Air start solebnoid valve
wise(at)txc.net.au
PostPosted: Wed Apr 20, 2011 1:42 pm    Post subject: Air start solebnoid valve Reply with quote
G’Day again,
Can anyone please tell me whereabouts the air start solenoid valve on a Yak 52?
Where is it located.
Does anyone have a actual photograph of the valve in its position?
Thanks and cheers,
Chris.
george(at)gesoco.com
PostPosted: Wed Apr 20, 2011 1:50 pm    Post subject: Air start solebnoid valve Reply with quote
On the inside of the firewall above and ahead of the pilots left foot.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/
SKYPE george.coy
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Chris Wise
Sent: Wednesday, April 20, 2011 5:38 PM
To: yak-list(at)matronics.com
Subject: Air start solebnoid valve
G’Day again,
Thanks and cheers,
Chris.
dsavarese0812(at)bellsout
PostPosted: Wed Apr 20, 2011 1:57 pm    Post subject: Air start solebnoid valve Reply with quote
Directly in front of your left rudder pedal on the back side of the
firewall. It is mounted vertically.
Dennis
On 4/20/2011 4:38 PM, Chris Wise wrote:
G’Day again,
Yak 52?
Thanks and cheers,
Chris.
Airstart_solenoid.pdf
Download
 Filename:  Airstart_solenoid.pdf
 Filesize:  58.96 KB
 Downloaded:  274 Time(s)
wise(at)txc.net.au
PostPosted: Wed Apr 20, 2011 2:07 pm    Post subject: Air start solebnoid valve Reply with quote
Thanks George and yes of course. I had clean forgotten.
Cheers,
Chris.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of George Coy
Sent: Thursday, 21 April 2011 7:17 AM
Subject: RE: Air start solebnoid valve
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
http://coyafct.com/
SKYPE george.coy
G’Day again,
Thanks and cheers,
Chris.
 http://www.matronics.com/Navigator?Yak-List http://forums.matronics.com http://www.matronics.com/contribution
