Flap System trouble shoot
jonlaury
PostPosted: Thu Apr 21, 2011 9:54 pm    Post subject: Flap System trouble shoot Reply with quote
What's wrong with this picture?
I'm trying to install an over-ride switch in conjunction with the Aircraft Extras Flap Positioning System
My flap motor is right up against the current limit of the AE FPS so I installed two 30A ice cube relays. On the relay, 12v+ and the motor terminals are NC. Pins 15 & 16 of the FPS are flaps up/down out to motor. The rocker at the top is the flap selector switch in to FPS.
The rocker at the bottom is the FPS circuit board over-ride switch.
Pins 15 & 16 are normally ground, except when there's a system flap input and either 15 or 16 goes to 12v+. I installed the diodes on the 15/16 to relay coil legs because I was getting a dead short when the override switch was closed.
I thought that the diodes would solve the problem, but I'm still blowing fuses whenever the override switch is closed.
Any suggestions much appreciated.
John
FPS trouble shoot.pdf
 Filename:  FPS trouble shoot.pdf
 Filesize:  30.01 KB
 Downloaded:  597 Time(s)
PostPosted: Fri Apr 22, 2011 7:16 am    Post subject: Flap System trouble shoot Reply with quote
It would help if you could offer a schematic of
the wiring as opposed to a pictorial. If you're
using relays to separate the output of an existing
control system from the motor, the I would expect
the control system to drive relay coils and the
motor would be powered from an alternative power
source through relay contacts. In other words, there
would be no exchange of energy between the control
system and the motor . . . your drawing shows some
wires that connect to motor . . . ?????
The forth page of
http://www.aeroelectric.com/PPS/Flight/Flaps/Flaps.pdf
illustrates a configuration of single-pole, double-
throw relays used to accept inputs from a small
switch for crew control of flaps. This same circuit
with the switch removed would accept outputs from
your flap control system.
It would be helpful to know more about the flap
control system. What's the 'current limit' issue
all about. Normally, flap system draws are pretty
benign, 10A or less. What is it about your particular
flap configuration that makes it "oversized" for
the control system. What is the design goal for
an "override switch"?
Can you point us to a link for the control system's
installation manual?
I would also encourage you to learn to draw in
pure schematic form . . . it's the universal language
of electrical systems behaviors. I once had to teach
a group of Japanese technicians how to deal with
some video equipment I designed. Their English was
marginally useful, my Japanese was nil. But our mutual
understanding of the schematics, video in general and
the use of test equipment made a much lighter task
of what could have been a no-value-added endeavor.
jonlaury
PostPosted: Sun Apr 24, 2011 11:50 am    Post subject: Re: Flap System trouble shoot Reply with quote
Now in schematic form per Bob's suggestion.
Aircraft Extras FPS-plus nt schematic URL - http://www.aircraftextras.com/PDF-files/FPS-Plus-ntWebE.pdf
My flap motor draws 7.5 amps in a no load condition. The traces on the FPS-Plus board are good for 10 amps. My flap extension speed is 140mph and I was concerned that under load I would be near max. amperage of the FPS system. I opted for more margin on flap motor current draw.
The manual flap switch is per AE's suggestion. Should the board in the FPS system fry for whatever reason, I can bypass the system with the manual switch.
Per my original post, Pins 15 & 16 of the FPS are normally GRND. When the the FPS flap switch is depressed, the selected function goes to 12v+. I have diodes in the wires from 15 & 16 to the coils in an attempt to prevent the manual switch (12v+) from shorting to ground. But whenever I press the manual switch, the fuse blows.
I can't see why.
Any help appreciated.
John
 Filesize:  59.06 KB
 Downloaded:  583 Time(s)
PostPosted: Sun Apr 24, 2011 3:02 pm    Post subject: Flap System trouble shoot Reply with quote
Hmmmm . . . that's a REALLY big, no load draw.
Do you have any in-flight data on maximum draw?
the manual switch.
What is the likelihood that having to make a no-flaps
landing presents a hazardous condition?
I can't see why.
I can't see why either without a schematic
that describes functionality of the compoents
as-wired in your system.
I can tell you that if wired per the figure I
referenced in my last posting, the switch
in the figure becomes the manual switch. Automatic
commands could be tied in parallel with the manual
switch if you include the diodes you've described
to prevent back-flow into the grounded terminal
on the ECB assembly.
Are you sure your diodes are installed correclty?
retasker(at)optonline.net
PostPosted: Sun Apr 24, 2011 4:47 pm    Post subject: Flap System trouble shoot Reply with quote
You don't say which fuse is blowing. However, if everything is actually
connected exactly like the schematic shows no fuse should blow.
I suggest you carefully go over the actual connections to make sure that
everything is really connected as shown. I have had enough times when I
just knew that the connections were correct (of course they were
correct, I wired them!). Then when I examined everything more closely
found something reversed or connected to the wrong pin.
Good luck.
Dick Tasker
Per my original post, Pins 15& 16 of the FPS are normally GRND. When the the FPS flap switch is depressed, the selected function goes to 12v+. I have diodes in the wires from 15& 16 to the coils in an attempt to prevent the manual switch (12v+) from shorting to ground. But whenever I press the manual switch, the fuse blows.
I can't see why.
John
http://forums.matronics.com/viewtopic.php?p=337983#337983
http://forums.matronics.com//files/fps_trouble_shoot_131.pdf
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
jonlaury
PostPosted: Sun Apr 24, 2011 6:58 pm    Post subject: Re: Flap System trouble shoot Reply with quote
I'm pretty sure, without it being in front of me now.
The cathode (banded end) of the diode faces the coil of the relay.
And the FPS selector switch operates the FPS and flap motor in either direction as intended. If a diode was backward, then power would not flow from 15 or 16 to the relay coil.
I also tested the diodes against a new one. They were identical. R is on the order of 1500 K ohms, voltage drop is about .54
The 5a (actually 2a for testing) for the manual switch is the one that blows.
I will re-check everything next time I'm at the hangar.
PostPosted: Mon Apr 25, 2011 5:59 am    Post subject: Re: Flap System trouble shoot Reply with quote
Make sure that the manual switch is connected to the hot side of the relay coils and not to the grounded side. And make sure that the switch is wired correctly.
Depending on the size of the relays, it is possible that high inrush current is blowing a 2 amp fuse. Try a 5 amp. Or substitute a small 12 volt light bulb for the fuse. If 12 volts are dropped across the light bulb, then there is a short to ground someplace.
Joe
Joe Gores
Tundra10
PostPosted: Mon Apr 25, 2011 7:12 am    Post subject: Flap System trouble shoot Reply with quote
John,
If you have wired everything per your drawing, the fuse should not
blow, so look first for a wiring error.
After you get that fixed, there are two changes I suggest. In your
diagram, it looks like you are using a double pole switch for the
manual override. So with the switch in neutral position, there is no
ground to the relay coils. This means the automatic controller cannot
turn on the relays. Just delete that half of the switch and ground
that side of both relay coils to allow automatic control.
The other suggestion I have is to trade both the NC and NO connections
on the relays. As shown, when not energized, all the flap motor wires
have +12V. To energize, one of those wires is grounded. Perhaps
better is normally both wires grounded and when activated, one goes to
+12V. This way, if a wire shorts to the airframe, it would not
normally have power in it. Less likely to cause a fire ? In effect,
this reverses the operation of the relays, so you will need to switch
the wires to the flap motor, so it turns in the same direction as it
originally did.
Just to be sure, the switch you need is a single pole, double throw,
center off momentary switch for manual flap activation. If you
already have a double pole version, one side can be left unwired. The
aeroelectric switch type is 1-7.
Looks like a nifty flap controller. If I didn't have manual flaps, I
would be really tempted to order one.
Jeff Page
Dream Aircraft Tundra #10
Time: 08:02:54 PM PST US
Subject: Re: Flap System trouble shoot
either direction
to the relay coil.
is on the order
flap.pdf
 Filename:  flap.pdf
 Filesize:  301.2 KB
 Downloaded:  582 Time(s)
jonlaury
PostPosted: Mon Apr 25, 2011 2:07 pm    Post subject: Re: Flap System trouble shoot Reply with quote
Thank you all for your suggestions.
After pulling things apart and blowing a few more fuses, the thing started working as intended. I was pulling off a relay coil spike-catcher diode, to see if that would make a difference, and I inadvertently grounded the 14 ga + to the flap motor and blew the 15a fuse. When I tried the FPS system, the flap motor wouldn't run but the manual switch was now activating the relays. Same for the FPS. I replaced the 15a fuse and s-c diode and everything works fine. I don't know what was causing the problem, but I suspect some errant strand of wire that was causing a dead short. Maybe the 15a got into it and vaporized it. In soldering the diodes into the wire legs, I wrap the splice with a single strand of fine wire to hold it in place while soldering. I suspect an errant piece of this was lying across a coil terminal to ground invisible to these far-sighted eyeballs.
I also disassembled the flap motor from the worm-drive jack screw because of Bob's surprise at the 7.5a no-load draw. The motor by itself draws 2.4a. I thought that maybe the jack screw mechanism was gummed up with old hard dried-up grease so I disassembled it too. The grease was fresh and all parts turned easily. Back together the motor still draws 7a +/-. Just the nature of this beast.
The Aircraft Extras Flap Positioning System works really well and is a breeze to use. Highly recommended for those with electric flaps.
John
