messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Sat Apr 23, 2011 11:28 am Post subject: D-Sub and other small connections |
Hi!
I'm a few to several months away from completing my Sonex. I have all of the wiring that goes through the firewall already installed, including my MGL Enigma. I got a used Collins TDR-950 transponder a week or so ago and now need to buy and install a radio, ELT and the audio.
The transponder came only with the bare plastic 15 position single row card edge connector housing. I understand I'd need 15 card edge contacts to crimp or solder, then slide them into this housing. I'll need to connect the other end of most of the wires to a 9-pin male D-Sub connector. The MGL V10 (or V6) radio would also use a 9-pin D-sub connector. And even if the ELT and any audio devices use those connections, there still wouldn't be that many of them. So I am considering soldering all the connections instead of crimping. I feel fairly comfortable with soldering and wouldn't have to buy a $30-40 crimp tool. I've read that soldering underneath the panel isn't fun, which could be needed for any changes made later. Seems I'd be able to pull both ends of the wires out and do this out of the plane. Anything else I'd need to consider?
There don't seem to be any solder cup card edge contacts at digikey, unless I want to buy 5,000 of them. I'd just crimp the 15 wires with the open barrel edge contacts with needle nose pliers, right?
As far as the D-Sub connector, is there an advantage to using a plastic hood to cover the end? Seems some heatshrink would make for a good strain relief fitting.
Any comments appreciated. Below is a pic of the card edge contact at digikey.
13.53 KB |
9780 Time(s) |
_________________ Dan |
Posted: Sun Apr 24, 2011 10:50 am Post subject: D-Sub and other small connections |
Soldered d-subs can be most adequate to the
task . . . but except for those that go to
etched circuit boards, I've not soldered one
in decades. I would think that you could do
all of your harness work out of the airplane.
Please don't. The b-crimp tools are pretty specific
in their design and function for getting a good grip
on the wires. See:
http://www.aeroelectric.com/articles/matenlok/matenlok.html
Actually, heat shrink is only a marginal strain
relief because it too is flexible. Hoods are
always a good idea unless the bundle is
to be supported by other means within a few
inches of connector.
Why not get the better tools, finish the job with
a higher degree of confidence and then sell the
tools? There are probably folks here on the List
that would take them off your hands for $10 less
than you paid for them . . . which means that you
get to 'rent' the real-deal for $10 a shot.
The cost of using better tools and processes
will seem insignificant compared to the $time$
it will take to find a pin that has become
detached AFTER you've installed it.
At this time I am struggling with the installation
of a new radio in my truck . . . normally a simple
cut-out-the-old-connector-splice-in-a-new-connector
endeavor. But an intermittent pin in one of two
connectors in series has caused me to cut out a
perfectly good connector and splice around it
before zeroing in on a bad pin in a NEW connector
that mates with the back of the radio.
Now, if I'd paid $30 extra for the radio and had
Best Buy install it, I would have save about 5 hours,
two weeks delay and lots of cursing and crying out
in the darkness.
It goes to the interesting question of "when does
the bargain cease to be a bargain?" The numbers of
folk who have regretted using the right tool is
probably zero. The folks who have regretted not using
the right tool are . . . well . . .
messydeer
Posted: Sun Apr 24, 2011 11:56 am Post subject: Re: D-Sub and other small connections |
Thanks, Bob
| Quote: | | ...when does the bargain cease to be a bargain? |
I'm certainly guilty of spending hours looking to save a few dollars. How much is my time worth? More than that...or it should be.
Yet, I don't have an open barrel crimp tool. These may be the only 15 open barrel contacts I'd crimp, all the others being d-sub. I see that Eclipse makes an open barrel crimper, 300-035, which goes for $15-20. I'd be okay with that sitting around in my tool box for a decade before using it again, or like you suggest, passing it on to another builder. The other option would be to cutoff the wings of the contact and just solder it to the wire. Wouldn't this work? Granted, if I were to do 100 of them, it wouldn't be worth the time.
Also, I've seen on Frys.com that they have very cheap d-sub stuff made by Pan Pacific. Is this fit to use, or would it be better to stick with the digikey suppliers?
Posted: Sun Apr 24, 2011 2:54 pm Post subject: D-Sub and other small connections |
| Quote: | Wouldn't this work?
I have no way to assess your skill set nor
the outcome of using any particular product
outside its design goals without having
personally observed and considered the results . . .
| Quote: | Granted, if I were to do 100 of them, it wouldn't be worth the time.
Your call my friend . . .
| Quote: | Also, I've seen on Frys.com that they have very cheap d-sub stuff
How about B&C or Steinair?
etienne.phillips(at)gmail Guest
Posted: Sun Apr 24, 2011 4:12 pm Post subject: D-Sub and other small connections |
On 23 Apr 2011, at 9:28 PM, messydeer wrote:
| Quote: | I've read that soldering underneath the panel isn't fun, which could be needed for any changes made later.
Hi Dan
Having spent in excess of 100 hours on my back in the front of my Citabria soldering thin wires into small places, I can certainly add my voice to those who suggest finding another solution. I am more comfortable soldering than crimping for a variety of reasons, so your suggestion for making sure both ends of a wire can come out would have helped me considerably. My main problem is that nearly every instrument in my aeroplane is connected to everything other instrument, so the harness would have to come out in one massive loom, but the routing of the wires has formed a net around the supports for the panel. With more planning I could have avoided that though.
I'd still suggest being able to get the harness out, as crimping (even with the best tools available) in a cramped space on your back in the dark is probably only slightly more fun than soldering, which in turn is only slightly better than getting teeth pulled.
My 2c...
Etienne
messydeer
Posted: Mon Apr 25, 2011 6:48 am Post subject: Re: D-Sub and other small connections |
Thanks, guys
I've used both B&C and Steinair before and would prefer to deal with either of them, but they don't have the parts I'd need. I may see how soldering the 'crimp' card edge contacts and if it doesn't work, switch to crimping.
Etienne, it sounds like both crimping and soldering under the panel is a pain, but you would still choose soldering if you were to do it over again, assuming you'd NOT be able to get the wires out?
Besides this transponder, I'll be getting and installing a COM radio, headset wiring, and an ELT. After flying, I may install wingtip lights. Other than this, all the wiring is already installed, including that for the EFIS. With any luck I hope to not have to pull out a 'massive loom', since the avionics would be last in, first out.
Posted: Mon Apr 25, 2011 3:35 pm Post subject: D-Sub and other small connections |
On 25 Apr 2011, at 4:49 PM, messydeer wrote:
| Quote: | Etienne, it sounds like both crimping and soldering under the panel is a pain, but you would still choose soldering if you were to do it over again, assuming you'd NOT be able to get the wires out?
Yes... However, that's driven by some fairly unique factors. I've been soldering almost daily since I was 6, and getting hold of decent machined crimp pins for D-Subs are prohibitively expensive from here in South Africa. I tried the cheap folded sheet pins, and they are horrendous! My final choice was the solder-cup D-Subs, with heat-shrink over each wire and a housing over the whole plug, supporting the wires in a nice bundle. An entire 15-pin solder-cup D-Sub assembly is cheaper than a single machined crimp pin here, and that's when ordering hundreds of pins at a go, and excluding the cost of the required tooling! A point to add is that the MGL V10 radio is supplied with a solder-cup plug.
If I were to do it over, I would still use the solder-cup d-subs, but I'd make sure I could get the harness out. As it stands, I am able to remove each instrument without any difficulty. Bear in mind too that significant effort went into labelling each wire, and checking that it was soldered correctly. So different choices for different people. Most of the arguments I've heard for crimped pins (aside from the repeatability for unskilled labour) revolves around being able to shuffle the pins around. If the harness is made correctly the first time, the amount of shuffling that needs to be done is minimal in most cases.
The next consideration is the stiffening of the wire (bad for vibration tolerance) around a soldered joint due to the solder wicking up into the strands of the wire. Bob can comment specifically on this, but my understanding is that if the wire is supported in the D-Sub housing, there should be no additional concern over crimped pins in this regard.
In my aircraft, I can lose the entire electrical system with no discomfort. I am day VFR only pilot, and have steam backups for the airspeed, altimeter and engine indications. I also have a handheld radio, no flaps, manual trim, fixed undercarriage, and twin magnetos. So if any wire were to come loose, the heatshrink should stop it from shorting out, but if it did then at worst it would pop a circuit breaker, and I'd sort it out on the ground.
My solution to the transponder problem, if it were me, would be to solder pigtails directly onto the card, leading to a 15- or 25-pin D-Sub. This would eliminate those awful low-pressure card-edge connectors that are nigh impossible to find now days. I would use a flexible epoxy to cover the soldered joints onto the card to offer some form of vibration relief on the hardened wire. This might mean modifying the tray, but it would yield an easily disconnectable instrument. This solution may very well have hidden dragons though, so I offer it for peer review!
Etienne
Posted: Mon Apr 25, 2011 4:39 pm Post subject: D-Sub and other small connections |
In the heavy-iron factories, we endeavor to make each
instrument harness long enough that the connectors can
be mated up before the instrument is stuck in the hole
and mounted. There is NO way you lay on your back and
work behind the panel on a King Air or Beechjet.
With reasonable care, the solder-cup connector
is perfectly suitable component. I published this
installation comic-book some years ago . . .
http://www.aeroelectric.com/articles/dsubs/d_solder.html
Behind-the-joints support on d-subs is necessary
whether the pins are soldered or crimped. Neither
pin technology offers insulation support behind
the pin-to-wire interface. The wire is just as
'solid' inside a crimped pin as it is on a soldered
pin. So use the hoods . . . or pot the back side
like . . .
http://www.aeroelectric.com/articles/macservo/macservo.html
Been there, done that. Works good and lasts a long
time. You'll want to fabricate a bench test harness
to send along with your radio if it has to go to the
shop so the tech can power it up.
ceengland(at)bellsouth.ne Guest
Posted: Mon Apr 25, 2011 4:41 pm Post subject: D-Sub and other small connections |
On 4/25/2011 6:28 PM, Etienne Phillips wrote: | Quote: |
Etienne
| I've successfully soldered quite a few of the edge type pins pictured in an earlier email; I just manually folded the shorter wings with needle nose pliers, soldered, then manually wrapped the longer wings. Not a lot of fun, but very 'do-able'. However, Etienne's solution makes even more sense, as long as warranty isn't an issue.
By paying the price of an extra few ounces & some careful planning, you can avoid diving under the panel for future soldering or crimping sessions. Just make service loops & routing so the connectors can be brought out into the cockpit, or even out over the wing for soldering sessions.
Charlie
messydeer
Posted: Tue Apr 26, 2011 6:52 am Post subject: Re: D-Sub and other small connections |
| Quote: | | My solution to the transponder problem, if it were me, would be to solder pigtails directly onto the card, leading to a 15- or 25-pin D-Sub. |
I think I'll have that as plan B, if I can't get the edge contacts to work right.
