pcondon(at)mitre.org Guest
Posted: Wed May 17, 2006 9:56 am Post subject: Ryton sumps Ryton sumps Another fix or Solution |
I made a forward facing sump out of a Lycoming magnesium casting from a
B1A sump. The Normal B1A sump has a rearward machined injector mount
and also has a rough cast area in the front that can be machined flat
and the studs mounted to mount a front injector. I spent 90 dollars at
a machine shop in my little 'berg where I live to machine the front
rough cast flat and thread the studs. I cut a plate from 1/4 inch
aluminum stock to make a plate for the rear hole. Works fine and when
you eye-ball the sump you can see where the cast areas are identical in
the front or rear. This is not a TSO/FAA/PMA/STC'ed mod, but as
experimental, works great. The magnesium is light too. Not the cold air
thing, but at least not subject to breakage either.
I have a spare, untouched sump (as described); When I looked into this
a few years ago. One salvage yard sent me one a few months after I
contacted them...... then they didn't have one initially. Wires got
crossed and the sent me one (with a bill for 750$). So, I wound up with
two, modified the one now on my airplane--hence the spare in the
garage. Maybe this is a solution for the Ryton folks........
I've been on the phone all day researching this topic. Thanks for =
pointing me in the right direction Gary.
Here's the deal:
If you want a "cold air sump", there seems to be 3 choices-
Ryton sump by Superior
Magnesium sump by ECI
Barrett Precision cold air sump
All the other metal sumps out there-
Aerosport Power
Aero Engines
Superflite
Are all copies of the Lycoming cast aluminum sump (not cold air sumps)
The Ryton sump (by Superior Engines) we've discussed before here, it =
costs 1000 to 1300 dollars and will break when used with a wasted spark
electronic ignition system...if not sooner, then later. You might not
know it's broken unless you inspect it closely like I did. Superior =
does not see the magnitude of the problem of the sumps it has in the =
field, but is currently in a "redesign" of the Ryton sump to address
the =
wasted spark ignition issue. The new sump is expected out by October.
Based on other new product announcements, I wouldn't look for it a day
sooner.
The magnesium sump by ECI is just now becoming available and costs
about =
$2400 including the tubes. There are two of them out there on aircraft
so far. If you want to be #3, they should be ready to ship on May 22.
I was told I'd have to fab a support bracket for the Bendix or AFP
servo =
because that was "too much weight" out there for the induction portion
of the sump to hold unsupported. That bothered me. The flange for =
mounting the fuel servo is also forward from where the Ryton sump
flange =
is, which will mean more extensive alteration of the air snorkel to get
it to fit.
I don't have the information on the Barrett Cold Sump system, but it is
the most expensive of the three. I'll post that here when I find it.
I guess that's it...
My choice will be the Superflight sump, when it's available in a few =
weeks. It's a clone of the Lycoming forward facing sump, so it's not a
"cold air sump". I have made peace with that and decided if I get a =
sump that WON'T BREAK, that will be more important than a few more =
horsepower. All these clones of the Lycoming forward facing sump are =
priced about the same at $2200.
I sure think there's a market out there for a well made cold air =
induction system...but I don't think there's a good one at a reasonable
price that's available yet.
For those of you who are running Ryton sumps, I encourage you to
inspect =
them very closely and very regularly. Like every time you fly. Two of
these sumps that have broken here have actually broken into pieces that
fell out onto the ground below the aircraft. The others have just =
cracked. In the case of my sump, the engine still ran fine with the =
cracked sump. Had we had the engine cowled, I would have had no reason
to uncowl it to inspect it before going flying. Had the lower part of
the sump (where the fuel servo mounts) broken off in flight, I am sure
it would have ruined my day.
bob
rv7a
last few things plus a new induction system
