FS: Nearly Completed RV-10 Project (DFW)
2eyedocs
PostPosted: Wed Mar 02, 2011 8:55 pm    Post subject: FS: Nearly Completed RV-10 Project (DFW) Reply with quote
Excellent workmanship throughout with professional assistance from an A&P. Kit includes many extras including new Hartzell Constant Speed 2 blade metal Prop, new Vetterman exhaust for Lycoming IO-540, all Position Lights and Strobes, Antennas, Safety-Trim speed sensitive controller, FWF kit with Throttle Quadrant, etc., etc. Metal work completed including Controls (Yoke, Ailerons, Elevator, Rudder, etc.), Fuel tanks, Fuel Lines, Gear, Brakes and Brake Lines and kit Interior. Most Fiberglass work completed including Cabin top mated to fuse, Doors installed and fitted, Wing Tips, Rudder Tip, etc. Wiring to wings and fuse completed to Wing Tip Lighting, AP servos, Heated Pitot, etc. Wheel Pants and Gear Fairing are not competed. Heated Pitot installed and plumbed, Static Ports installed and currently working on static plumbing to the panel. You will have personal choice on buying Avionics, Engine and Interior Finish-Out.
Excellent Opportunity!!
Get a major head start towards First Flight with a wonderful aircraft for close to the price of parts. Asking $79,000, willing to negotiate. Contact Mark at 2eyedocs(at)gmail.com or 817-915-7294. Some pics may be seen at:
https://picasaweb.google.com/2eyedocs/RV10Build#
Partial Inventory List Attached:
RV-10 - Kit Inventory List.pdf
 Filename:  RV-10 - Kit Inventory List.pdf
 Filesize:  215.13 KB
 Downloaded:  577 Time(s)
