEL FITTING SEAL 3/8" OD
Charlie Kuss
--- On Sun, 7/10/11, Matt Dralle <dralle(at)matronics.com> wrote:
| Quote: | From: Matt Dralle <dralle(at)matronics.com>
Subject: Reusing 3/8" Flares...
To: rv-list(at)matronics.com, rv8-list(at)matronics.com, rv7-list(at)matronics.com
Date: Sunday, July 10, 2011, 11:02 PM
Dear Listers,
Thanks!
Matt
Construction Log
Log
http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV
YouTube Channel
Mishap...
