Connectors for small diameter 'coax" wires
harvey4(at)earthlink.net
PostPosted: Fri Apr 29, 2011 3:51 pm    Post subject: Connectors for small diameter 'coax" wires Reply with quote
I know about the existence of connectors for RG0400-like coax cables, but are there similar connectors for small diameter wires like 18AWG shielded Tefzel wires? I hate the resulting "lump" in the wire when I try to connect shield and core wires using butt-splice connectors, and the shrink-wrap never seems to contract nicely around the wires afterwards.
Thanks for ideas.
Neil
mrspudandcompany(at)veriz
PostPosted: Fri Apr 29, 2011 4:34 pm    Post subject: Connectors for small diameter 'coax" wires Reply with quote
Thanks for ideas.
Neil
If the lump in the wire bothers you, then the best method of
connecting two wires is to solder them, there is a good tutorial in the
Aeroelectric Connection. Be sure to use a shrink tubing size just large
enough to pass over the wires and the soldered connection. If shrink tubing
of too large size is used, it will, in fact, not shrink down to the wire for
a nice neat joint.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.67 KB
 Downloaded:  457 Time(s)
