Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Wed Mar 16, 2011 12:27 pm Post subject: Bob Nuckolls - advice |
Bob,
I realise I should test for myself, but thought it might apply to others:
I am using a DB25 female and male pair for quick disconnect to accommodate up to #18 wire runs for future circuits in my instrument panel. [The whole panel OR each sub-panel is meant to be dismountable].
Since it will hold up to 12 + and – runs, I measured the male pins at 0.04 inches in diameter from the pack of 100, labelled as `S604P’. These are solid, not stamped pins and sockets.
Can I consider these to carry a constant 4 amps if not bundled tightly together? AND could I parallel a set of three to carry a constant 10A in similar circumstances?
I would like to know I’m operating in a`conservative’ milieu and don’t plan to run cfuture equipment at greater than 10A.
Cheers, Ferg
Posted: Wed Mar 16, 2011 7:43 pm Post subject: Bob Nuckolls - advice |
At 04:16 PM 3/16/2011, you wrote:
| Quote: | Bob,
I would like to know I’m operating in a`conservative’ milieu and don’t plan to run cfuture equipment at greater than 10A. |
That works. When I qualified paralleled d-sub pins
onto this vehicle
http://aeroelectric.com/Pictures/Misc/GQM_1st_Ops_Flight.jpg
I had to suffer the indignities of 70C environment at
full electrical loads. I de-rated the pins to 3A, paralleled
6 pins and handled three 20A input output pathways
on this solid state relay box.
http://aeroelectric.com/Pictures/Misc/GQM_Power_Dist.jpg
So your suggestion of 3 pins to handle 10A is
as conservative that which flies at Mach 3
and 15 feet off the water. Things get really
warm on the launch stand . . . and warmer still
in flight through dense air.
Just keep your airplane below M3 and I think
you'll be just fine. I presume you understand
the necessity for 'ballasting' resistors in the
form of 12" of 22AWG in each pin path?
Bob . . . [quote][b]
