Posted: Tue May 17, 2011 9:31 pm Post subject: Board Soldering: Overheating and Cleaning? |
At 07:49 PM 5/17/2011, you wrote:
Hi!
I think I'd like to solder wires to the back of my transponder
board. Using the supplied edge card connector housing, I couldn't
get the contacts to lock into place. Instead, they'd move around
inside the housing. I figure I could cut these contacts off the ends
and solder the 24 awg wires directly to the board.
Before you solder wires to the board, how many
pins (ecb tabs) are on this connector. I presume
also that they are .156" spacing on centers of
the tabs (that was a common standard way back when).
There might be a better way.
Posted: Tue May 17, 2011 9:48 pm Post subject: Board Soldering: Overheating and Cleaning? |
| Quote: | --> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com>
Hi!
I think I'd like to solder wires to the back of my transponder board. Using the supplied edge card connector housing, I couldn't get the contacts to lock into place. Instead, they'd move around inside the housing. I figure I could cut these contacts off the ends and solder the 24 awg wires directly to the board. |
There might be a better way. I'm assuming you've got
12 upper and lower ECB tabs on a 1/16" thick board.
[img]cid:7.1.0.9.0.20110518014123.01db35d0(at)aeroelectric.com.0[/img]
Here's an AutoCAD plot that shows the alignment
(or lack thereof) for .156" ecb tabs and a 37-pin
d-sub connector.
You might be able to use a 37-pint, solder-cup connector
slid over the edge of the board. Note that every
ECB tab has at least ONE d-sub pin in a position
to be soldered to the tabs. There are a few d-sub
pins that fall between the ecb tabs and should
probably be totally removed from the d-sub connector
so as to reduce potential for shorting between ecb
tabs.
You might just luck out and have a relatively easy
transition from the ECB tabs to the very user friendly
d-sub technology.
50.18 KB |
8329 Time(s) |
rjquillin
Posted: Wed May 18, 2011 9:00 am Post subject: Board Soldering: Overheating and Cleaning? |
At 15:49 5/17/2011, you wrote:
Hi!
I think I'd like to solder wires to the back of my transponder board. <snip>
I've never soldered to a board, but imagine it's easier than the
cramped solder cups I've already done. Main questions are heat and
cleaning. I've got a 30W iron. How long can I leave a tinned tip on
the board before being concerned with overheating?
I also read a little about cleaning the board after soldering, cuz
of the flux. I'm using Kester 44 resin core. Should I wipe the board
with rubbing alcohol after I'm done?
Suggestions appreciated.
There is an excellent guide to soldered electrical connections from
NASA I sent to Bob a couple yeas back and he archived. Not sure of
the exact name it's stored as, but look for something like NASA
STD-8739.3. I find it difficult to imagine a hand soldering question
not addressed in that document, unless it pertains to SMD components.
Ethanol or Isopropyl are both accepted cleaners for common RMA fluxes.
| Quote: | Are the edge connector fingers gold plated? If so, it's doubtful
you'll even need flux.
When soldering to gold, NASA requires multiple 'tinning' operations
to remove the gold to prevent embrittlement of the joint.
Another commonly overlooked issue is moisture in the board, that,
when heated, turns to steam and causes delamination and bubbles; a
few hours in a warm to medium oven dries out the board.
Posted: Wed May 18, 2011 11:10 am Post subject: Board Soldering: Overheating and Cleaning? |
| Quote: | > There might be a better way. I'm assuming you've got
Thanks, Bob, except I've got 15 tabs on the bottom 3 or 4 on the top. At this point, since I've got all the pieces to do the direct soldering and D-Sub 15 connections, I'm leaning in that direction. Soldering the male pins to the board wouldn't be very easy either, since the metal shell would protect the pins from the solder tip. But if there was room to maneuver, it would make for a slick connection, all right. |
You got it backwards. What I proposed was converting
your card-edge male to a d-sub by soldering the wire-cups
of the connector to the tabs. Here is an example of a product
that uses solder-cup d-subs to bring the connections
off an ECB.
[img]cid:.0[/img]
[img]cid:.1[/img]
Like so.
112.79 KB |
8304 Time(s) |
119.26 KB |
8304 Time(s) |
messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Thu May 19, 2011 6:16 am Post subject: Re: Board Soldering: Overheating and Cleaning? |
| Quote: | | You got it backwards |
Doh!
| Quote: | There is an excellent guide to soldered electrical connections from
NASA |
Thanks! Here's a link I found:
http://www.hq.nasa.gov/office/codeq/doctree/NS87393.pdf
_________________ Dan |
messydeer
Posted: Fri May 20, 2011 6:51 am Post subject: Re: Board Soldering: Overheating and Cleaning? |
Yesterday I soldered the wires to the transponder board leaving them about 6" long, which I soldered to a female dsub 15. Also made up the mating male dsub. At first I tinned the board and wire ends then came back with the iron with a minimal bead of solder on the tip. It took only a couple seconds to solder them. I found it was difficult coming back to put more solder after this initial soldering to make a nice little mound over the wire. I found it worked better for me to put that extra solder on first, during the board tinning, so I wouldn't have to come back a second time. I scrubbed the contacts afterwards with a toothbrush and rubbing alcohol. It's not super pretty, but I'm happy with how it went.
Grounding
I also needed to run grounds from the transponder to the encoder on the EFIS and to the common ground buss. My solder cups aren't big enough to put more than one wire in. Instead of splicing the wires together, I recalled that Bob had jumped a bunch of dsub solder cups together by placing a section of wire between them and soldering it all together. I did that for 3 of the cups and connected ground wires from the transponder and encoder to this. I wanted a 20 awg ground from the encoder, but only had one spare 24 awg wire left over in the cable. I used a 22 awg along with this 24 awg wire for this. Diagram below.
38.23 KB |
8271 Time(s) |
