NGK spark plugs
Fergus Kyle
PostPosted: Sat Apr 23, 2011 6:12 am    Post subject: NGK spark plugs Reply with quote
Time: 03:43:59 AM PST US
Subject: Rotax 914 NGK Spark Plugs
From: "pestar" <peter(at)reivernet.com (peter(at)reivernet.com)>
Recently Rotax added NGK sparkplugs as approved plugs for the 914 complementing the existing Denso plugs. Can someone point me to the Service Bulletin that mentioned this. I cannot find it and would like to print it out for my records.
In New Zealand NGK's are a lot easier to get than Denso's
Thanks Peter Armstrong
Time: 10:14:24 AM PST US
Subject: Re: Rotax 914 NGK Spark Plugs
From: PHILLIPS I <ivor.phillips(at)ntlworld.com (ivor.phillips(at)ntlworld.com)>
Hi Peter
Its a series of running mods for 2010, i think its the third article, haveincluded it as a pdf regards Ivor Phillips G-IVER,
Peter and Ivor –
Just to be sure (i have a hrd time navigating the 914 releases) Is this the article?
SI-912-020 / SI-914-022 Revision 4
74-00-00, item 2.
Thanks, Ferg
Ivor Phillips
PostPosted: Sat Apr 23, 2011 10:48 am    Post subject: NGK spark plugs Reply with quote
Hi Ferg
No i think that is just the current Rotax bulletin index,
I have included the relevant bulletin as a PDF file
best wishes
Ivor
G-IVER
On 23 April 2011 15:09, Fergus Kyle <VE3LVO(at)rac.ca (VE3LVO(at)rac.ca)> wrote:
Subject: RotaxEngines-List: Rotax 914 NGK Spark Plugs
Subject: Re: RotaxEngines-List: Rotax 914 NGK Spark Plugs
Hi Peter
Peter and Ivor –
74-00-00, item 2.
Thanks, Ferg
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
ttp://forums.matronics.com
SI-912-020-R4_Running_mods_2010.pdf
 Filename:  SI-912-020-R4_Running_mods_2010.pdf
 Filesize:  1.08 MB
 Downloaded:  311 Time(s)
