jimpuglise(at)comcast.net Guest
Posted: Sat May 13, 2006 4:16 am Post subject: Wing Cradles |
I am in the process of making my wing cradles. What experience have people had with the material used to line them? I will also need to make a set for my trailer and am anxious to avoid "hangar rash" after the wings are painted.
Jim-A-286, Punta Gorda FL
<html><body>
<DIV>I am in the process of making my wing cradles. What experience have people had with the material used to line them? I will also need to make a set for my trailer and am anxious to avoid "hangar rash" after the wings are painted. </DIV>
<DIV> </DIV>
<DIV>Jim-A-286, Punta Gorda FL</DIV></body></html>
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sat May 13, 2006 4:51 am Post subject: Wing Cradles |
Jim,
I used carpet strips about 150mm wide, it seemed to work fine. - Paul
| Quote: | jimpuglise(at)comcast.net
| Quote: | I am in the process of making my wing cradles. What experience have people
Posted: Sat May 13, 2006 5:38 am Post subject: Wing Cradles |
Hi! Jim
I used a loop of conveyor belting lined with carpeting making sure the
countersunk bolts and nuts are completely out of the way of the wing
surfaces. If you go to the Matronics photo share pages and look for Self
Rigging Photos posted under my name on Aug 13 DSC 00138jpg "End View of
Wing in Clamp" you can see my two carpeted cradles, they are on pivots
to allow the wings to be lifted over them so they pivot back up to act
as cradles. One (Starboard side) is laid down and one (Port side) is in
travel mode (up) in the photo. Both without the wings in place.
I have in the region of 600 hours and I would estimate about the same
number of rig and dismantles to my name without damage or trailer
rash.(other than by my own carelessness!)The aircraft had travelled
hundreds of miles in this trailer, without the wings vertically
restrained, (such vertical restraint on the trailing edge can result in
damage from the "tie downs") mine are just pinned through the spars.
However the trailer is a double axle with the axles load linked for
smooth travel and the whole rig being so heavy has no chance of bouncing
Bob Harrison G-PTAG Europa MKI/Jabiru 3300
