bob(at)fly-ul.com Guest
Posted: Mon Apr 04, 2011 7:23 pm Post subject: Questions about radiator & duct tape on a 582 |
What other options do I have?
Do you have a thermostat on the engine?
Not sure you'll need anything else besides that, but there are some people making louver systems for some radiator setups. here's one: http://www.theultralightplace.com/new_page_8.htm
How about mixture control?
Bob Comperini
e-mail: bob(at)fly-ul.com
WWW: http://www.fly-ul.com
Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Mon Apr 04, 2011 7:50 pm Post subject: Questions about radiator & duct tape on a 582 |
Nope - no thermostat or mixture control.
I guess I should look into both.
Thanks, Bob - I should have guessed that you'd be able to respond to this question.
Arty
--- On Mon, 4/4/11, Bob Comperini <bob(at)fly-ul.com> wrote:
| Quote: | >What other options do I have?
Bob Comperini
e-mail: [url=/mc/compose?to=bob(at)fly-ul.com]bob(at)fly-ul.com[/url]
p; --> http://www.matronics.com/Navigator?RotaxEnginebsp; - MATRONICS WEB FORUMS - href="http://forums.matronics.com" target="_blank">http://forums.matrobsp; - List Contribution Web Site -http://w=======================
| [quote][b]
m.tucciarone(at)hotmail.c Guest
Posted: Tue Apr 05, 2011 3:21 am Post subject: Questions about radiator & duct tape on a 582 |
I have been using a ball valve between my heater and the engine. I have the valve in the cockpit so I am able to just dial in the temp I want. I got this tip from the guys up in Canada. It works great.
From: TheWanderingWench (thewanderingwench(at)yahoo.com)
Sent: Monday, April 04, 2011 11:46 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: Re: Questions about radiator & duct tape on a 582
Arty
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
elleryweld(at)aol.com Guest
Posted: Tue Apr 05, 2011 6:06 am Post subject: Questions about radiator & duct tape on a 582 |
Matt Tucciarone
You got to explain a little more about your system a Ball Valve between your heater and engine is not enough, do you have external cooler/Coolers? in this system. also what Temp are you controlling the heater or the engine Temp ?
Ellery Batchelder Jr.
Roger Lee
Posted: Tue Apr 05, 2011 6:28 am Post subject: Re: Questions about radiator & duct tape on a 582 |
Heater control valves are fairly common on some engines. (not the Rotax) They are an in line valve with a cable. Opening or closing regulates the flow thus the heat exchange. They can usually be purchased at an auto parts store. If you can't find it at the US auto parts store then try the foreign parts store. They were more common overseas many years ago. I suppose you could also make your own, but make sure you use a metal one and not a plastic that may be subject-able to the heat or be prone to failure from the heating and cooling cycle.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Tue Apr 05, 2011 9:45 am Post subject: Questions about radiator & duct tape on a 582 |
Ok,
The coolant goes out of my hot engine, then to the heater. After the heater, I have a brass ball valve that I can reach in the cockpit. Then it goes to the radiator and then back to the engine. I try to keep my water temp around 180 to 190f.
Sent: Tuesday, April 05, 2011 10:02 AM
Matt Tucciarone
-----Original Message-----
From: Matt Tucciarone <m.tucciarone(at)hotmail.com>
Sent: Tue, Apr 5, 2011 7:19 am
Arty
--- On Mon, 4/4/11, Bob Comperini <bob(at)fly-ul.com (bob(at)fly-ul.com)> wrote:
Bob Comperini
e-mail: wlmailhtml:/mc/compose?to=bob(at)fly-ul.com
Posted: Tue Apr 05, 2011 4:09 pm Post subject: Questions about radiator & duct tape on a 582 |
thank you for the details on your system
