Door wedges???
AirEupora
PostPosted: Thu May 05, 2011 4:57 pm    Post subject: Door wedges??? Reply with quote
I have been looking at some of the things people have done for the bulging doors. I had mine installed real nice then I installed new door locks. I had to pull off the Cabin width MOD from inside the door. I put the locks on and glued the MOD panel back in place. The wrong thing to do. Then installed my window. I should of placed in back on the fuselage so it would take that shape.
I now have a bulging door. Mal Maclure apparently made some wedges that help. Anybody know how to do the wedges?
Rick Stockton
N120EJ
A210 95%
tonyrenshaw268(at)gmail.c
PostPosted: Thu May 05, 2011 5:15 pm    Post subject: Door wedges??? Reply with quote
Kingsley Hurst does. He is pretty busy at the moment, but I'll try and flush him out of hiding. As I recall it was interlocking triangular wedges. The door "FRAME" one, midway along the bottom horizontal edge has its vertical face inwards, and a reciprocal one on the outside of the door has its vertical face outwards. He simply pulled the door in at the bottom of its travel, mated the two surfaces, and then eased the door down, then shut it. They were only small, about 8 mm high, as I recall, but I saw them about 10 years ago. Kingsley has seen them more recently.
Now, can someone tell me why the door tangs don't finish square with the hinge line??
Reg
Tony Renshaw
On 06/05/2011, at 10:57 AM, AirEupora wrote:
I have been looking at some of the things people have done for the bulging doors. I had mine done real nice then I installed new door locks. I had to pull off the Cabin width MOD from inside the door. I pull the locks on and glued the MOD panel back in place. The wrong thing to do. Then installed my window. I should of placed in back on the fuselage so it would take that shape.
rick Stockton
N120EJ
A210 95%
http://forums.matronics.com/viewtopic.php?p=339054#339054
rparigoris
PostPosted: Thu May 05, 2011 7:07 pm    Post subject: Re: Door wedges??? Reply with quote
Hi Rich
I made some stainless pin and strikers for center of door. Easy to do and works great. Details on page 3:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=29082&g2_page=3
I opted to leave gas strut in original position and install a pin and striker in upper aft area. Probably on page two and three. Works well along with CF stiffening. When you close door it pushes down on the upper aft portion of the door!
Tangs can't be parallel with hinge line because of curvature of fuse.
See page 1, 2 and 3 for mutilation of that area with great results and minimal gap.
Ron Parigoris
kingsnjan(at)westnet.com.
PostPosted: Thu May 05, 2011 9:35 pm    Post subject: Door wedges??? Reply with quote
the wedges?
Rick,
I haven't had any problems with my doors but I made the attached auxiliary
latchs for the doors because it seemed a good idea at the time.
They are made of Tufnol and are 25mm long. If Neville Eyre is lurking . .
they are 1" long.
Note that the door part latches over the sill part on the inside face.
Hope this helps
Kingsley
 Filesize:  45.64 KB
 Viewed:  7862 Time(s)
 Filesize:  38.75 KB
PostPosted: Thu May 05, 2011 9:43 pm    Post subject: Door wedges??? Reply with quote
hinge line??
Because this was left as an exercise for the builder !! IOW, the factory
stuffed up.
They can't be square with the hinge line Tony but the geometery can be
corrected. See attached.
Kingsley
 Filesize:  56.39 KB
 Viewed:  7861 Time(s)
 Filesize:  55.34 KB
fklein(at)orcasonline.com
PostPosted: Fri May 06, 2011 7:54 am    Post subject: Door wedges??? Reply with quote
<Sill part.JPG><Door part.JPG>
Kingsley...for the life of me, I can't get my mind around what you've done and how it keeps the door from bulging out...Could you help orient me to your photos #1 and #2?
Fred
grahamsingleton(at)btinte
PostPosted: Fri May 06, 2011 9:15 am    Post subject: Door wedges??? Reply with quote
Fred
the door flexes enough to let the wedges slide over each other and latch. When the shoot bolts are engaged the door can't flex so
it won't bulge out and suck your sleeve into the gap. I was flying one hot day and had the vents open and couldn't work out who was tugging at my sleeve at 4000 ft.!
Graham
Sent: Friday, 6 May, 2011 16:50:04
Subject: Re: Door wedges???
Fred
http://www.matronics.com/Naviet="_blank" href="http://forums.matronics.com">http://forums.matronics.->
AirEupora
PostPosted: Sat May 07, 2011 7:30 am    Post subject: update - Door wedges??? Reply with quote
I took some clay to see if I could make the wedges and figured out that I had put the wide MOD 67 panel on wrong. It was off center. So I took it off to re-center. I had to do some fiberglass repairs as this was the second time I had installed and removed it. Because of the wide MOD 67 the door is weak in the middle and you can see it bowed there. I took a piece of aluminum angle on the outside and was thinking of heating it up and determined that I needed more strength in this area. I laid three layers of one inch tape and shaped it into an ā€œLā€ around a aluminum angle inside the door area above the lower lip. I made it about 18 inches long. I believe that will straighten the door in this area. I will be added some more fiberglass to the cut out areas from the wide MOD 67. I'll let you know the results in a few days.
PostPosted: Sun May 08, 2011 9:09 am    Post subject: Door wedges??? Reply with quote
Sorry if I confused you Fred . . . . I hope the attached will be easier to follow.
Bear in mind my honourable friend, I don't know if I really needed these devices but I did them anyway if for no other reason than to satisfy my determination to take 20 yrs to build the aircraft !!
Cheers
Kingsley
Aux_Latch.pdf
 Filename:  Aux_Latch.pdf
 Filesize:  28.44 KB
 Downloaded:  437 Time(s)
PostPosted: Sun May 08, 2011 9:42 am    Post subject: Door wedges??? Reply with quote
Excellent sketch Kingsley. 20 years? I needed 4 years to build my Long EZ, then it took another 15 to refurbish it and fit another engine. (NO, not a twin!)
Graham
Sent: Sunday, 8 May, 2011 3:53:30
> Kingsley...for the life of me, I can't get my mind around what you've done and how it keeps the door from bulging out..Could you help orient me to your photos #1 and #2?
Cheers
Kingsley
PostPosted: Sun May 08, 2011 1:04 pm    Post subject: Door wedges??? Reply with quote
Kingsley,
Your sketch saved (at least) 1000 words...thank you.
I was having trouble orienting my mind to your photos, and I'd fixed
in my mind the notion that the chamfers were relevant.
Fred
