stuart(at)stuarthutchison Guest
Posted: Mon Jun 13, 2011 12:17 am Post subject: Inflight load return wire size |
G'day Bob,
I have an all-metal aircraft without much room for large diameter wires,
especially two. I recall reading that it's a good idea to have power and
return lines of the same size for small systems, but is it really necessary
to have a return wire to the battery of the same size as the starter wire?
In other words, I have # 2 AWG CCA fatwire from the battery (down aft) to
the starter contactor at the firewall, but I would like to use a # 6 CCA
fatwire for inflight currents? I was thinking of grounding the engine to
the airframe, but using an # 6 CCA fatwire for return to the battery
(insulated from the airframe - to which normal inflight loads [lights,
avionics etc] would be connected). Is this idea OK?
Cheers, Stu
benboatright(at)gmail.com Guest
Posted: Mon Jun 13, 2011 3:57 am Post subject: Inflight load return wire size |
There was a very good article in one of the aviation magazines recently that discussed grounding. The article pointed out that your ground wire should be as large as (or larger) than your positive wire.
Keeping the size to those rules should minimize and/or eliminate any ground feedback looping.
Ben
J. Ben Boatright
benboatright(at)gmail.com (benboatright(at)gmail.com)
Member, AOPA and EAA
On Mon, Jun 13, 2011 at 4:13 AM, Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:
[quote] --> AeroElectric-List message posted by: "Stuart Hutchison" <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)>
G'day Bob,
Cheers, Stu
http://forums.matronics.com
le, List Admin.
mrspudandcompany(at)veriz Guest
Posted: Mon Jun 13, 2011 4:48 am Post subject: Inflight load return wire size |
Cheers, Stu
I own a "tin" T/C aircraft (Cessna Cardinal) and it has the
battery in the rear. The negative terminal is connected directly to the
airframe with a short cable. There are no other cables going to the
negative side of the battery. This seems to work well for Cessna, in that
they use the whole airframe as ground reference. When you use this method
always be sure that you have a substantial ground strap from the engine to
the airframe.
Roger
winmail.dat |
3.7 KB |
398 Time(s) |
Posted: Mon Jun 13, 2011 6:19 am Post subject: Inflight load return wire size |
At 04:13 AM 6/13/2011, you wrote:
<stuart(at)stuarthutchison.com.au>
G'day Bob,
I'm not getting a good mental image of your proposed ground
system architecture. How long are the wires in question?
If you take the approach illustrated in Figure Z-15 View -A-
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z15K1.pdf
. . . you can consider the option of taking a same-size battery
ground wire to the single-point, firewall ground -OR- grounding
the battery locally
http://aeroelectric.com/Pictures/Grounding/Local_Battery_Grounds_1.jpg
2AWG wire may be somewhat oversized too. Unless you have a
really big engine or the battery is a long ways away from
the starter, 4AWG wire might be adequate to the task.
But I do suggest you review your grounding philosophy in
light of suggestions offered in Z-15 and chapter 5 of
the 'Connection.
Posted: Mon Jun 13, 2011 8:00 pm Post subject: Inflight load return wire size |
Thanks Bob,
Yes, I have an IO-540 with the starter about 10 feet ahead of the battery.
This configuration is needed A) due to space limitations and B) for weight
and balance. I understand the need for a big cable to carry start current
and planned to ground this current via the airframe to a local bonding strap
next to the battery. However, after start, normal inflight currents will
obviously feed via the same big cable to the hot pole of the starter
contactor, then to the busses and I would like to ground via a dedicated
return to the battery post that is only 6 AWG and is insulated from the
airframe. I don't understand why we need an return cable the same size as
the starter wire when only 60-70A max is passing through this during flight?
Z-15 shows the engine bonding strap connected to a 2 AWG return all the way
to the battery, but I propose not to do this, since high currents are only
required during start and can be grounded via the airframe for that short
period. I would have thought any noise generated during start would be
acceptable, because it is temporary? Perhaps different sized power and
return wires cause noise regardless of whether they are both quite able to
carry the current .. I don't know?
Kind regards, Stu
Posted: Tue Jun 14, 2011 4:40 am Post subject: Inflight load return wire size |
At 11:54 PM 6/13/2011, you wrote:
Thanks Bob,
airframe.
Ground what? If the engine is grounded to airframe (at
the firewall ground bus?) and the battery is grounded
to airframe locally, everything else goes to the firewall
ground bus. You don't need any wire going back to the
battery(-) for grounding other things.
| Quote: | I don't understand why we need an return cable the same size as
to the battery,
For a plastic airplane that. That pathway CAN be
eliminated in metal airplanes as described above.
| Quote: | but I propose not to do this, since high currents are only
This is not a noise issue, only cranking performance.
Do Z-15 with local ground for the battery, single point
firewall ground for everything else (with exceptions
for remotely grounded, non-victims noted) and you're
done.
Posted: Tue Jun 14, 2011 5:30 am Post subject: Inflight load return wire size |
OK, thanks Bob.
I seem to recall reading somewhere ... over the past 3 years ... that
grounding the avionics at the firewall in a metal airframe can lead to
multiple grounds with different potentials. Perhaps I confused this with
grounding the various avionics boxes to the airframe whereever it happened
to be convenient, rather than at a common point.
Kind regards, Stu
Posted: Tue Jun 14, 2011 6:37 am Post subject: Inflight load return wire size |
At 09:26 AM 6/14/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Stuart Hutchison" <stuart(at)stuarthutchison.com.au>
OK, thanks Bob.
to be convenient, rather than at a common point. |
Yeah. Lots if not most avionics get grounded to
the airframe locally because their power and signal
grounds are common to chassis. This is what prompted
the idea behind the avionics panel ground bus added
to the Z-figures along with this product to the catalog.
[img]cid:7.1.0.9.0.20110614102312.01db80f0(at)aeroelectric.com.0[/img]
The idea is to take all the potential victims to
ground in a location as local to the avionics
package as practical. Ground-loops on the panel
are short, and VERY weakly excited. Once the
potential victims are fire-walled, you can
take the power grounds off the panel to about
anywhere free of concerns for installation induced
noise.
This is not so much about holding big
risks for noise at bay as it is doing-the-
best-we-know-how-to-do without jacking up
cost of ownership. The local ground bus
on the panel is a great convenience when
assembling the panel that also goes to
risk of noise reduction.
When we put the insulating washers under
headset and mic jacks, THAT activity beat
down most of the risk for noises in the
radios right there. There is still the
occasional strobe noise issue but those
are pretty rare now too.
The point is that after 100 years of
bolting engines to wings and climbing
aboard, our recipe for success is pretty
well refined.
56.38 KB |
4896 Time(s) |
