flap drive pin engagement
kees de bussy
PostPosted: Tue Mar 08, 2011 5:07 am    Post subject: flap drive pin engagement Reply with quote
In my case the flap drive pins engagement comply with the service bulletin on that matter but at the portside it is at the limit. So I decide the bring it well within the limits and I purchased the special bearing housing from Europa Aircraft.
I have now a problem to remove the original housing and bearing from the x-tube. The x-tube end was heated with a hot air gun (air of 600 degr. C / 1110 degr. F) but I could not get any movement of the bearing housing.
Has anybody experience in removeing the bearing housing from the X-tube ? Any ideas are welcome.
Kees de Bussy
PH-SBR
dpark748(at)hotmail.co.uk
PostPosted: Tue Mar 08, 2011 6:40 am    Post subject: flap drive pin engagement Reply with quote
Replaced my bearing housings with heat gun, and turned bearing with mole and levered with screwdriver on edge - no problem.
Dave G-LDVO
> Subject: flap drive pin engagement
Date: Tue, 8 Mar 2011 05:07:30 -0800
--> Europa-List message posted by: "kees de bussy" <keesdebussy(at)hotmail.com>
Kees de Bussy
PH-SBR
http://forums.matronics.com/viewtopic.php?p=333147#333147
&gt================
kees de bussy
PostPosted: Wed Mar 09, 2011 2:18 am    Post subject: Re: flap drive pin engagement Reply with quote
Thanks Dave for your input. I will give it another try. It sounds if you did not needed a lot of force to make it move. Is that correct ? Kees de Bussy PH-SBR
PostPosted: Wed Mar 09, 2011 2:43 am    Post subject: flap drive pin engagement Reply with quote
Just needed heat gun and gripped the edge of the housing with mole wrench and turned, once loose can be levered and turned out easily.
Dave
> Subject: Re: flap drive pin engagement
Date: Wed, 9 Mar 2011 02:18:47 -0800
http://forums.matronics.com/viewtopic.php?p=333295#333295
&gt Archive Search & Download, 7-Day Browse, Chat, FAQ,
&gt===
PostPosted: Wed Mar 09, 2011 10:43 am    Post subject: flap drive pin engagement Reply with quote
correct,
Dave
&gt===
jrgowing(at)bigpond.net.a
PostPosted: Thu Mar 10, 2011 4:01 pm    Post subject: flap drive pin engagement Reply with quote
David Park
Would you please quote what Service Bulletin No refers, and your kit number so we can see if this concerns other builders?
JR (bob) Gowing Kit no 327 in Oz
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of david park
Sent: Wednesday, 9 March 2011 1:37 AM
Subject: RE: flap drive pin engagement
Dave G-LDVO
From: keesdebussy(at)hotmail.com (keesdebussy(at)hotmail.com)
--> Europa-List message posted by: "kees de bussy" <keesdebussy(at)hotmail.com (keesdebussy(at)hotmail.com)>
Kees de Bussy
PH-SBR
Checked by AVG - www.avg.com
Version: 10.0.1204 / 03/09/11
Ivor Phillips
PostPosted: Fri Mar 11, 2011 1:27 am    Post subject: flap drive pin engagement Reply with quote
Hi Bob
the Service Bulletin is SB 16
find PDF file attached
Ivor
On 10 March 2011 23:57, JR Gowing <jrgowing(at)bigpond.net.au (jrgowing(at)bigpond.net.au)> wrote:
David Park
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of david park
Dave G-LDVO
Subject: Europa-List: flap drive pin engagement
Kees de Bussy
PH-SBR
Sb_16.pdf
 Filename:  Sb_16.pdf
 Filesize:  9.14 KB
 Downloaded:  390 Time(s)
PostPosted: Fri Mar 11, 2011 3:48 am    Post subject: flap drive pin engagement Reply with quote
Bob,
Someone else has quoted the SB No.  I changed mine during build when I had to adjust length of cross tube.
Dave
Date: Fri, 11 Mar 2011 10:57:23 +1100
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle20 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page WordSection1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxWordSection1 {page:WordSection1;}
David Park
Subject: RE: Europa-List: flap drive pin engagement
Dave G-LDVO
Kees de Bussy
PH-SBR
8 [quote][b]
PostPosted: Fri Mar 11, 2011 6:26 pm    Post subject: flap drive pin engagement Reply with quote
Thank you Ivor!
Now I can find it in my records. I remembered the issue from what seems like a long time ago.
I wlll now be able to put my finger on what I did.
Bob Gowing kit 327 in Oz
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of PHILLIPS I
Sent: Friday, 11 March 2011 8:24 PM
Hi Bob
Ivor
David Park
Dave G-LDVO
Kees de Bussy
PH-SBR
http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution
arget="_blank">http://www.matronics.com/Navigator?Europa-Listttp://forums.matronics.com
Version: 10.0.1204 / 03/11/11
PostPosted: Sat Mar 12, 2011 3:38 pm    Post subject: flap drive pin engagement Reply with quote
Thank you Dave!
Yes it is on my “to do” list and I have not mounted the wings since the service bulleting was issued!
No I won’t lose the list!
JR (Bob) Gowing UK Kit 327 in Oz
Sent: Friday, 11 March 2011 10:45 PM
Bob,
Dave
David Park
Dave G-LDVO
Kees de Bussy
PH-SBR
target=_blank>http://www.matronics.com/Navigator?Europa-Listttp://forums.matronics.com
5
6
7
8
9
