Slanted Right Elevator Trim Tab
JHearnsberger
PostPosted: Wed Mar 30, 2011 5:43 pm    Post subject: Slanted Right Elevator Trim Tab Reply with quote
I noticed last night when looking down the back of the tail cone that the trim tab on the right elevator appears to be slanted upward toward where the vs attaches. Maybe the photos can better explain.
Jake H.
 Filesize:  551.11 KB
 Viewed:  7911 Time(s)
 Filesize:  651.48 KB
 Filesize:  508.68 KB
Jake Hearnsberger
RV-10 Wings
Springhill, LA
Tim Olson
PostPosted: Wed Mar 30, 2011 9:50 pm    Post subject: Slanted Right Elevator Trim Tab Reply with quote
Try to sight straight down the trailing edge, from the side....see if
there is any bowing or fishtailing to the way the edge is. It
looks like their either is some of that, or maybe some bending on
the end, but it's hard to say from those photos. If you had a straight
and true trim tab, it wouldn't likely be doing that. Try to do
all photos or visuals from real consistent centered places though.
All those photos are off center a bit so it's hard to tell what's
an optical illusion and what's real.
None of the parts in the fail feathers are very expensive, so if
you find something that just isn't great and you figure out the
cause, it wouldn't be a big deal to re-build.
Tim Olson - RV-10 N104CD
Jake H.
Jake Hearnsberger
RV-10 Empennage
Springhill, LA
http://forums.matronics.com//files/img_0310_217.jpg
http://forums.matronics.com//files/img_0307_155.jpg
http://forums.matronics.com//files/img_0305_169.jpg
daveleikam(at)wi.rr.com
PostPosted: Thu Mar 31, 2011 4:54 am    Post subject: Slanted Right Elevator Trim Tab Reply with quote
I too had to re-build one tab. I would carefully inspect the tab itself for trueness.
David Leikam
RV10
Flying
Jake H.
Jake Hearnsberger
RV-10 Empennage
Springhill, LA
http://forums.matronics.com/viewtopic.php?p=335539#335539
JHearnsberger
PostPosted: Thu Mar 31, 2011 7:46 am    Post subject: Re: Slanted Right Elevator Trim Tab Reply with quote
Looking down the edge of the elevator, it looks straight all the way up to the trim tab. Then, the whole trim tab appears to slant upward.
To be honest, the trim tabs have always bothered me and I was hoping I could one day install new ones. I had a very hard time squeezing my hand in and bucking the rivets and I would up using pop rivets in places. Is it hard to mount new trim tabs on?
Jake Hearnsberger
RV-10 Wings
Springhill, LA
JHearnsberger
PostPosted: Fri Apr 01, 2011 7:05 pm    Post subject: Re: Slanted Right Elevator Trim Tab Reply with quote
Here are a couple more pictures.
Jake
 Filesize:  1.98 MB
 Viewed:  7848 Time(s)
 Filesize:  1.92 MB
Jake Hearnsberger
RV-10 Wings
Springhill, LA
Tim Olson
PostPosted: Fri Apr 01, 2011 8:25 pm    Post subject: Slanted Right Elevator Trim Tab Reply with quote
Yeah, they look to have a built in twist. I'd rebuild new ones.
On Apr 1, 2011, at 8:05 PM, "JHearnsberger" <jakehearnsberger(at)gmail.com> wrote:
Jake
Jake Hearnsberger
RV-10 Empennage
Springhill, LA
http://forums.matronics.com/viewtopic.php?p=335817#335817
http://forums.matronics.com//files/img_1535_199.jpg
http://forums.matronics.com//files/img_1531_796.jpg
n223rv(at)wolflakeairport
PostPosted: Sat Apr 02, 2011 3:26 am    Post subject: Slanted Right Elevator Trim Tab Reply with quote
While you are at it, build them yourself with the aluminum wedge in the trailing edge and they will match the elevators and look much nicer.....
Just a thought.....
-Mike
> Jake
> Jake Hearnsberger
> RV-10 Empennage
> Springhill, LA
