New Rotax Oil Pressure Regulator Parts
hgmckay
PostPosted: Thu Apr 21, 2011 2:41 pm    Post subject: New Rotax Oil Pressure Regulator Parts Reply with quote
Fixing to install the new Rotax Oil pressure regulator replacement parts (cone, spring, and Hex screw). I don’t believe an oil system purge is necessary or required when replacing the old parts with these new ones. However, as I remember an old SI for replacing the spring and cleaning the “ball” stated to follow the purging procedure. Any comment?
Hugh G. McKay III, P.E.
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
Hugh.vcf
 Filename:  Hugh.vcf
 Filesize:  364 Bytes
 Downloaded:  435 Time(s)
bob(at)fly-ul.com
PostPosted: Thu Apr 21, 2011 3:00 pm    Post subject: New Rotax Oil Pressure Regulator Parts Reply with quote
Not needed. Only a little oil will dribble out when you make the change. No different than removing the oil filter
--Bob Comperini
On Apr 21, 2011, at 3:37 PM, "Hugh McKay" <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
[quote] Fixing to install the new Rotax Oil pressure regulator replacement parts (cone, spring, and Hex screw). I don’t believe an oil system purge is necessary or required when replacing the old parts with these new ones. However, as I remember an old SI for replacing the spring and cleaning the “ball” stated to follow the purging procedure. Any comment?
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email [url=mailto:hgmckay(at)bellsouth.net]hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)[/url]
<Hugh.vcf>
Roger Lee
PostPosted: Thu Apr 21, 2011 4:13 pm    Post subject: Re: New Rotax Oil Pressure Regulator Parts Reply with quote
Hi Hugh,
I'm with Bob. No purge. Too little oil drool to worry about.
Hi Bob,
How have you been?
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
hgmckay
PostPosted: Fri Apr 22, 2011 5:31 am    Post subject: New Rotax Oil Pressure Regulator Parts Reply with quote
Bob, Roger,
Thanks, I thought that was the case.
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
