Roger Lee
Posted: Thu Feb 17, 2011 2:42 pm Post subject: How to mount a tire the easy way. |
Hi All,
Here is the easy way to mount a tire on the wheel. You will use a lot less choice words and do it in 1/4th the time.
I have been doing it this way for the last several years and the nice people at Matco made a nice picture for everyone.
Enjoy
| Mounting a tire made easy |
How to mount a tire the easy way.pdf |
422.11 KB |
542 Time(s) |
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
thesupe(at)hotmail.com Guest
Posted: Thu Feb 17, 2011 7:42 pm Post subject: How to mount a tire the easy way. |
Good one Roger, so simple but yet so effective. Of course now though I have to buy one more clamp! LOL Take care, Jim Chuk
PS keep those tips comming! Thanks!
> Subject: How to mount a tire the easy way.
| Quote: | ======================
Thom Riddle
Posted: Fri Feb 18, 2011 4:48 am Post subject: Re: How to mount a tire the easy way. |
That is clever.
I have had tires so difficult to remove from the rim half that my 280 lb mechanic partner standing on the tire could not break the bead. So we built a tool using pieces of 5/8" plywood with a circular hole just larger than the wheel rim diameter plus a piece of all-thread, plus clamp bars and nuts to squeeze the tire off the rim. Works well but this seems a bit simpler.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
williamtsullivan(at)ATT.N Guest
Posted: Fri Feb 18, 2011 4:58 am Post subject: How to mount a tire the easy way. |
Don't forget to lube the tire and rim with a bit of soapy water, for on or off.
Bill Sullivan
Windsor Locks, Ct.
Kolb FS 447
--- On Fri, 2/18/11, Thom Riddle <riddletr(at)gmail.com> wrote:
That is clever.
I have had tires so difficult to remove from the rim half that my 280 lb mechanic partner standing on the tire could not break the bead. So we built a tool using pieces of 5/8" plywood with a circular hole just larger than the wheel rim diameter plus a piece of all-thread, plus clamp bars and nuts to squeeze the tire off the rim. Works well but this seems a bp; --> http://www.matronics.com/Navigator?RotaxEngines-; - MATRONICS WEB FORUMS -http://www.matronics.c===================
blackmore(at)platinum.ca Guest
Posted: Fri Feb 18, 2011 6:10 am Post subject: How to mount a tire the easy way. |
gpabruce(at)gmail.com Guest
Posted: Fri Feb 18, 2011 10:34 am Post subject: How to mount a tire the easy way. |
Separating a tire from the rim on small aircraft:
As a Vintage A&P and having changed out many tires and my preferred method was relatively simple and effective. I used two large heavy bladed and blunt screw drivers, not your watch repair screwdrivers, more like heavy equipment type screw drivers . . .the bigger and dumber the better . . . Then I would squat and put my knees on both sides of the "deflated" tire. A little soapy water is always good too. Then I would just work my way around the tire a little at a time, pushing in the screwdrivers in and prying a little each time. It was more Neanderthal than NASA but it works.
On Fri, Feb 18, 2011 at 4:11 AM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]Roger:
INTERESTING....
I have never had a problem mounting a tire to a wheel...
Where I have problems is separating the tire from the wheel. Especially if it has been on for a long time.
I guess I could use the clamps, if I had clamps.
Andy tricks if one does not have clamps?
Yea, Yea, I know - - Buy clamps.
What I have used successfully (but not what I would suspect is the easiest method) is just a 2 ft long 2x4 across the tire and stand on it.
Any other suggestions?
Barry
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
ttp://forums.matronics.com
| [b]
KeysFox
Posted: Sat Feb 19, 2011 12:11 pm Post subject: How to mount a tire the easy way. |
I gave up trying to demount two really old tires on roughly 1991 vintage
Kitfox (Douglas) wheels and resorted to cutting a section of the tire down
to the wheel rim then cutting thru the metal wires in the bead of the tire
with a carbide bur in a dremel tool.
The wires in the bead made a serious "pop" as I cut thru the last one.
Being a retired dentist this seemed prettly easy to do without damaging
the aluminum wheel but it ruined the carbide bur.
BJ
Kitfox IV N143K
PA 39 N626NR
That is clever.
simpler.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
Don't accept your dog's admiration as conclusive evidence that you are
wonderful.”Â
—Ann Landers
http://forums.matronics.com/viewtopic.php?p=331397#331397
_________________ B Jones
N154K
443-480-1023 |
pchristensen10(at)austin. Guest
Posted: Sat Feb 19, 2011 12:35 pm Post subject: How to mount a tire the easy way. |
Here's how I dismounted some difficult tires. I removed the wheel and
tire from the plane. Then I took them to a tire shop. That was so easy.
(I just can't help being a smart ass.)
Pete
Leander Tx
Kitfox III, 912,
On 2/19/2011 2:01 PM, bjones(at)dmv.com wrote:
BJ
Kitfox IV N143K
PA 39 N626NR
> That is clever.
> simpler.
> Thom Riddle
> Buffalo, NY (9G0)
> Jabiru 2200A #1574
> wonderful.”Â
> —Ann Landers
