Europa Classic cooling hoses
uvtreith(at)t-online.de
PostPosted: Thu Mar 17, 2011 2:32 am    Post subject: Europa Classic cooling hoses Reply with quote
Dear Europa family,
Walter Swoboda needs for his Classic Monowheel with Rotax 912 new cooling hoses, especially the 180° bended outlet hose. But better would be to replace the inlet hose too.
EA/UK do not have them. Some weeks ago there was a discussion and a result, where you can get these hoses – when I remember right.
Please help out.
Best Regards,
Bruno Reith / Europa Aircraft Germany
frans(at)privatepilots.nl
PostPosted: Thu Mar 17, 2011 4:42 am    Post subject: Europa Classic cooling hoses Reply with quote
Stefan Ingemarsson, also a member of the Europa community, sells
silicone hoses for both the XS and the classic Europa.
His email is ingemarsson.s at telia.com
I just received a set of silicone hoses for my XS from him. I'm not an
expert on hoses but these hoses look ok to me. I hope they don't age as
much as rubber hoses, and they are more heat resistant. And some people
like the blue color (although I usually fly with the cowling securely
closed). If I'm correctly informed, these hoses don't need to be
replaced every five years.
Frans
roger(at)middlecave.plus.
PostPosted: Fri Mar 18, 2011 3:37 am    Post subject: Europa Classic cooling hoses Reply with quote
Hi Bruno,
The factory does have stock of the hoses Walter needs. There were plenty when I retired, and I checked with Karen yesterday that they are still available.
From memory the part numbers are C01 and C02 (C03 is an oil hose).
Hope that helps.
Roger
