tc1234c(at)roadrunner.com Guest
Posted: Thu Apr 28, 2011 2:56 am Post subject: Fire and off field landing |
I thought I owe you, my fellow RV-10 builder some information. At this
point the plane is still sitting in the field and I have been spending
the time doing statements and answering inquiries from friends. Without
opening the tunnel and cowling I can not say for sure what happened.
Here are my observations:
a. Fire was limited to the tunnel.
b. It is a fuel leak inside the tunnel that fed into the fire.
c. Fuel has been leaking some time before the fire started on this
particular flight (based on the high fuel flow). Fuel flow was normal
when I taxied out and on the take off.
d. The smoke thinned out soon after I jettisoned the door. Although I
still did not have much in-flight visibility, by the time the airplane
stopped the cabin was almost cleared of smoke.
e. There is no time to think. When my right leg felt warm I banked
quickly and put it on the ground soon.
f. After I turn off the fuel (it did shut off) there were still small
fire but limited to inside the tunnel.
g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool
boxes in my baggage compartment to keep the CG in the limit (my W&B
requirement).
h. I have not calibrated my stall warning system. The buzzer goes off at
around 60 kts. So, it was not a full stall landing. The field slopes up
and I had a three point.
i. Don't rely on emergency checklist. Remember the important steps and
just do it. There is no time and visibility to find the checklist.
Some facts:
a. There is no modification on my fuel system.
b. The door is still good except the area where bolts go through. It is
the quickest way to get ride of the smoke and get visibility from the
opening.
c. The fire damage seems to be limited to around tunnel and firewall. I
do have insulation inside the tunnel floor and up on firewall.
d. Propeller strike and powder fire extinguisher from the fire
department probably caused more damage than the fire.
I have to admit that for a few seconds when the smoke came out and my
leg felt the heat I had a thought that I was in deep trouble (burn to
death). I quickly focused on the tasks in front of me and tried to fly
the airplane and solve the problems I was facing. From that point on
there was no fear or regret. After I called 911 and my insurance agent
I got to walk down the hill, wait and think. My only negative thought
was that my accident might negatively impact a lot of builders. I don't
want to see anyone get disencouraged. I am pretty sure that what
happened to me is not a design flaw, but a builder mistake. After I
found the problem I will share with you so you can avoid this problem.
Ted
kearney
Posted: Thu Apr 28, 2011 5:02 am Post subject: Fire and off field landing |
Ted
Thank you for your candour and willingness to share whatever can be learned
from your accident. Everyone one the list is relieved that you came out okay
on this.
Les
amekler
Posted: Thu Apr 28, 2011 5:03 am Post subject: Fire and off field landing |
Ted,
Thank you for the summary. I think you did a great job getting the plane on the ground without personal injury.Your story makes me want to get a smoke hood for my flying.
Alan
requirement).
Some facts:
opening.
Ted
tp%3A%2F%2Fwww.matronics.com%2FNavigator%3FRV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-List
tp%3A%2F%2Fforums.matronics.com" target=_blank>http://forums.matronics.com
tp%3A%2F%2Fwww.matronics.com%2Fcontribution" target=_blank>http://www.matronics.com/contribution
amekler
Posted: Thu Apr 28, 2011 5:11 am Post subject: Fire and off field landing |
Ted and RV-10,
Just found this link to smoke evac hoods.
http://www.avweb.com/news/safety/cockpit_smoke_hoods_197712-1.html
Alan Mekler
n668g
requirement).
Some facts:
opening.
Ted
rleffler
Posted: Thu Apr 28, 2011 5:12 am Post subject: Re: Fire and off field landing |
Ted,
Thanks for sharing your experiences and thoughts!
The community will be better from learning from your experience.
If you need any help, let me know. I'm only a couple hours away.
bob
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
jfrjr(at)roadrunner.com Guest
Posted: Thu Apr 28, 2011 6:25 am Post subject: Fire and off field landing |
You are a good man Ted Chang--glad you are still with us. Jay Rowe #301
---- Ted Chang <tc1234c(at)roadrunner.com> wrote:
requirement).
Some facts:
opening.
Ted
dlm34077(at)q.com Guest
Posted: Thu Apr 28, 2011 6:43 am Post subject: Fire and off field landing |
donning it is the problem; I have smoke hood but not quick donning type, so unless the AP is flying the hood won't happen.
dave.saylor.aircrafters(a Guest
Posted: Thu Apr 28, 2011 7:02 am Post subject: Fire and off field landing |
Hi Ted,
Thanks so much for your report. Great job!
One thing I'm wondering about is whether you remember using the flaps
at the time the fire started. There's been some discussion about the
flap motor as an ignition source.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, Apr 28, 2011 at 3:53 AM, Ted Chang <tc1234c(at)roadrunner.com> wrote:
I thought I owe you, my fellow RV-10 builder some information. At this point
jjessen01
Posted: Thu Apr 28, 2011 7:42 am Post subject: Fire and off field landing |
So very happy you made it through this event, Ted. Great job!
John J
Posted: Thu Apr 28, 2011 8:34 am Post subject: Fire and off field landing |
Thanks for the info Ted. I've had two off-field landings ..... engine
related .... and there's no real way of knowing how you will react to an
emergency until you really do have one. Your reactions appear to be
excellent. Without knowing anything about you, you've got my respect
(for what that's worth!).
I'm counting two RV-10 tunnel fires so far. the first one was destroyed
so no definitive info (that I have) emerged. Your investigation will be
valuable to the rest of us builders.
I have two questions:
1) Where did the fuel escape from the system?
2) What was the ignition source?
If you can answer those, you'll give a lot of builders more sleep at night.
To echo the many other comments .... I'm glad the outcome was
successful. The plane can be repaired.
Linn
On 4/28/2011 6:53 AM, Ted Chang wrote:
Without opening the tunnel and cowling I can not say for sure what
happened. Here are my observations:
requirement).
at around 60 kts. So, it was not a full stall landing. The field
slopes up and I had a three point.
Some facts:
is the quickest way to get ride of the smoke and get visibility from
the opening.
I do have insulation inside the tunnel floor and up on firewall.
agent I got to walk down the hill, wait and think. My only negative
thought was that my accident might negatively impact a lot of
builders. I don't want to see anyone get disencouraged. I am pretty
sure that what happened to me is not a design flaw, but a builder
mistake. After I found the problem I will share with you so you can
avoid this problem.
Ted
aerosport1
Posted: Thu Apr 28, 2011 9:01 am Post subject: Fire and off field landing |
Ted glad you are ok. Great job. Let me know if I can help.
Geoff Combs
N829GW
Sent from my iPhone Geoff
On Apr 28, 2011, at 12:29 PM, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Thanks for the info Ted. I've had two off-field landings ..... engine related .... and there's no real way of knowing how you will react to an emergency until you really do have one. Your reactions appear to be excellent. Without knowing anything about you, you've got my respect (for what that's worth!).
I'm counting two RV-10 tunnel fires so far. the first one was destroyed so no definitive info (that I have) emerged. Your investigation will be valuable to the rest of us builders.
To echo the many other comments .... I'm glad the outcome was successful. The plane can be repaired.
Linn
> I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations:
> c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off.
> d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke.
> e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon.
> f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel.
> g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement).
> h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point.
> i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist.
> Some facts:
> b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening.
> c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall.
> d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire.
> I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem.
> Ted
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
AV8ORJWC
Posted: Thu Apr 28, 2011 11:07 am Post subject: Fire and off field landing |
Ted - several of your actions are Commendable. #1 you flew the aircraft
to the landing site and walked away. The remaining builders and your
underwriter should be appreciative. #2 You were willing to share and
encourage other builders with the facts, when known. - Invaluable! #3
You removed your EFIS screens and took steps to protect the residual
value of what looks like a repairable incident. Thank you.
Several questions came immediately to mind after considering those
actions. Condition of Aluminum fuel tubing, flares and fittings? Fire
Annunciation & Suppression systems? What would or could have happened
if the tunnel had been composite rather than aluminum? Smoke evacuation
and hoods. All will come out in time. This incident is the second most
valuable RV-10 incident since the loss of Dan Lloyd and much will be
gained from the post incident review.
What comes to my mind is I seem to remember Scott Schmidt (#40111) as
the first builder to provide side access panels to reach/inspect to the
maze of tubing and to service fuel filters. I reflect on DLM (#40168)
and his Halon (non dry powder) onboard suppression system. I now
reflect on the comment of lowering the inherent pressure in the tunnel
and venting fumes/smoke to the outside atmosphere and will await the
flap switch query. Your Picasso pictures are stunning! Glad your around
to share.
Your summation should be reviewed by all builders.
No modification to the VANS system.
Limiting fire damage is critical.
Fuel shutoff worked, as advertized.
Your prop strike damage was that to just the "now needed" engine
teardown or did it migrate into your avionics?
As a Tech Advisor, no one wants to hear from us how often we find flares
on tubing incorrectly manufactured or improperly torqued (under and
over). Many builders have not added the test of their "Shutoff Valve to
cut engine operation" and confirm continued function at each conditional
inspection. This drives that action home. I am thrilled that you are
reporting and I look forward to more news of the landing gear mounts,
legs and what you find. I am willing to kick-in $100 for a N718PF Chang
Relief Fund, cause your data will be worth far more than that to current
aviators, current builders, future builders and loved ones. If I could
bring Dan back I would spend even more.
Geoff can you weigh in on steps that can be applied to mitigate flame
damage to a composite tunnel under similar circumstance? Lizard skin
a.k.a. Johnston (#40410) or Zetex heat shield batting or flame-resistant
topcoat chemical application?
John
#40600
gengrumpy(at)aol.com Guest
Posted: Thu Apr 28, 2011 11:26 am Post subject: Fire and off field landing |
For what it's worth, I have a Halon bottle mounted on top of the console with the pin and handle in easy reach (right above the fuel pump).
I took aviation consumer's advice some time ago and removed the dry powder one from my airplane (if you've ever discharged one of these in a small area, you'll understand!).
I have a spring-loaded-closed, quarter-sized access hole in the tunnel cover.
Connected to the Halon nozzle is a flexible, plastic hose that I can quickly stick the end through the hole and then squeeze the Halon handle discharging into the tunnel.
grumpy
N184JM
to share.
John
#40600
Posted: Thu Apr 28, 2011 12:06 pm Post subject: Fire and off field landing |
I am considering using the unused port on my Halon bottle to plumb a line
into the tunnel. WE are still discussing the Halon discharge in the cabin as
the tunnel has some big holes to cabin.
civengpe
Posted: Thu Apr 28, 2011 12:11 pm Post subject: Re: Fire and off field landing |
Would someone mind posting a link to the picassa photos?
civengpe
Posted: Thu Apr 28, 2011 12:12 pm Post subject: Fire and off field landing |
Can someone post a link to the picassa photos?
Shannon
On Thu, Apr 28, 2011 at 2:17 PM, Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)> wrote:
[quote]--> RV10-List message posted by: Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)>
grumpy
N184JM
> --> RV10-List message posted by: "John Cox" <johnwcox(at)pacificnw.com (johnwcox(at)pacificnw.com)>
> to share.
> John
> #40600
pmnewlon
AV8ORJWC
Posted: Thu Apr 28, 2011 2:28 pm Post subject: Fire and off field landing |
I was! At work, we use Halon under high pressure nitrogen in a s.steel
accumulator bottle along with a squib. Your system could be quite
effective if directed to the most logical area around the fuel filter
and shutoff valve. Just pull the valve, no squib to worry about. Heat
rises so I am interested in steps which could be taken to provide
additional temperature protection to a composite cover. The one Picasso
shot Img. 1882 gives clarity to a "Sense of Urgency" with a hot seat.
There have been other posts on hydrocarbon sensors to alert when a
combustible source is sensed, temperature is rising above an established
threshold or other indicators. It was great that Ted responded quickly
and accurately to getting the aircraft on the ground.
"When the engine stops, the aircraft is on fire, or a medical emergency
requires immediate action, the obligation of the pilot is to get the
aircraft on the ground." Think of it as becoming immediately the
underwriter's aircraft. The pilots job is to be around to settle the
claim at a successful conclusion. A friend was lost 5 years ago leaving
OSH while attempting solutions "in-flight" and conscientiously passing
over 8 perfectly good airports. He made it up to the point of touchdown
in Madison, WI. Kudos to Ted regardless of what is going to be found as
the cause.
Fire Annunciation?
Fire Suppression?
Pilot Skill? We should all be discussing the various solutions and
pursue enhanced pilot training like LOBO.
John C.
bruce1hwjohnson(at)yahoo. Guest
Posted: Thu Apr 28, 2011 3:27 pm Post subject: Fire and off field landing |
Good write up Ted. Glad your OK and sorry it happened. Good Luck
Sent: Thu, April 28, 2011 3:53:00 AM
Subject: Fire and off field landing
--> RV10-List message posted by: Ted Chang <tc1234c(at)roadrunner.com (tc1234c(at)roadrunner.com)>
Some facts:
I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share wi========================
Posted: Thu Apr 28, 2011 3:59 pm Post subject: Fire and off field landing |
I got the airplane back to the hangar and took a look into the engine
compartment. Now I am pretty sure the cause of the fire is a loose fuel
line b-nut on the mechanical fuel pump. It is entirely my mistake. So,
my follow builders, make sure all your nuts and fittings are tightened.
You don't need to worry about the fire problem I experienced. A few
observations to follow:
a. The fuel flow down and under the tunnel. I did not know when the fire
started since it was burning underneath.
b. After the fire burnt through the tunnel floor, it sent up some smoke
smell.
c. Soon brake line and fuel line melted and the brake fluid produced a
lot of smoke.
d. After brake fluid was consumed there were little smoke.
e. Fire did burn up around the mechanical fuel pump and up around left
mag. Wire bundle attached to the engine mount on top the mag is charred.
f. Fire did not burn through the aluminum heat boxes. The sealant on top
of the heat boxes are gone but not the ones around them.
g. I used plastic bushing, RTV, then a thick coat of 3M fire barrier
sealant for firewall penetration. None of them get compromised.
h. I brought firewall insulator but have not installed yet. It would not
do anything for this particular case.
i. The insulator on the tunnel floor can not withstand the fire. Most of
them are gone with the floor.
j. Nose gear link (WD1016) folded and the rest of the nose gear are in
good shape.
