n345js(at)verizon.net Guest
Posted: Sat Mar 12, 2011 3:49 pm Post subject: starter does not turn the prop |
Sometimes when I turn the ignition key on my Rotax 912UL, the starter makes no sound and does not turn the prop. When I turn the prop to a new position by hand, it cranks normally. Someone said worn brushes. Does that mean the starter motor needs to be removed an overhauled? Is this a gradual deterioration (only happened 3 times) or will it soon not crank in any prop position?
What issues will I find removing the starter? Any special tools, warnings, obstacles, etc?? Should I send it to Lockwood Aviation? Thanks
John Schussler
N345JS, Pulsar XP, flying 10 years
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
mortweaver(at)sbcglobal.n Guest
Posted: Sun Mar 13, 2011 5:57 am Post subject: starter does not turn the prop |
The problem you are describing sounds like you are experiencing is due worn out brushes on the starter motor. If the brushes are not of good quality (low density material) or the armature commutator segments are eroded from electrical arching, then premature failure of the starter motor can be experienced. Never replace brushes on any motor without first carefully examining the armature commutator segments for a Britte clean surface less any eroded or blackened segment surfaces. If you seek out a local electrical motor shop that services and performs motor repair, you will learn some very useful service tips that will be useful in dealing with trouble shooting compressor, heat/cooling applications etc. The Internet also provides a wealth of information on servicing just about anything.
Dave Weaver
--- On Sat, 3/12/11, John Schussler <n345js(at)verizon.net> wrote:
Subject: starter does not turn the prop
To: pulsar-list(at)matronics.com
Date: Saturday, March 12, 2011, 5:46 PM
John Schussler
el=nofollow target=_blank>http://www.matronics.com/Navigator?Pulsar-List
| [quote][b]
