65l Europa fuel tank
stranfaer(at)btinternet.c
PostPosted: Tue Jun 21, 2011 12:01 pm    Post subject: 65l Europa fuel tank Reply with quote
Good evening list
I am working on a little project that may benefit us all, does anyone have a line drawing of the Europa 65L fuel tank that can be emailed to me, I also need the dimensions if anyone can get a tank to do this I would be most grateful, I need all the measurements, including depth of and dimensions of the saddle part, width, height girth etc!
I look forward your response and to the power of the list....
Kindest regards
David Joyce
(the other one)
rowlandcarson(at)gmail.co
PostPosted: Tue Jun 21, 2011 2:06 pm    Post subject: 65l Europa fuel tank Reply with quote
David - I haven't measured it, but I do have a complete spare tank that you can have, to do what you like with. Available for collection in Gloucestershire - let me know if you want it.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
g-iani(at)ntlworld.com
PostPosted: Tue Jun 21, 2011 11:34 pm    Post subject: 65l Europa fuel tank Reply with quote
David
I do not have an accurate CAD drawing of the tank. What I have is attached as a PDF.
If you are going to take up Rowland’s offer then I will be happy to produce an accurate drawing from it.
Bear in mind that the tank has had slight changes with almost every production batch. The changes I know about involve a ridge across the front to reduce the bulging.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David Joyce
Sent: 21 June 2011 20:59
Subject: 65l Europa fuel tank
Good evening list
Kindest regards
David Joyce
(the other one)
http://www.matronics.com/Navigator?Europa-List< - MATRONICS WEB FORUMS -
tank.pdf
 Filename:  tank.pdf
 Filesize:  10.2 KB
 Downloaded:  224 Time(s)
m.j.gregory(at)talk21.com
PostPosted: Thu Jun 23, 2011 12:42 am    Post subject: 65l Europa fuel tank Reply with quote
Ian,
If it would help you to build up a library of tank dimensions from different vintages, I can bring you my 1996 tank (subsequently fluorinated by return to the manufacturer) when I come to Bisley tomorrow.
Mike
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of G-IANI
Sent: 22 June 2011 08:31
Subject: RE: 65l Europa fuel tank
David
e-mail g-iani(at)ntlworld.com (g-iani(at)ntlworld.com)
Good evening list
Kindest regards
David Joyce
(the other one)
PostPosted: Thu Jun 23, 2011 9:58 am    Post subject: 65l Europa fuel tank Reply with quote
Mike
If you don’t mind that would be a good idea. I will measure it and photograph and you can have it back almost immediately
Ian
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Mike Gregory
Sent: 23 June 2011 09:39
Ian,
Mike
David
Good evening list
Kindest regards
David Joyce
(the other one)
