n223rv(at)wolflakeairport Guest
Posted: Thu Jun 02, 2011 6:46 pm Post subject: Nose Wheel Noise |
Does anyone else's nose wheel make noise when steering (left and right motion, not rotary motion). I have greased it thru the zerk fitting and tried a few other things which help, but only for a short time. Are others seeing this? Any ideas how to fix? My next step is a full disassembly and re- grease it all up.....
-Mike Kraus
Lew Gallagher
Posted: Fri Jun 03, 2011 7:09 am Post subject: Nose Wheel Noise |
Hey Mike,
I would suspect the big washers that sit on top of the fork. Others have
said that when they wear in, the left right torq needs to be reset, so I
went ahead and polished the mating surfaces and greased them before
installing on Wes's plane and setting the torq -- haven't had any squeak but
still checked and reset torq after about a year of flying.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
