plevyakh
Posted: Fri May 20, 2011 9:54 am Post subject: Looking for a smaller 5amp switch breaker |
Folks,
I'm using Bob's Low Cost Ground Power Jack for your airplane architecture. It calls out a Tyco W31X2M1G5 5 amp switch breaker for the Ground Power circuit.
I was hoping to include this switch breaker in my row of switches....but I have a depth clearance issue. The switch breaker is quite a bit more DEEP (2 1/8") than a standard S700 Carling series switch (1 3/16"), so it's hitting a fuselage cross cage tube before I can get my panel in place.
Is anyone aware of another 5amp switch breaker with similar profile to the S700 series switch that I could swap in place of the Tyco?
I could move the switch breaker to another location up on the far right side of the panel where my two alternator breakers are....but I'd like to keep the switches together if I can.
Thanks for any ideas.
Howard
_________________ Howard Plevyak
GlaStar / Cincinnati, Ohio |
jonlaury
Posted: Sat May 21, 2011 6:25 am Post subject: Re: Looking for a smaller 5amp switch breaker |
Howard,
Use the Carling switch of your choice and remote mount one of these:
http://www.wiringproducts.com/contents/en-us/d60.html
They're also available in modified reset where you have to cycle the switch.
Hope this helps.
John
