Under control . . .
PostPosted: Thu Jul 07, 2011 12:05 pm    Post subject: Under control . . . Reply with quote
At 12:46 PM 7/7/2011, you wrote:
How long is this inappropriate use of the Aeroelectric Connection
forum going to go on? We all signed up to this forum pledging to use
it for its intended purpose. THIS AIN'T IT. There are literally
thousands of site devoted to political BS. There is only one AEC.
How about it guys and gals, can we just talk electrons here?
Gently my friend . . . at least the subject
line didn't creep. Just hit the delete key
until we can get it squared away. The
AEC list is not in danger of getting away
from us!
You up for some 'cross country' in that
airplane of yours? Ya outta come down for
for some BBQ-n-Beer some weekend. We'll
put you up.
park045(at)cox.net
PostPosted: Thu Jul 07, 2011 1:05 pm    Post subject: Under control . . . Reply with quote
FIREDOG
Mike Parker
On Jul 7, 2011, at 4:00 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
> How long is this inappropriate use of the Aeroelectric Connection forum going to go on? We all signed up to this forum pledging to use it for its intended purpose. THIS AIN'T IT. There are literally thousands of site devoted to political BS. There is only one AEC. How about it guys and gals, can we just talk electrons here?
from us!
put you up.
rickofudall
PostPosted: Thu Jul 07, 2011 8:11 pm    Post subject: Under control . . . Reply with quote
Bob, I had a bad day last Sunday, at least for my plane. Engine started to sputter at about 300' on take off. I made the impossible turn, but as Maxwell Smart used to say, "Missed it by that much". If the runway had only been 2 feet lower.......I walked away without a scratch or bruise, but now I have a little rework to do. Maybe I can come over in the trike once the summer heat subsides a bit.
Rick
On Thu, Jul 7, 2011 at 3:00 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
 from us!
 put you up.
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
 Filesize:  1.01 MB
 Viewed:  1773 Time(s)
PostPosted: Fri Jul 08, 2011 6:34 am    Post subject: Under control . . . Reply with quote
Just damn . . . glad you're okay. Did you
figure out what's up with the engine?
rickofudall
PostPosted: Fri Jul 08, 2011 7:52 am    Post subject: Under control . . . Reply with quote
I can't find anything wrong with it, no signs of seizure or anything like that. It starts and runs fine. The weather at the time was very humid and the temps had just dropped 20 degrees following a thunderstorm passage. I wasn't on my best investigative abilities after I crawled out of the plane so I didn't check to see if there was ice on the carbs. I'd been thinking about modifying the front of the fuselage truss to accommodate a forward opening canopy, so I'm looking on this as an opportunity. :-}
Rick
On Fri, Jul 8, 2011 at 9:30 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Mike Welch
PostPosted: Fri Jul 08, 2011 1:20 pm    Post subject: Under control . . . Reply with quote
>I'd been thinking about modifying the front of the fuselage truss to accommodate a forward opening canopy, so I'm looking on this as an >opportunity. :-}
Rick
Rick,
  You could modify the front of the fuselage to accept "side swinging" doors.  They call it
an Xtra.
Mike Welch
