Recent pictures of N519RV (40250) and Weight and Balance
Ray.R.Doerr(at)sprint.com
PostPosted: Mon May 15, 2006 5:41 am    Post subject: Recent pictures of N519RV (40250) and Weight and Balance Reply with quote
            Here are a few recent pictures of N519RV (40250).  I also completed the W & B yesterday, which weighed in at 1587 lbs.
            Nose Wheel      369 lbs              Arm      49.82
            Right Main         609 lbs              Arm      123.82
            Left Main           609 lbs              Arm      123.69
            For the Weight and Balance, the gear leg fairings, wheel pants and intersect fairing were not installed.  The exterior of the plane in not painted, but the interior is complete with carpet interior panels all painted except the insides of the doors.
Thank You
Ray Doerr
40250 (N519RV)  (DAR scheduled for Mon May 22nd, First Flight scheduled for Fri May 26th)
 Filesize:  226.84 KB
 Viewed:  340 Time(s)
 Filesize:  247.56 KB
 Viewed:  352 Time(s)
 Filesize:  201.09 KB
 Viewed:  329 Time(s)
coop85(at)bellsouth.net
PostPosted: Mon May 15, 2006 6:02 pm    Post subject: Recent pictures of N519RV (40250) and Weight and Balance Reply with quote
Ray,
   Nice, clean looking interior.  Are the side panels painted aluminum sheet or vinyl  with snaps?   It’s kind of hard to tell by the pictures and I’m trying to firm up what I’ll be doing on the sides.
Marcus
JSMcGrew(at)aol.com
PostPosted: Tue May 16, 2006 6:35 am    Post subject: Recent pictures of N519RV (40250) and Weight and Balance Reply with quote
Ray,
Could you post the part # / where you bought your tow bar? Aircraft Spruce sells a bunch of them, but I'm not sure which one works with the RV-10
Jim
40134 Finishing kit / FW forward
In a message dated 5/15/2006 7:46:15 A.M. Mountain Daylight Time, Ray.R.Doerr(at)sprint.com writes:
Thank You
Ray Doerr
Jim "Scooter" McGrew
jsmcgrew(at)aol.com
PostPosted: Wed May 17, 2006 7:27 am    Post subject: Recent pictures of N519RV (40250) and Weight and Balance Reply with quote
            I made the panels from .020 aluminum sheets.
Thank You
Ray Doerr
CDNI Principal Engineer
Sprint PCS
16020 West 113th Street
Lenexa, KS 66219
Mailstop KSLNXK0101
(913) 859-1414 (Office)
(913) 226-0106 (Pcs)
(913) 859-1234 (Fax)
