avkozloff(at)roadrunner.c Guest
Posted: Sun Mar 20, 2011 9:31 am Post subject: Rotax 912 exhaust pipe cracks |
Gentlemen:
A few years ago there was a spate of Pulsar II and III exhaust pipe
cracks that was somehow resolved.
I remember some discussion regarding replacing the mild steel pipes that
came with the engine with Stainless Steel ones.
Could anyone please refresh our minds with the the details of this
problem and how it was resolved?
Thank you,
Alex Kozloff
Pulsar I
N190AK
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
pulsar331(at)sbcglobal.ne Guest
Posted: Sun Mar 20, 2011 10:08 am Post subject: Rotax 912 exhaust pipe cracks |
It was resolved by going to Rick's exhaust system. Both the original mild steel and the SkyStar stainless steel systems cracked continuously.
I have Rick's system built with stainless steel and it has worked perfectly for over 800 hours. I believe those with his mild steel system have also had success.
I think some folks also had success with a stainless steel system made by Jeff Sell.
Hope that helps.
Bill Coleman
Pulsar XP N331BP
To: pulsar-list(at)matronics.com
Sent: Sun, March 20, 2011 1:15:00 PM
Subject: Rotax 912 exhaust pipe cracks
--> Pulsar-List message posted by: "Alex Kozloff" <avkozloff(at)roadrunner.com (avkozloff(at)roadrunner.com)>
Gentlemen:
A few years ago there was a spate of Pulsar II and III exhaust pipe cracks that was somehow resolved.
I remember some discussion regarding replacing the mild steel pipes that came with the engine with Stainless Steel ones.
Could anyone please refresh our minds with the the details of this problem and how it was resolved?
Thank you,
--Alex Kozloff
Pu nbsp; ================
mortweaver(at)sbcglobal.n Guest
Posted: Sun Mar 20, 2011 11:13 am Post subject: Rotax 912 exhaust pipe cracks |
I had similar cracking problems with Aero Designs mild steel and Sky Star's stainless steel systems on my Pulsar XP. I decided to go for maximum efficiency by reducing exhaust system weight and heat dissipating area in the engine compartment. I had Aircraft Exhaust, Inc. build a straight pipe system from a PVC pipe mock-up. There is no exhaust cans in my system. The exhaust pipes exiting the lower cowl are capped on the ends with a series evenly spaced 3/16 holes around the periphery of each pipe. What I have done is to move the exhaust can baffle outside of the engine compartment less the can. I monitored both cylinder EGT and back pressure to experimentally determine how many holes to make. I used a long tapered punch to pull flutes in the stainless steel. The result was 3.1 pounds weight per side with slightly increased exhaust noise. I have short transverse pipe runs (about 3 inches from bottom of fuselage) and no measurable increase in drag. I also have no exhaust stains on the bottom of the fuselage. I have less than 100 hours on the system with no signs of cracking or loosening at the manifold connection points. I can provide pictures if needed.
Dave Weaver N912GR
--- On Sun, 3/20/11, Alex Kozloff <avkozloff(at)roadrunner.com> wrote:
Date: Sunday, March 20, 2011, 12:15 PM
Gentlemen:
Thank you,
--Alex Kozloff
Pulsar I
N190AKhttp://www.matronics.com/Navigator?P - MATRONICS WEB FORUM; ="http://www.matronics.com/contribution" target=_blank>http://www.matro=====================
| [quote][b]
rickyd54(at)gmail.com Guest
Posted: Sun Mar 20, 2011 1:03 pm Post subject: Rotax 912 exhaust pipe cracks |
Alex,
Did you get a new bird?
Rick (AKA your Seagrams buddy:-)
On Mar 20, 2011, at 12:15 PM, "Alex Kozloff" <avkozloff(at)roadrunner.com> wrote:
Gentlemen:
Thank you,
Alex Kozloff
Pulsar I
N190AK
skipper144(at)juno.com Guest
Posted: Sun Mar 20, 2011 1:14 pm Post subject: Rotax 912 exhaust pipe cracks |
Dave
Thanks for the exhaust pipe description.
Pictures would be terrific!
Thanks in advance.
Be well,
Skip La Police
ccoulter(at)wavecable.com Guest
Posted: Mon Mar 21, 2011 7:21 am Post subject: Rotax 912 exhaust pipe cracks |
On Sun, 20 Mar 2011 10:15:00 -0700
Gentlemen:
Steel ones.
Thank you,
Alex Kozloff
Pulsar I
N190AK
Un/Subscription,
Forums!
Admin.
We bought Rick's exhaust.
Clarke
garymid(at)ymail.com Guest
Posted: Mon Mar 21, 2011 7:51 am Post subject: Rotax 912 exhaust pipe cracks |
I have Rick's exhaust- 760hrs with zero issues.
Gary
Pulsar XP-912 N9DK
Sent: Sun, March 20, 2011 2:05:45 PM
Subject: Re: Rotax 912 exhaust pipe cracks
Hope that helps.
Bill Coleman
Pulsar XP N331BP
Gentlemen:
Thank you,
--Alex Kozloff
TomisFlyingby(at)comcast. Guest
Posted: Thu Mar 24, 2011 7:26 pm Post subject: Rotax 912 exhaust pipe cracks |
Rick's our hero!!
Posted: Fri Mar 25, 2011 10:13 am Post subject: Rotax 912 exhaust pipe cracks |
On Thu, 24 Mar 2011 22:24:38 -0500
"Tom Gibbons" <TomisFlyingby(at)comcast.net> wrote:
[quote] Rick's our hero!!
freedom4life(at)xtra.co.n Guest
Posted: Fri Mar 25, 2011 11:00 am Post subject: Rotax 912 exhaust pipe cracks |
I have a look alike product based on Rick's system and I now have 1500 hours
on it with no issues. My first system supplied by Aero Designs would crack
every 50 hours or so! It got to the point I was afraid to fly anywhere in
case it broke.
Cliff
ZK KFC
> Rick's our hero!!
