redrocketrider
Joined: 13 May 2011 Posts: 67 Location: Nervino airport
Posted: Fri Jun 03, 2011 6:07 am Post subject: Speed |
Hi kitfox aviators ! Doing a extensive annual and wheel change and looking to possibly install a set of wheel pants that we now have. These puppies' are really of rather dubious size and shape. All you speedster guys, did you see any difference in speed with the wheel pants off and then installed ? thanks for your opinions. Bob and Toodie 4/1200
_________________ Keep the dirty side down/Blue skies. Bob |
Guy Buchanan
Posted: Fri Jun 03, 2011 9:02 am Post subject: Speed |
On 6/3/2011 7:05 AM, rtmarshall wrote: | Quote: | | These puppies' are really of rather dubious size and shape. All you speedster guys, did you see any difference in speed with the wheel pants off and then installed ? |
I'm not a Speedster guy, but my plane slows down about 5 when I put on the wheel pants. Of course, they were made for a DC-3, but they look COOL. (See photo.)
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
85.64 KB |
14417 Time(s) |
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
redrocketrider
Posted: Fri Jun 03, 2011 10:16 am Post subject: Speed |
[quote] Guy, As you say they are very cool, and that was what I suspected but wanted to hear it from a flyer. You have a great looking ship. Thanks for the info. Toodie and Bob
Sent: Friday, June 03, 2011 10:00 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Re: Speed
Guy Buchanan
Ramona, CA
pchristensen10(at)austin. Guest
Posted: Fri Jun 03, 2011 10:27 am Post subject: Speed |
Lookin Good!
Pete
Leander, TX
Kitfox III, 912, Grove
On 6/3/2011 12:00 PM, Guy Buchanan wrote: [quote] On 6/3/2011 7:05 AM, rtmarshall wrote: | Quote: | | These puppies' are really of rather dubious size and shape. All you speedster guys, did you see any difference in speed with the wheel pants off and then installed ? |
Guy Buchanan
Ramona, CA
cliffh(at)outdrs.net Guest
Posted: Fri Jun 03, 2011 6:15 pm Post subject: Speed |
I had wheele pants on my speedster but I took them off.
In my 58 years of flying, I have seen two airplanes laying on their backs because of wheel pants.
They took off with sleet on the runway and it froze while they were in the air. When they landed the wheels were frozen in the wheel pants and would not turn. It caused the airplanes to roll over on their backs.
Floran Higgins
Helena, Mt.
Speedster
912 ULS
VIXEN
Posted: Fri Jun 03, 2011 6:56 pm Post subject: Speed |
Hi Guys
I have a Model 5 long wing Vixen with 912UL. I have flown it for 100 hours always with wheel pants (spats, in some countries) and have had no issues. Always on pavement though. It cruises at 117 to 120 IAS. Maybe I will take them off and see what happens. I always thought they were supposed to "improve" speed.
Don
On Fri, Jun 3, 2011 at 7:12 PM, floran higgins <cliffh(at)outdrs.net (cliffh(at)outdrs.net)> wrote:
[quote] I had wheele pants on my speedster but I took them off.
Floran Higgins
Helena, Mt.
Speedster
912 ULS
Guy Buchanan
Posted: Fri Jun 03, 2011 7:30 pm Post subject: Speed |
On 6/3/2011 7:53 PM, Don Hudgeon wrote:
| Quote: | Maybe I will take them off and see what happens. I always thought they
Well, it certainly depends on the pants. Modern laminar flow pants only
marginally bigger than the wheels will dramatically reduce drag. Pants
like mine that are turbulent flow and four times the cross sectional
area of the tire don't reduce drag. (Especially with 1/2 the wheel
sticking out anyway!)
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
MichaelGibbs(at)cox.net Guest
Posted: Fri Jun 03, 2011 11:11 pm Post subject: Speed |
Mine must have been a better fit because when I installed the main
gear pants on my Model IV-1200 Nose-wheeled Speedster (shown here
without the nose wheel pant installed), I picked up something in the
neighborhood of 5-7 knots at cruise power.
Mike G.
Kitfox IV-1200 Speedster
Phoenix, AZ
only marginally bigger than the wheels will dramatically reduce
drag. Pants like mine that are turbulent flow and four times the
cross sectional area of the tire don't reduce drag. (Especially with
1/2 the wheel sticking out anyway!)
"My airplane is quiet, and for a moment still an alien, still a
stranger to the ground, I am home."
--Richard Bach
129.2 KB |
14394 Time(s) |
ronlee
Posted: Mon Jun 06, 2011 8:54 am Post subject: Re: Speed |
Wheel pants look very nice and work well if you have a speedy airplane. You will gain no utility with wheel pants on a bush that I can think of. By putting them on you will loose a nice place to sit, stand or put your foot on for what ever reason. If you are on rough ground they will shake and rattle around, not good on a bush plane.
Of course if we all thought alike it wold be a very boring world.
_________________ Ron Lee
Tucson, Arizona |
Paul A. Franz, P.E.
Posted: Mon Jun 06, 2011 10:29 am Post subject: Speed |
On Mon, June 6, 2011 9:54 am, ronlee wrote:
I have seen an alternative to complete wheel coverage over the top and that is just a
smaller trailing tailcone. I think something like this would allow you to use the tire
as a step and have most if not all of the streamlining gains of full pants. Having
nothing out in front of the tire would eliminate problems of hitting vegetation and
riverbank rocks. When the airplane tail tailwheel on the ground, there still wouldn't
be much ground clearance though.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
_________________ Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Fox5flyer Guest
Posted: Fri Jun 17, 2011 4:03 am Post subject: Re: Speed |
Ten years ago I installed wheel pants on my S5 and noticed an immediate speed improvement. Not a lot, but 3-5 mph at cruise which adds up and saves fuel. I have a farm strip that can be wet and somewhat muddy in the spring time which makes a mess of the airplane, thus the main reason I installed them. No more mess. I leave them on now year around. I don't fly in the winter time so snow and ice is not an issue.
Deke
NE Michigan
S5/Soob/465TT
[quote="redrocketrider"]Hi kitfox aviators ! Doing a extensive annual and wheel change and looking to possibly install a set of wheel pants that we now have. These puppies' are really of rather dubious size and shape. All you speedster guys, did you see any difference in speed with the wheel pants off and then installed ? thanks for your opinions. Bob and Toodie 4/1200
222.43 KB |
14283 Time(s) |
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Thu Aug 25, 2011 4:28 am Post subject: Re: Speed...Hey Gibbs! |
Hey Gibbs!
IS that craft of yours 912 powered?...if so..where did you get that cowl?..looks real nice. I am not far from replacing my mkIV speedster cowl..and would like to have something easier to see around.
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
