hhobbit
Posted: Sun Jun 19, 2011 4:40 pm Post subject: troubleshooting overvoltages |
Say you've fried a transponder for no apparent reason. So it gets fixed, at a cost. Now putting it back in and hoping for the best doesn't seem particularly bright. I wonder if general info on troubleshooting this sort of problem has been published anywhere, and would really appreciate any advice or links available.
Posted: Sun Jun 19, 2011 7:09 pm Post subject: troubleshooting overvoltages |
At 08:40 PM 6/19/2011, you wrote:
What parts were damaged? Did the repairing service
offers some hypothesis as to what happened? Is your
airplane fitted with overvoltage protection?
hhobbit
Posted: Mon Jun 20, 2011 5:25 am Post subject: Re: troubleshooting overvoltages |
Bob
Dont know for sure until it goes back for repair. I phoned the Mendelssohn repair shop and they tell me that the Bendix King KT76C is rarely a victim of overvoltage. There is a fuse marked LF 7A in near the edge connector which is supposedly the first item to blow; it tested ok for continuity without removing it from the board. Further in there is a crowbar device which I am informed cannot be tested in place, at least one end must be desoldered. I don't want to disturb that because I don't have conformal coating product to reinstate it in. One might reasonably go on the assumption that the fuse would protect from an overvoltage? or not? In either case the crowbar device should. I am awaiting further communication from another repair shop which should help decide that. Seems the circuit breaker was too lazy to do its job then
There are four unallocated circuit breakers on the aircraft wiring diagram with rating values of 3, 6, 8 and 10A. Until I am back at the plane which is 40 odd miles away, I wont be able to determine if its connected to the 3A breaker which would be the correct one for a 1.6A transponder maximum load. BTW aircraft is a CTSW.
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Mon Jun 20, 2011 5:28 am Post subject: Re: troubleshooting overvoltages |
| Quote: | | Say you've fried a transponder for no apparent reason. |
Dear H. Hobbit,
Please furnish us AeroListers with a reasonably good schematic.
Together, we eclipse the combined intelligence of the Krell Empire....
Dabbling with Electricity.pdf |
101.68 KB |
644 Time(s) |
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
l_luv2_fly(at)yahoo.com Guest
Posted: Mon Jun 20, 2011 6:15 am Post subject: troubleshooting overvoltages |
Perhaps even the known universe
do not arhive
Sent: Monday, June 20, 2011 8:28 AM
Subject: Re: troubleshooting overvoltages
--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)>
| Quote: | Say you've fried a transponder for no apparent reason.
Dear H. Hobbit,
Eric M. Jones
[url=http://www.PerihelionDesign.com][/url]
Posted: Mon Jun 20, 2011 7:05 am Post subject: troubleshooting overvoltages |
At 08:25 AM 6/20/2011, you wrote:
Bob
Actually, the Transorb is the 'protective' device.
The upstream fuse offers a means by which the
circuit may be broken if the antagonistic transient
duration is too long (like runaway alternator).
| Quote: | or not? In either case the crowbar device should.
Yes, if there was a power transient event, one would
reasonably expect the transorb to stand off the event
until (1) the even ends or (2) the fuse blows.
| Quote: | I am awaiting further communication from another repair shop
lazy to do its job then [Evil or Very Mad]
Circuit breakers are not ov protection devices any
more than fuses. They become part of an ov protection
system when combined with crowbar ov protection
devices like our OVM series devices . . . Transorbs
must be combined with fuses which are 10 to 100 times
FASTER than breakers. It's a rather common misconception
that fuses and breakers in the power distribution
system are protection for ov events. The only service
they perform is to protect wires from severe overload
along with isolating a fault such that it does not
affect the rest of the airplane.
If your fuse is intact, then perhaps there was
no OV event. The transponder may have simply
suffered a failure of a venerable component.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
Eric M. Jones
Posted: Mon Jun 20, 2011 7:44 am Post subject: Re: troubleshooting overvoltages |
Make sure you understand the difference between Transorbs and MOVs.
They do approximately the same thing, but MOVs are rarely used anymore because they have an inherent wearout mechanism. So over time, they tend to age...then fail short.
Ask the service tech for the part ID.
113 Brentwood Drive
(508) 764-2072
hhobbit
Posted: Wed Jun 22, 2011 1:43 pm Post subject: Re: troubleshooting overvoltages |
Has anyone here got a usb oscilloscope? the type that turns a laptop or notebook pc into a storage scope? If you have one, it would be great to find out what are the important specs for such a device. They are on ebay starting at suspiciously cheap $50. I figure on recording for example start up voltage transients in the vicinity of the starter, alternator and regulator. Using such a device, the intention is to eliminate a lot of theorising . The manufacturer tells me there is no history of this kind of trouble, and if there is a rogue regulator or capacitor this could be a definitive way to diagnose. My original question on this forum was for general information on how to go about solving such a problem.
BTW I found an interesting general article on ESD: http://www.eib-gmbh.de/englisch/faqs/text_faqs.htm in particular Q13.
Posted: Wed Jun 22, 2011 4:14 pm Post subject: troubleshooting overvoltages |
At 04:43 PM 6/22/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: "hhobbit" <jm2833530(at)gmail.com>
Has anyone here got a usb oscilloscope? the type that turns a laptop or notebook pc into a storage scope? If you have one, it would be great to find out what are the important specs for such a device. They are on ebay starting at suspiciously cheap $50. |
Every one of those products will perform as advertised . . .
and in many cases, ANY 'scope is better than NO 'scope.
Be wary of the ratings. Know that "samples per second"
is related to but separate from "bandwidth." For
example:
http://tinyurl.com/6b6lytn
is advertised as a 200 mHz bandwidth and 250 mega-samples
per second. In general, sample rates should be AT LEAST 3x the
period of interest. So 250 m-s/S implies a useful bandwidth
on the order of 80 mHz . . . which is respectable for a
$350 digital 'scope. But really 'clean' paints of wave-forms
will be limited to 25 mHz.
My Tektronix digital scope is rated at 100 mHz bandwidth
and 1000 m-s/Sec. Or 10x the rate of the signal of
interest. This means that 100 mHz displayed wave-forms will
be very faithful to reality a compared with a device
that is only 3x faster.
Your search for electrical gremlins needs to capture
transients of 100 nanoseconds or longer. Shorter transients
are easily shunted off by the capacitors that are
invariably part of every piece of electronics. Looking
for these little short duration spikes is always disappointing.
But to get a good picture of a 100 nS event, you're looking
for samples at 20nS intervals which is 50 megasamples/S.
So the 'scope described in the link above would suffice.
Bob . . . [quote][b]
enginerdy(at)gmail.com Guest
Posted: Wed Jun 22, 2011 6:51 pm Post subject: troubleshooting overvoltages |
I have a Rigol 1052E... it has 50MHz bandwidth and 1GS/s (gigasample per second) when using one channel and 500MS/s when using both channels. If you're feeling brave, it can be hacked up to 100MHz bandwidth. Around $400. It has some drawbacks, but it's pretty great for the price.
http://www.tequipment.net/RigolDS1052E.html
Another option is the DSO Nano v2. It's more of a toy, but a lot cheaper. $99
http://www.sparkfun.com/products/10244
With both you should be able to save images of your captures. The first exceeds Bob's advice, the second doesn't really come close.
On Jun 22, 2011, at 4:43 PM, hhobbit wrote:
ainut(at)knology.net Guest
Posted: Thu Jun 23, 2011 4:24 am Post subject: troubleshooting overvoltages |
Be advised. the DSO unit is made and is shipped from China.
David
Daniel Hooper wrote:
If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros.
..democracy and a republic can function only in a firm partnership with morality and religion. -- John Adams. Indeed. Same should be said for ANY type of gubmnt
hhobbit
Posted: Thu Jun 23, 2011 11:07 am Post subject: troubleshooting overvoltages |
You've got that a little turned around. If you order the Rigol from
tequipment.net, it will ship directly from China, like mine did. Rigol
is a Chinese company, and makes decent products for people on a tight
budget. The only issue I had was the foreign power plug that came with
it. I substituted a spare US IEC cable (a computer power cord) and was
up and going quickly.
The DSO (which I've never used) may be made in China, but Sparkfun is
in Boulder, CO -- to the best of my knowledge everything they sell
ships from there.
Both sparkfun and tequipment.net are companies I've bought from in the past.
On Thu, Jun 23, 2011 at 7:14 AM, David <ainut(at)knology.net> wrote:
David
