dcw(at)mnwing.org Guest
Posted: Fri May 12, 2006 4:59 pm Post subject: Lightspeed EI installation |
Fellow Listers:
I am into a major project installing a dual Lightspeed Ignition system in my
flying RV-4. It will be using the direct crank sensor installation. This
project is just about done and I am beginning to do some preliminary tests
are stated in the LSI manual. I have run a magnetic across the sensors on
both systems on the direct crank sensor circuit board and the coils fire
fine across their terminals.
Here is my question. I have carefully measured the calculated clearance
between the sensors on the circuit board and the small magnets which are
installed in the ring gear (I had LSI install them so I assume they are in
the correct position). I have been trying to see if I can get the coils to
fire my temporarily positioning the starter ring gear and moving the engine
through TDC. No luck in getting them to fire. Now I don't know if this is
a valid test. I assume I am moving the ring gear fast enough through the
sensor positions but it is hard to say.
For any of you that have installed the LSI system with the direct crank
sensor, did you have any issues like this?. Or did you put it together and
it just ran??
Doug Weiler
N722DW, 290 hours
alexpeterson(at)earthlink Guest
Posted: Fri May 12, 2006 5:21 pm Post subject: Lightspeed EI installation |
| Quote: | Here is my question. I have carefully measured the
calculated clearance between the sensors on the circuit board
and the small magnets which are installed in the ring gear (I
get the coils to
moving the engine through TDC. No luck in getting them to
fire. Now I don't know if this is a valid test. I assume I
am moving the ring gear fast enough through the sensor
direct crank sensor, did you have any issues like this?. Or
did you put it together and it just ran??
Doug Weiler
N722DW, 290 hours
Doug, are you moving the ring gear back and forth? The sensor needs to see
two magnets within .5 seconds in order to fire.
Alex Peterson
RV6-A N66AP 752 hours, with my own magnet issues with the Lightspeed
installation
Maple Grove, MN
dan(at)rvproject.com Guest
Posted: Fri May 12, 2006 5:33 pm Post subject: Lightspeed EI installation |
You need to rotate the prop (or flywheel) somewhat quickly to get it to
fire. I suspect the issue you're seeing is that you're not moving it
quickly enough. My experience with my Plasma II was that if you don't
rotate the prop/flywheel quickly enough during the phase test, you won't see
the coils firing.
Otherwise, Klaus should be able to help you. Give him a call on the
phone...contact info at the bottom of this page:
http://www.lightspeedengineering.com/
Where are you located? If you're anywhere near SoCal I could probably give
you a hand.
)_( Dan
RV-7 N714D (901 hours on a Plasma II)
http://www.rvproject.com
Posted: Sun May 14, 2006 3:17 pm Post subject: Lightspeed EI installation |
the coils firing.
you a hand.
Thanks for the offer Dan, except I am way out here in Minnesota. I think
you are right and affirmed by Alex that rotating the ring gear by hand won't
do it. I'll proceed and check everything as instructed and hopefully it
will fire up when finished.
Doug
mstewart(at)iss.net Guest
Posted: Mon May 15, 2006 3:36 am Post subject: Lightspeed EI installation |
Doug.
Recommend you read this thread for gapping the direct crank pickup .
http://www.vansairforce.com/community/showthread.php?t7688
Best,
Mike
Fellow Listers:
in my
This
tests
on
in
coils to
engine
is
the
and
it just ran??
Doug Weiler
N722DW, 290 hours
