Southbridge Airport Tornado
mrspudandcompany(at)veriz
PostPosted: Mon Jun 20, 2011 6:15 am    Post subject: Southbridge Airport Tornado Reply with quote
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
Eric,
I just flew into Southbridge airport this
past week and saw the devastation. I counted about 15 damaged aircraft at
the tiedowns. The damage seemed to be everything from some wingtip damage
to total destruction. One aircraft was just a pile of rubble with the only
way to tell it was an aircraft was an engine with propeller attached in the
pile.
Hope you did not suffer any loss to the
wind.
I have my plane at North Central, certainly
glad it was not Southbridge.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.81 KB
 Downloaded:  456 Time(s)
N20DG
PostPosted: Mon Jun 20, 2011 6:29 am    Post subject: Southbridge Airport Tornado Reply with quote
Question: What program do you use to run .dat files???? I can't find anything to run them on but I'm a computer dummy
Dick
In a message dated 6/20/2011 9:17:01 A.M. Central Daylight Time, mrspudandcompany(at)verizon.net writes:
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
  Eric,
pile.
wind.
  Roger
PostPosted: Mon Jun 20, 2011 6:54 am    Post subject: Southbridge Airport Tornado Reply with quote
Dick
.dat files are usually information files created
by some application like a spread sheet, electronic
Rolodex, data acquisition system, etc.
Thus they don't have any common industry
format and will generally be accessible only
by the application that generated it.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
N20DG
PostPosted: Mon Jun 20, 2011 7:06 am    Post subject: Southbridge Airport Tornado Reply with quote
Ok, Thanks, I find that a lot of those files are attached to the e-mails. I'll just disregard them in the future
Thanks again
Dick
In a message dated 6/20/2011 9:55:13 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
Dick
  (o o)
ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
riggs_la(at)yahoo.com
PostPosted: Mon Jun 20, 2011 1:02 pm    Post subject: Southbridge Airport Tornado Reply with quote
A *.dat file is a data file that is used by and other program that needs information to run and the dat file gives it that information. What operation system are you using?
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RGent1224(at)aol.com
Sent: Monday, June 20, 2011 9:26 AM
Subject: Re: Re: Southbridge Airport Tornado
Dick
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Eric,
pile.
wind.
Roger http://www.matronics.com/Navigator?AeroElectric-List
N20DG
PostPosted: Mon Jun 20, 2011 1:06 pm    Post subject: Southbridge Airport Tornado Reply with quote
windows XP Pro
In a message dated 6/20/2011 4:02:50 P.M. Central Daylight Time, riggs_la(at)yahoo.com writes:
Dick
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
  Eric,
pile.
wind.
PostPosted: Mon Jun 20, 2011 1:08 pm    Post subject: Southbridge Airport Tornado Reply with quote
I would be very suspicious of an email that had a dat file attached to it. Do you have good anti-virus checking software?
Sent: Monday, June 20, 2011 10:04 AM
Thanks again
Dick
Dick
  (o o)
ist href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Lists.matronics.com/">http://forums.matronics.comp://www.matronics.com/contribution">http://www.matronics.com/contribution
