wb2ssj(at)frontiernet.net Guest
Posted: Sun May 15, 2011 8:24 am Post subject: flap motor |
Steve Biele, I just got your Email and want to let you know I am still investgating the situation. I have been using 30 degrees of flap on landing which seems ok. I will be starting my anual in july and will try to determined the cause. I will be looking at the hole in the fuse to see if the flap arm is riding on the top side of it which at high speed which could be binding it. Will keep you posted. TEX
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
n5pb(at)AOL.COM Guest
Posted: Mon May 16, 2011 1:20 pm Post subject: flap motor |
Tex,
Keep me in the loop too as i'm experiencing the same.
Bear
N82PB
info(at)flylightning.net Guest
Posted: Tue May 17, 2011 8:06 am Post subject: flap motor |
I guess I missed the original post. Would someone fill me in.
nick
Posted: Tue May 17, 2011 1:37 pm Post subject: flap motor |
I gues about 3 months or so the was a thread about the flap motor not being able to extend the flaps all the way down.
I had a side bar with you about a month before that and you thought we just need to put in a heavier (more powerful) motor.
I think Tex was going to do some experimentation with it.
Like his mine goes to 30 degrees without any problem, but seems unable to retract the flaps all the way no matter what approach speed I use. on the ground there's no issue...
Bear
Posted: Tue May 17, 2011 2:03 pm Post subject: flap motor |
Ok,
Now I am filled in. We had gone to less flap travel some time ago, for several other reasons including this one. Yes there is a motor available with about twice the rated torque as the current one.
This could be an option.
Nick
LIGHTNING AUSTRALIA
Joined: 02 Dec 2008 Posts: 11 Location: Kingston SE AUSTRALIA
Posted: Tue May 17, 2011 3:55 pm Post subject: flap motor |
Nick we have been trying to get this info, for this heavier duty flap motor for some time now for one of our customers, but no one seems to be able to find it. Mark has certainly tried.
Dennis Borchardt. Lightning Aircraft Australia
Sent: Wednesday, May 18, 2011 7:31 AM
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Subject: RE: flap motor
Ok,
Nick
-----Original Message-----
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of n5pb(at)aol.com
Sent: Tuesday, May 17, 2011 4:35 PM
Subject: Re: flap motor
Bear
To: lightning-list <lightning-list(at)matronics.com>
Sent: Tue, May 17, 2011 12:06 pm
nick
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com ([email]owner-lightning-list-server(at)matronics.com?[/email])] On Behalf Of n5pb(at)aol.com (n5pb(at)aol.com)
Sent: Monday, May 16, 2011 4:18 PM
Tex,
Bear
N82PB
From: Tex Mantell <wb2ssj(at)frontiernet.net (wb2ssj(at)frontiernet.net)>
To: lightning-list <lightning-list(at)matronics.com (lightning-list(at)matronics.com)>
Sent: Sun, May 15, 2011 12:24 pm
Subject: flap motor
0123456
789012
3456789 | Quote: | | p://forums.matronics.com | 0 | Quote: | | p://forums.matronics.com | 1 | Quote: | | p://forums.matronics.com | 2 | Quote: | | p://forums.matronics.com | 3 | Quote: | | p://forums.matronics.com | 4 | Quote: | | p://forums.matronics.com | 5 | Quote: | | p://forums.matronics.com | 6 | Quote: | | p://forums.matronics.com | 7 | Quote: | | p://forums.matronics.com | 8 | Quote: | | p://forums.matronics.com | 90123456
7
NowackLinden(at)gmx.de Guest
Posted: Tue May 17, 2011 10:20 pm Post subject: flap motor |
Nick,
could you please publish the A/C Spruce number of the stronger flap motor in case they sell it?
Or where else to get it?
Or can I buy one from Arion?
Gerd
Am 18.05.2011 00:01, schrieb flylightning: [quote] <![endif]--> Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]-->
Ok,
Nick
Posted: Wed May 18, 2011 5:11 am Post subject: flap motor |
Ok, I will get it for you I know where it is.
Nick
selwyn
Posted: Fri May 27, 2011 7:57 pm Post subject: Re: flap motor |
Seeing as this topic seems to have stalled again, must be some sort of flap motor disease , I offer the following:
http://products.danahermotion.com/v41/Advisor.asp?User=Actuators_Linear
These are what appears to be the source of the original flap motor which is an Electrac 1. The Electrac 2 series offer more thrust but the package is larger and the travel speed lower. The D1210A5 model seems to be in the ballpark for thrust and it has a limit switch option, as per the current unit, and a potentiometer option which would be useful for flap indicator or control systems. The motor end is roughly 76 by 148 mm compared to the existing 40 by 73 mm so space may be an issue, I have not checked at all.
Hope this provides some useful clues.
_________________ Cheers, Selwyn
Kit 66 VH-ELZ |
selwyn
Posted: Sun Jun 12, 2011 12:51 am Post subject: Re: flap motor |
A bit more checking on this and there seems to be another candidate in this range. This is the PR12-02-2A65 model family.
http://products.danahermotion.com/v41/ModelDetail.asp?User=Actuators_Linear&PkgOrder=542
This offers a 250 lb force and a number of options including one which would be very useful for the flap system.
"Position follower input provides the possibility to make the extension tube position follow the setting of a customer provided trim potentiometer"
I could see this providing a "dial the flap setting" control instead of having to hold the finger on the switch. To get the detailed dimensions you need to download the catalogue from the downloads tab on the product spec page.
Kit 66 VH-ELZ |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
