Erich_Weaver(at)URSCorp.c Guest
Posted: Tue May 10, 2011 9:17 am Post subject: lithium batteries |
I would like to hear your Bob's or other folks comments about aviation use of the lithium batteries supplied here:
http://www.lithiumaviationbattery.com/index.html
they seem to offer signficant weight reduction
thanks
Erich Weaver
jan_de_jong(at)casema.nl Guest
Posted: Tue May 10, 2011 9:45 am Post subject: lithium batteries |
This has been discussed two months ago: see archives "Shorai".
I don't think I could add anything.
Jan de Jong
mike(at)aeromotogroup.com Guest
Posted: Tue May 10, 2011 2:57 pm Post subject: lithium batteries |
I asked a similar question a few months back on the Lancair Mailing List and
was insulted for suggesting LiFePO4 batteries even be considered for
experimental aircraft use. At the time I was not aware of anyone selling
them specifically for aircraft, so that's an interesting new development.
Below, I share the tactful wisdom of Mr. Regan for the benefit of all.
Michael
"Michael writes: <<I never claimed to be an expert>>
Then perhaps you would be wise to take the council of someone who IS
experienced.
<<The SECOND link in my post is a thread with several hundred posts on
designing, building, and testing cells. Have any of the naysayers read the
thread, in depth, or done similar research? >>>
Wow. Reading the anecdotal results of anonymous hobbyists is not "research",
it is entertainment (for some). Reading about or doing actual experiments
with the appropriate equipment and collecting reliable and repeatable data
is research. My income depends on doing quality R&D so I appreciate the
danger of searching the internet for data that supports your position and
then taking that as evidence you are right. You can find supporting
information for ANY position on the internet.
<<< I also have read <snip> that deep discharging, such as Hamid had done,
is different than the minimal discharge we would expect from an engine
start. The small discharge contributes to less need to balance the cells.
Quite different from the total-loss system in an RC or solar-powered
environment.>>>
Wrong, wrong and wrong.
The Wave Glider had a 10 -30 day (depending on payload power) "no sun"
duration so it was a mixed cycle, not deep discharge.
Engine start is not a minimal discharge event. A 300 amp load for 30 seconds
represents about a third of the available energy at those rates from a
typical 20 AH battery. (careful, I set a trap here)
Cell imbalance is a function of the number of charge / discharge cycles, the
depth of discharge / charge, the rate of discharge / charge, the
temperature, and cell initial "matching". If you start with matched and
balanced cells it will take longer to require balancing. Rate is one of the
more important factors because it also effects temperature due to I^2R
losses. Double the current and you get four times the heat.
<<<I'm an experimenter. I can't just sit on the sidelines and wait for
"someone else" to do the research, testing and development, then jump on the
bandwagon. That's why I'm building an experimental aircraft. I thought
this forum would be a good place to discuss development and testing of new
systems rather than quickly declare it "too risky" for intelligent
discussion.>>>>
I am all for experimentation, just not at 10,000 feet with peoples lives at
stake. I have been a contributor on this list since the beginning and I have
assisted the NTSB with several accident investigations where people died
because the pilot ignored fact in favor of their own "opinion". Flying is
serious business. Lithium batteries are sensitive to mishandling. Neither
tolerates ignorance or arrogance well.
Lithium batteries can and have been used in aerospace applications
successfully but it requires a careful, detailed and intelligent design to
mitigate the risks to an acceptable level. The risk levels that can be
tolerated for an EV motorcycle or car are significantly higher than for a
manned aircraft.
The word "Experimental" in Experimental Aircraft is not a directive to take
foolish risks. It does mean that you and you ALONE, as a pilot and builder,
are responsible for operating AND building an aircraft that is SAFE.
If I am not "intelligent" for pointing this out, so be it.
Brent Regan"
Posted: Tue May 10, 2011 4:34 pm Post subject: lithium batteries |
At 01:13 PM 5/10/2011, you wrote:
Yes, among other things. Quoting from the website:
If your reading this; you already know that the primitive lead acid battery is going the way of the horse and buggy.
. . . yeah . . . sort of.
I can tell the List that there are a whole lot of folks
intently interested in exploring alternatives to the
legacy lead-acid battery technologies for a host
of applications, not the least of which are aircraft.
I've been indirectly and directly involved in battery
studies for general aviation for over 10 years . . .
and I can tell you nobody at any of my former places
of employment are looking to go lithium as the standard
battery product . . . yet.
A variety of new-wave technologies have come and gone.
Some proved useful in certain specialty applications
such as portable power for computers, cameras, phones,
etc. Most of these applications did not demand hi cranking
currents to start engines nor were they expected to
work at cold temperatures. Further, in small energy
demand applications, the extra electronics needed to
optimize battery performance was not a big cost of
ownership burden. Looking at the website we see the
following data table:
BATTERY SIZING - 12V & 24V
Based on your starter cranking current.
Rectangular Dimensions
Ah Wt./lb CCA w heat shrink cover $$ (12V )
2p, 4.6 1.7 200 4.5 x 2.2 x 3.3 200
3p, 7.0 2.3 300 4.5 x 3.5 x 3.3 300
4p, 9.2 3.0 400 4.5 x 4.8 x 3.3 400
5p, 11.5 3.5 500 4.5 x 6.0 x 3.3 500
6p, 13.8 4.0 600 4.5 x 7.2 x 3.3 600
7p, 16.1 4.5 700 4.5 x 8.4 x 3.3 700
I see no mention of battery selection criteria based
on a load analysis for the endurance mode of operation.
Keep in mind that there have been several "gee-whiz" battery
offerings in the past that would crank an engine. I think
some products featuring 2 a.h. jelly-roll NiCd technology
about the size of a c-cell.
The product even made it into the over the counter market in
the form of a "Start Stick" sold by Sears as I recall.
Cranking the engine is a concern only for the first
few seconds of the day's operations. How about the rest
of the time?
A minimum battery that would crank your Lycoming might
weigh in at 3 pounds and cap check at 9.2 a.h., but how
long would that battery run your e-bus? Okay, you've got
Z13/8 and the endurance loads are not an issue. How many
18 a.h. SLVA batteries can you buy for $400? Let's say
5 batteries. In a situation where the e-bus is supported
by a second alternator, then you might get 2-3 years
service life out of an SVLA. Let's say 2 years x 5 batteries
gives you 10 years. The cost of ownership for 5 batteries
is equal to that of 1 Lithium battery that has a warranty
of 5 years and is a somewhat unknown player in the market
when 10 years is the target service life.
Okay, it's 15 pounds lighter than the SLVA. That's 2.5
more gallons of fuel. Are you going to fit your airplane
with larger tanks? Probably not. Okay, no help on fuel.
Are you going to miss that 15 pound reduction in baggage
limits? Hmmm . . . at 10 gph you'll be back under gross
limits in 15 minutes after takeoff . . . doesn't seem
like much of a worry there either.
Suppose you don't have the second alternator and you
really want 12+ a.h. of endurance bus support for
alternator-out ops. Now we're talking about a $600-
$700 battery. That will buy a LOT of SLVA capability.
How about service life? At least with the SLVA, you're
starting with a clean slate every two years. You're
COMMITTED to living with the lithium product for a
whole lot longer than that.
The point is that until one has considered ALL the
data points that drive a battery selection decision,
getting sucked down the whirlpool of lighter, stronger,
sexier, etc. etc. may keep you from making good decisions
that tend to ditch proven technologies with no surprises
and very predictable cost of ownership numbers.
If you're selecting a battery for Voyager, it took about
5 pounds of fuel to carry 1 pound of airplane around the
world. So 15 pounds of battery would translate to 75 pounds
of fuel. Uncle Bert MIGHT have been interested in the
Lithium products back then. I suspect that once the RV
builder has considered issues of weight, endurance mode
support, cost of ownership over the LIFETIME of the
airplane, and cold weather ops . . . that stoggy ol'
SVLA still has a few things going for it.
Yes, these are experimental airplanes. The owners of
[img]cid:.0[/img]
are out to show the world a 'better mousetrap' and I do
wish them well. But if I were flying an RV, I'd do it to
have fun while minimizing cost of ownership and meeting
specific design goals. Please make sure ALL of your goals
are identified, prioritized and considered in your battery
selection decisions.
It may well be that 10 years from now, everybody will
be scoffing at the occasional SLVA hanger-on. I hope
that the technology and market positions will have matured
sufficiently to make that a reality. But that's not today
folks.
35.21 KB |
2992 Time(s) |
Posted: Tue May 10, 2011 5:04 pm Post subject: lithium batteries |
At 06:53 PM 5/10/2011, you wrote:
<mike(at)aeromotogroup.com>
Michael
Brent's misgivings about lithium aboard airplanes are
well founded. There IS a TSO document in place for
FAA approval of lithium batteries. It's based in part
on performance we've come to know and love from lead-acid
technologies. At the same time, it acknowledges
elevated risks for what I've suggested is akin to
teaching your Lycoming to burn nitroglycerine. The
energy content is spectacular but the firewalls needed
to keep that dragon caged are significant.
We didn't have battery fires until the wet Ni-Cad
came along. Those dragons proved meddlesome too but
were eventually brought to heel. Integration of
lithium into the every day lives of the consumer-citizen
will be an even greater challenge.
