graeme bird
Posted: Mon Feb 21, 2011 4:56 am Post subject: rudder pedal pads and heel plate |
I have been looking for some pictures to show what I should do to make some rudder pedals - don't much like the pipe - too narrow, shall I just make some wood or aluminum blocks and self tap screw on. Also I think I have seen plates at the bottom for ones heels, is that the thing to do?
Help appreciated
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
kevinmarie(at)blueyonder. Guest
Posted: Mon Feb 21, 2011 5:17 am Post subject: rudder pedal pads and heel plate |
Graeme
I know what you mean looking at the standard rudder pedals. I thought the same but in use I have never had a problem. They are fine.
Kevin
On 21 Feb 2011, at 12:56, "graeme bird" <graeme(at)gdbmk.co.uk> wrote:
Help appreciated
Graeme Bird
http://forums.matronics.com/viewtopic.php?p=331706#331706
steven.pitt2(at)ntlworld. Guest
Posted: Mon Feb 21, 2011 6:26 am Post subject: rudder pedal pads and heel plate |
Graeme
Sorry can't remember where you are based but I used two footplates produced
by Ripspeed in the UK. They are lightweight aluminium and have ridges and
holes for fitting to the pedals - non slip and ideal for the Europa. The
only problem is you have to buy them in 3s as they are for cars.
Steve Pitt
G-SMDH
Posted: Mon Feb 21, 2011 6:36 am Post subject: rudder pedal pads and heel plate |
A picture tells a thousand words.
Steve Pitt
1022.28 KB |
3963 Time(s) |
Posted: Mon Feb 21, 2011 6:53 am Post subject: rudder pedal pads and heel plate |
Hi! Graham.
The rudder pedals (crude though they look) work just fine ....if it "ain't
broke don't fix it" with more weight !
Bob Harrison.
