		backstagelive(at)gmail.co Guest
				 Posted: Sun Jul 10, 2011 8:45 am    Post subject: First Flight.  (Joe) |
				Congratulations Paul! Keep us posted as you go through the flight test
 process. A long time back, there was a thread about turning the Zodiac
 landing gear around so it takes more of the weight off the nose during
 landing and takeoff. I'm not sure if anyone has done that. Is there anyone
 watching this thread that has actually done that? Would that be something
 you would consider Paul?
 Joe
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		psm(at)att.net Guest
				 Posted: Sun Jul 10, 2011 11:47 am    Post subject: First Flight.  (Joe) |
				Hi Joe,
 I actually installed my gear with the flat edge forward on the first
 pass.  I think I understand the reason the nose is so hard to get off
 the runway.  It is because the main gear is put far enough behind the CG
 so you can step on the step behind the wing and still not make the tail
 smack in to the ground.
 Paul
 On 7/10/2011 9:42 AM, Joe wrote:
  anyone watching this thread that has actually done that? Would that be
  something you would consider Paul?
  Joe
		merlin
  Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
				 Posted: Sun Jul 10, 2011 11:49 am    Post subject: First Flight.  (Joe) |
				That's what I plan to do as well and I'm going to go with the grove gear to save some weight added by the upgrade.
 Sent: Sun, July 10, 2011 12:42:49 PM
 Subject: Re: First Flight.  (Joe)
				 Posted: Sun Jul 10, 2011 12:11 pm    Post subject: First Flight.  (Joe) |
				Hi Joe,
      Before you change something as big and heavy as the landing gear     "Spring" you might want to check into the weight and balance     impact.  With the Zenith spring and Jabiru engine the first W&B     came up really nicely with the CG nearly centered in the envelope.
      Paul
      On 7/10/2011 12:47 PM, JEFFREY WEBB wrote:     [quote]       That's what I plan to do as well and I'm going to go with the         grove gear to save some weight added by the upgrade.
