rowlandcarson(at)gmail.co Guest
Posted: Sat Feb 26, 2011 8:51 am Post subject: tp9/tp10 retention |
I am just about to fettle up the tailplane torque tube holes and bond the bearings into the fuselage, but I thought I remembered that there was some talk a while back of an improved TP9/TP10 retention mod, maybe even a factory approved scheme (as opposed to Bob Harrison's and Phil Tunney's clamps, and the factory Loctite approach). Am I dreaming or can anyone point me in the right direction?
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
g-iani(at)ntlworld.com Guest
Posted: Sat Feb 26, 2011 11:25 am Post subject: tp9/tp10 retention |
Rowland
I have attached a copy of the review I did for LAA/Europa of the options.
Since then I have obtained details of two more variations
| Quote: | From Richard Collings and John Baker. If you would like these I will send
them direct to you.
As you know (ie SB15 issued) the decision was to glue the joint. After that
nobody was prepared to invest any time in developing a Europa fix.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
TT_Pins_Options.pdf |
133.84 KB |
633 Time(s) |
Patrick Tunney
Posted: Sat Feb 26, 2011 1:09 pm Post subject: Re: tp9/tp10 retention |
Rowland
My adaption of Bob Harrison's torque tube clamp has now been approved by the LAA as a standard Mod (11906).
The Mod is currently fitted to 1 flying aircraft, 1 ready for test flight and two others in the build stage.
Europa have now re-designed the torque tube.
Best Regards
Pat Tunney
www.europaxs.com
jan_de_jong(at)casema.nl Guest
Posted: Sat Feb 26, 2011 2:34 pm Post subject: tp9/tp10 retention |
Rowland,
I have a set of Bob Harrison's torque tube clamps - not fitted yet, so I
thought I 'd weigh them for you: about 300g each.
I think it's worth it but you may - reasonably I suppose - think
differently.
Jan de Jong
Ivor Phillips
Posted: Sun Feb 27, 2011 2:15 am Post subject: tp9/tp10 retention |
Rowland
I have had a set of Bob Harrison's torque tube clamp's fitted for three years and 300 hours and there isn't any movement
in the pins and i know i can easily remove the tube for maintenance if necessary,
I am very glad that they are more or less a fit and forget feature,
just my two penny's worth!
Ivor Phillips
On 26 February 2011 22:27, Jan de Jong <jan_de_jong(at)casema.nl (jan_de_jong(at)casema.nl)> wrote:
[quote]--> Europa-List message posted by: Jan de Jong <jan_de_jong(at)casema.nl (jan_de_jong(at)casema.nl)>
Rowland,
I have a set of Bob Harrison's torque tube clamps - not fitted yet, so I thought I 'd weigh them for you: about 300g each.
I think it's worth it but you may - reasonably I suppose - think differently.
Jan de Jong
ist Un/Subscription,
www.matronics.com/Navigator?Europa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
Matt Dralle, List Admin.
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Sun Feb 27, 2011 2:31 pm Post subject: Re: tp9/tp10 retention |
Rowland,
Pat Tunny's clamps are the way to go for my build. I did not need to drill the white nylon bush, as it may take a few attempts and in doing so you run the risk of making the TT holes bigger and this is where the unwanted movement is started. With Pat's clamps you set up the whole thing in one go, that includes the brass bushes too. then your dun. NO DRILLING. Easy and solid.
Richard
Posted: Tue Mar 01, 2011 7:36 am Post subject: tp9/tp10 retention |
On 26 Feb 2011, at 19:22, G-IANI wrote:
| Quote: | I have attached a copy of the review I did for LAA/Europa of the options
Ian - thanks very much for that document - very useful and comprehensive.
| Quote: | Since then I have obtained details of two more variations
them direct to you.
Yes, please!
| Quote: | As you know (ie SB15 issued) the decision was to glue the joint. After that
I had a message direct from Michel Auvray commending the glue method, but saying DON'T use Loctite 603. I will ask him why not, and what type he proposes instead.
In reviewing SB15 I don't seem to be able to find a copy of "PFA FSB- 006 issue 4" that specifies the inspection intervals. I though it would be in the Engineering part of the LAA website but I can't locate it.
Thanks again for your help.
in friendship
Rowland
Posted: Tue Mar 01, 2011 7:52 am Post subject: tp9/tp10 retention |
On 26 Feb 2011, at 21:09, Patrick Tunney wrote:
| Quote: | My adaption of Bob Harrison's torque tube clamp has now been approved by the LAA as a standard Mod (11906).
Pat - thanks for the info, and apologies for calling you Phil before - I was confusing you with another PT.
| Quote: | Europa have now re-designed the torque tube
I've not heard about this - how does the new design differ? As I've not bonded mine in yet, I might consider buying the new design. I have incorporated Factory Mod 62 (3/8" pins TP14) but would definitely consider a better engineering approach.
in friendship
Rowland
flyingphil2
Posted: Tue Mar 01, 2011 8:55 am Post subject: Re: tp9/tp10 retention |
Hi Rowland,
With regards to the new re-designed torque tube then I have one of these. As Roger put it to me, the new torque tube no longer has any torque.
Basically the whole design has been beefed up and there are now only 2 pins involved, not 4, see attached photo.
My main concern when I received this was the weight increase. My numbers are below:
Old Tube:
TP4 - 1350g
2 x TP5 & TP6 - 270g
TP9 - 200g
2 x TP12 - 800g
Total = 2.620kg or 5.776lb
New Tube:
TP4 - 1330g
2 x TP5 & TP6 - 330g
TP9 - 1250g
2 x TP12 - 1060g
Total = 3.970kg or 8.752lb - 52% above original.
NB. (Pat Tunney's clamps would add 0.4kg bringing an original assembly to 3.0kg).
My mind was originally put at rest when I was told that monos (or conventional taildraggers as my aircraft is likely to be) like having an aft c of g and so this additional weight at the back would be ok. I tried not to think about it too much and decided it would be ok ......
Hope that helps.
Phil
599.39 KB |
15355 Time(s) |
peterz(at)zutrasoft.com Guest
Posted: Tue Mar 01, 2011 9:26 am Post subject: tp9/tp10 retention |
Wouldn't the same issue with hammering out of the holes (if not an interference fit) still apply to the two drive pins?
Just curious,
Pete
A239
On Tue, Mar 1, 2011 at 11:56 AM, flyingphil2 <ptiller(at)lolacars.com (ptiller(at)lolacars.com)> wrote:
[quote]--> Europa-List message posted by: "flyingphil2" <ptiller(at)lolacars.com (ptiller(at)lolacars.com)>
Hi Rowland,
Old Tube:
TP4 - 1350g
TP9 - 200g
2 x TP12 - 800g
New Tube:
TP4 - 1330g
TP9 - 1250g
2 x TP12 - 1060g
Hope that helps.
Phil
http://forums.matronics.com/viewtopic.php?p=332375#332375
http://forums.matronics.com//files/torque_tube_2_109.jpg
le, List Admin.
pete(at)lawless.info Guest
Posted: Tue Mar 01, 2011 9:35 am Post subject: tp9/tp10 retention |
Phil
You could always put the battery in the original position under the cowling
on top of the foot well. That would save you a great length of thick copper
cable.
Pete
mau11(at)free.fr Guest
Posted: Tue Mar 01, 2011 9:36 am Post subject: tp9/tp10 retention |
Le 01/03/2011 18:18, Peter Zutrauen a écrit : | Quote: | Wouldn't the same issue with hammering out of the holes (if not an interference fit) still apply to the two drive pins?
Just curious,
Pete
A239
| Quote: | --> Europa-List message posted by: "flyingphil2" <ptiller(at)lolacars.com (ptiller(at)lolacars.com)>
Hi Rowland,
Old Tube:
TP4 - 1350g
TP9 - 200g
2 x TP12 - 800g
New Tube:
TP4 - 1330g
TP9 - 1250g
2 x TP12 - 1060g
Hope that helps.
Phil
le, List Admin.
| | Hi Phil,
Do you nhave pictures of a new design?
[quote]--
Michel AUVRAY
l
-----(*)-----[b]
richard.churchill-coleman Guest
Posted: Tue Mar 01, 2011 9:46 am Post subject: tp9/tp10 retention |
Hi Phil
I received a mono kit from Roger in late 2007 and I'm ashamed to say that I haven't touched the torque tube yet to know if it is the heavier version you describe - and I haven't seen a revised build manual or Mod 73 exemption that would take it into account - please can you tell me when did you get the new version from Roger, to give me a guide as to whether mine might be the new version with my kit?
regards
Richard
On 1 March 2011 16:56, flyingphil2 <ptiller(at)lolacars.com (ptiller(at)lolacars.com)> wrote:
Hi Rowland,
Old Tube:
TP4 - 1350g
TP9 - 200g
2 x TP12 - 800g
New Tube:
TP4 - 1330g
TP9 - 1250g
2 x TP12 - 1060g
Hope that helps.
Phil
http://forums.matronics.com====
="http://www.matronics.com/Navigator?Europa-List" target="_blank">http:=====
http://forums.mle, List Admin.
flyingphil2
Posted: Wed Mar 02, 2011 4:57 am Post subject: Re: tp9/tp10 retention |
Hi,
In response to other postings:
The thickness of the material involved is greatly increased. I guess the 2 pins may eventually wear the holes and introduce play but I think the rest of the aeroplane may have worn out long before.
Michel - picture attached with my posting.
Richard - I purchased my Torque tube early last year and I think the design had been around for a while before (at least 6 months). If you could post a picture of your tube then I/the forum could easily identify what type it is.
Phil
Posted: Wed Mar 02, 2011 5:25 am Post subject: tp9/tp10 retention |
Hi Phil,
Please excuse my lack of part number knowledge, but using descriptions instead:
- the center pushrod/counterweight driven assembly does indeed look thicker - and no longer stainless steel?
- the tailplane drive assemblies however look similar to the the original ones as far as material thickness is concerned... do they indeed have significantly thicker gauge tubes?
Cheers & thx,
Pete
A239
On Wed, Mar 2, 2011 at 7:57 AM, flyingphil2 <ptiller(at)lolacars.com (ptiller(at)lolacars.com)> wrote:
[quote] --> Europa-List message posted by: "flyingphil2" <ptiller(at)lolacars.com (ptiller(at)lolacars.com)>
Hi,
Phil
http://forums.matronics.com/viewtopic.php?p=332467#332467
le, List Admin.
flyingphil2
Posted: Wed Mar 02, 2011 7:26 am Post subject: Re: tp9/tp10 retention |
Hi Peter,
You would have to check with the factory on this but:
1. Centre section (originally TP9) is beefed up and on the grounds that it is zinc plated, it won't be stainless steel.
2. The tailplane drive assemblies (TP12) are heavier according to my numbers and so yes, they are a thicker gauge. Not sure how much thicker.
Phil
roger(at)middlecave.plus. Guest
Posted: Thu Mar 03, 2011 6:13 am Post subject: tp9/tp10 retention |
Hi Richard,
Although now retired I still follow the forum, so I noticed your query.
The new torque tube only came in shortly before I retired at Xmas 2009, say mid 2009 from memory, so yours will definitely not be the new heavier one.
Best wishes for the build,
Roger Bull
Posted: Thu Mar 03, 2011 10:07 am Post subject: tp9/tp10 retention |
Le 03/03/2011 15:10, Roger Bull a écrit : [quote] Hi Richard,
Roger Bull
kingsnjan(at)westnet.com. Guest
Posted: Thu Mar 03, 2011 8:01 pm Post subject: tp9/tp10 retention |
G'day Roger, greetings from Oz. Nice to know your'e still lurking on the list. Now please tell me retirement is good . . . . mine is very imminent too!
Cheers
Kingsley
