Need Parts
rcdettmer(at)charter.net
PostPosted: Sat May 14, 2011 7:15 am    Post subject: Need Parts Reply with quote
Hello Commander Colleagues,
My 680F is almost complete with its annual inspection, however we are in need of some parts that are being elusive. Can anybody help out with the following parts..??
Fitting Assembly (rudder bracket on tail) No. 541000S-119
Nitrogen pressure gauge (gear blow down system) No. 2850186
Oil Access Door (to check and add oil) No. 5260020-223
Fuel Sump Drain Valve No. 475C-45WP
Thanks very much. Your assistance is greatly appreciated.
Randy Dettmer, AIA, NCARB
680F / N6253X
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
 Filesize:  2.9 KB
 Viewed:  1787 Time(s)
LLOYDSSS11(at)MSN.COM
PostPosted: Sat May 14, 2011 6:03 pm    Post subject: Need Parts Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> RANDY, IF THE GAGE IS THE SAME AS THE ONE ON A 500B (MARKED AT 350 LBS),
THEN NORTH EAST AIR IN PORTLAND MAINE QUOTED ONE ABOUT 6 MONTHS AGO.
I HOPE YOU ARE SITTING DOWN !!! LIST PRICE WAS $1200.00. INSANITY FOR A PART
WORTH $25.
 Filesize:  2.9 KB
 Viewed:  1781 Time(s)
