Float Flyr
Posted: Fri Feb 18, 2011 3:38 pm Post subject: LED question |
Bob: is it OK to wire an LED directly (through a resistor in series) to a 14V system? Or should a voltage reduction circuit/device be used. I always though most LEDs were supposed to work on 5V. And 14V would be too much.
Noel
Sent: February 18, 2011 11:25 AM
Subject: Re: "Starter Engaged" Warning Light Circuit Refresher
At 10:34 PM 2/17/2011, you wrote:
--> AeroElectric-List message posted by: Bob Falstad <bobair(at)me.com>
Bob N.,
I'm putting a "starter engaged" warning light in my new IFR panel. I simply hooked the incandescent bulb from my B&C alternator "low voltage" warning light between a fused wire that runs from the hot side of the starter contactor and ground. (I now have the standby B&C alternator and will use its controller's "standby alternator on" light in lieu of the low voltage light on the primary alternator controller.)
But then I ran across a handwritten sketch that I believe you drew up for this circuit. It has a 470 Ohm - 1 Watt resistor in the wire between the hot side of the starter contactor and the lamp. It also shows a 1N4001 protection diode in parallel with the lamp and ground. It isn't clear from your sketch (and my electrical symbols knowledge is limited) whether the lamp is incandescent or an LED.
This is an incandescent lamp
This is an Light Emitting Diode
The resistor used with the LED warning circuit as
sketched serves a dual purpose. It protects the wire
that runs from starter to lamp by limiting the maximum
current that could flow in a faulted wire. At the same
time, it SETS the current intended to illuminate the
LED.
For an incandescent warning light, the resistor is
replaced with a fuse and the incandescent lamp is
substituted for the LED. No reverse current diode
is needed.
8.64 KB |
1481 Time(s) |
8.05 KB |
1481 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Feb 18, 2011 4:21 pm Post subject: LED question |
At 06:20 PM 2/18/2011, you wrote:
| Quote: | Bob: is it OK to wire an LED directly (through a resistor in series)
LED's are CURRENT driven devices. They do drop 2-3 volts
across the device while illuminated (depending on color)
but they can be BIASED up to run at ANY voltage greater
than 3 volts by selection of the series resistor . . . which
is the purpose of the 470 ohm resistor in the sketch. With
9-12v applied to the starter and 2v dropped across the
LED leaves 7 to 10 volts drop across the 470 ohm resistor.
This translates to an LED operating current on the order of
(7/470) 15 to (10/470) 21 milliampers.
