Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Thu Mar 17, 2011 7:25 am Post subject: Power for Checking Systems Out on the Ground |
| Quote: | > http://cgi.ebay.ca/13-5V-DC-25-8A-350W-Regulated-Switching-Power-Supply-/150471439243?pt=LH_DefaultDomain_0&hash=item2308cbf38b
I used about a half dozen of various models in projects
over the last two years. Got two of them on the bench right
now. Just be careful when hooking these guys across batteries.
Some of these products don't like to be reverse powered when
their ac input power is removed. I use a fat schottky in
series with the output to prevent tug-o-war issues. This
means you might want to order the next higher voltage
next time . . . but there's one resistor you can change
inside that will boost the output if necessary.
I don't plan on connecting it in parallel with a battery, but this is
an important point. I stuck a label on the power supply to remind me,
in case I get different ideas a few years from now. Thanks.
Jeff Page
Dream Aircraft Tundra #10
