912 new oil pressure sender and gauge wiring
graeme bird
PostPosted: Sun Apr 24, 2011 11:26 pm    Post subject: 912 new oil pressure sender and gauge wiring Reply with quote
I have just struggled to get the oil pressure readings on my new 912 install with the skydrive VDO gauge and new style sender (mainly because I thought it was oil purge/thermostat issues). The information supplied with the gauge was sparse and misleading. In case anyone else is a the point of wiring, New sender is current based 4-20mA and requires +12v (red) and signal to gauge(white) the gauge needs ground and signal, not power and signal.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
graeme bird
PostPosted: Sun Apr 24, 2011 11:28 pm    Post subject: Re: 912 new oil pressure sender and gauge wiring Reply with quote
Sorry, correction Power on red wire to sender, and ground to gauge. doh!
Graeme Bird
kit4 (Wagstaff) TBD
Richard Wheelwright
PostPosted: Mon Apr 25, 2011 1:13 am    Post subject: 912 new oil pressure sender and gauge wiring Reply with quote
Graeme Bird
  I had a similar problem, I talked to Conrad at Conair Sports and he sent me this the attached diagram. I have wired mine like the first diagram, and all works fine now. Just note that you also have the new pressure gauge too. as it dose not work with the old or original VDO gauge.
Richard Wheelwright
Sent: Monday, 25 April 2011, 8:26
Subject: Re: 912 new oil pressure sender and gauge wiring
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Build nearing completion
http://forums.matronics.com/viewtopic.php?p=338033#338033
http://www.matronics.com/Navigator?Europa--> http://forum - List Contribution Web Site -
Oil_Press_wiring001.pdf
 Filename:  Oil_Press_wiring001.pdf
 Filesize:  16.78 KB
 Downloaded:  320 Time(s)
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
graeme bird
PostPosted: Tue Apr 26, 2011 12:11 pm    Post subject: Re: 912 new oil pressure sender and gauge wiring Reply with quote
Thanks Richard, that is very helpful and has saved me some rewiring. Clearly the sensor can be either a current sink or source.
Graeme Bird
kit4 (Wagstaff) TBD
