AOA indicator
Goto page 1, 2  Next
mrspudandcompany(at)veriz
PostPosted: Fri Feb 11, 2011 8:44 am    Post subject: AOA indicator Reply with quote
What effect does icing have on the accuracy of an AOA indicator? Will it
give you an accurate indication of an impending stall if you have
accumulated ice on the wing leading edge?
Roger
PostPosted: Fri Feb 11, 2011 9:24 am    Post subject: AOA indicator Reply with quote
At 11:24 AM 2/11/2011, you wrote:
<mrspudandcompany(at)verizon.net>
No . . . . Most AOA displays don't give you
an 'angle' display. They generally display bands
of relative goodness/badness shaded in legacy red, yellow
and green. The display will probably be fitted with a
'sweet spot' . . . which represents an AOA value
optimized by much flight testing.
The problem is that the any sweet spot assumes that
the wing is clean and stall breaks at xx.x degrees.
Just lowering flaps can give you a new sweet spot at
yy.y degrees. The more sophisticated AOA display
systems will have inputs for flap position so that
the sweet spot is automatically moved to a new value
confirmed by careful flight testing.
Once you add ice shapes on top of those super whippy,
laminar flow, high efficiency, low drag, etc etc
air foils, the stall break moves to zz.z degrees.
Unless iced over, the AOA sensor will continue to
give you an accurate AOA display. The problem is
that any knowledge the AOA possesses with respect
to airplane performance is now suspect.
It's not a loss of display integrity that bites.
It's a departure from performance conditions under which
IAS or AOA sweet spots were deduced.
email(at)jaredyates.com
PostPosted: Fri Feb 11, 2011 9:27 am    Post subject: AOA indicator Reply with quote
Generally, no, it will not give accurate information.  A wing that used to stall at 13 degrees might stall at 10 or 8 with ice (for instance, these aren't necessarily accurate numbers).  In fact, this has been a source of at least a few crashes of transport category airplanes that stalled on takeoff without activation of the stall protection systems.  Ice accumulation combined with an aggressive rotation rate and the ground effect were sufficient to push the stall AOA below the thresholds for the stick shaker and pusher, so in some cases the crews didn't even get any indication that the airplane was stalled, other than the sudden 90 degree bank angle.  An AOA indicator might or might not indicate degrees AOA correctly, but even if it does, it's information doesn't mean anything, since you don't know what the stall AOA is of your "new" experimental airfoil shape.
On Fri, Feb 11, 2011 at 11:24 AM, ROGER & JEAN CURTIS <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
[quote]--> AeroElectric-List message posted by: "ROGER &  JEAN CURTIS" <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)>
Roger
http://forums.matronics.com
le, List Admin.
dee.whittington(at)gmail.
PostPosted: Sat Feb 12, 2011 5:55 am    Post subject: AOA indicator Reply with quote
Even though what Bob says about the critical angle of attack changing with the accretion of ice is, of course, correct, it would be good to have an AOA indicator which was not killed by ice. I just remembered that our new Grand Rapids HX (and in fact all new Grand Rapids EFIS units) now have a "AOA Indexer" built in. They display angle of attack on the left side of the screen derived from, I think, AHARS data, not from unheated pin holes in the wing.
Unfortunately, the GRT web site currently does not explain, or even mention this new feature. I've just brought this to the attention of Carlos Fernandez at GRT and he promised to update the web site.
Dee
At 11:19 AM 2/11/2011, you wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
--> AeroElectric-List message posted by: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
AeroElectric-List Email Forum -
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
DeWitt (Dee) Whittington
406 N Mulberry St
Richmond, VA 23220-3320
(804) 358-4333 phone and fax
SKYPE: hilltopkid
dee.whittington(at)gmail.com [quote][b]
PostPosted: Sat Feb 12, 2011 7:59 am    Post subject: AOA indicator Reply with quote
How does it matter where and how some AOA value is
measured or synthesized once the wing is iced?
I was once enamored of the delta-p AOA sensor
designs. There have been a number of articles
published on the technique. I've posted a collection
of my archived articles at:
http://www.aeroelectric.com/articles/Angle_of_Attack/
There was an article in a Sport Aviation issue in
2005 for a DIY AOA sensor/display package. Anyone
got a copy in their library? I'd sure like to
read a copy.
The common thread that runs through these articles
is an absence of discussion as to when the readings
so carefully calibrated and displayed are not
to be trusted.
pwmac(at)sisna.com
PostPosted: Sat Feb 12, 2011 9:08 am    Post subject: AOA indicator Reply with quote
Interestinb, but production units are out there.
Lets not ignore what Elbie said about the AOA in icing contitions.
For sure he is the guru on these devices for all kinds of airplanes
http://www.riteangle.com/
PaulW
read a copy.
to be trusted.
PostPosted: Sat Feb 12, 2011 10:31 am    Post subject: AOA indicator Reply with quote
Yup, lots of them . . .
But what do YOU understand and are willing to pass
along to the less informed as to the value of
and AOA sensor and display system? What statements
have been made by myself or anyone else that you
find in error? Is it your understanding that Elbie
claims that the "sweet spot" on his or any other
AOA display is golden under all challenges that
a pilot might face for comfortable arrival with
the earth?
retasker(at)optonline.net
PostPosted: Sat Feb 12, 2011 12:42 pm    Post subject: AOA indicator Reply with quote
If you are an EAA member you can see ALL back issues of Sport Aviation
on http://www.oshkosh365.org
If that doesn't do it for you I do have the 2005 issues but I would have
to see what issue it was in. Do you remember what month?
Dick Tasker
read a copy.
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
pwmac(at)sisna.com
PostPosted: Sat Feb 12, 2011 2:05 pm    Post subject: AOA indicator Reply with quote
I do noy have his message, but it went like any chance of icing
forget about the aoa As the readings will be bad..
PaulW
the earth?
kuffel(at)cyberport.net
PostPosted: Sat Feb 12, 2011 5:09 pm    Post subject: AOA indicator Reply with quote
<< How does it matter where and how some AOA value is measured or
synthesized once the wing is iced? >>
The Dynon AOA sensor is a single heated probe with two holes which replaces
the standard pitot sensor. It has temperature control so you just leave it
on all the time. Thus is it relatively immune to icing. This means I will
have one less distracter when I follow Bob's (and others) great advice to
get the heck out of wherever I am if ice is encountered.
Tom Kuffel
PostPosted: Sat Feb 12, 2011 6:05 pm    Post subject: AOA indicator Reply with quote
While the AOA is relatively immune to icing, and it's output is accurate
for your clean wings, it doesn't have any way to know the wings are iced
up or how to take into consideration the degradation in performance when
the wings have ice on them. Therefore, if you pay attention to it's
readings you could end up stalling.
That is what the original poster was referring to. Even though the AOA
is working perfectly, it is giving you false information.
Dick Tasker
The Kuffels wrote:
<kuffel(at)cyberport.net>
replaces the standard pitot sensor. It has temperature control so you
just leave it on all the time. Thus is it relatively immune to
icing. This means I will have one less distracter when I follow Bob's
(and others) great advice to get the heck out of wherever I am if ice
is encountered.
Tom Kuffel
Please Note:
PostPosted: Sat Feb 12, 2011 9:13 pm    Post subject: AOA indicator Reply with quote
Hi Dick,
<< That is what the original poster was referring to. Even though the AOA
is working perfectly, it is giving you false information. >>
And what I'm referring to is if I take avoidance action, as I should, the
instant ice is encountered I don't have to worry about my Dynon giving me
"false information". It will still tell me accurately if my angle of attack
is well above stall with clean wings. While I don't know what my stall
margin actually is at the moment I'm certainly better off than with no or
incorrect AOA information.
In other words, as compared to some other AOA systems the Dynon is giving me
true information. My job is to apply judgement to take actions which
prevent the stall margin at normal cruise AOA from narrowing to zero. And I
get whatever benefit/insurance, however minor, of a heated pitot.
Tom Kuffel
PostPosted: Sun Feb 13, 2011 7:08 am    Post subject: AOA indicator Reply with quote
At 08:01 PM 2/12/2011, you wrote:
<retasker(at)optonline.net>
AOA is working perfectly, it is giving you false information.
I think this is the 'nut' of what has
yanked some folk's chains. Heated AOA
or IAS will indeed continue to MEASURE and
display the rudimentary stimulus that
the sensor watches. IAS measures
the DIFFERENCE of two pressures that
is translated into a CALIBRATED IAS
reading (complete with sweet-spots
. . . or sweet-bands)
AOA can be a vane that actually weather-
cocks to align with relative wind -or-
the system can measure pressure differentials.
Both of those phenomenon are calculated upon
interpreted, CALIBRATED data are displayed
along with sweet-spots intended to be
a guide for operation of the airplane.
The concept often missed is that these
sweet-spots are DERIVED numbers confirmed
by repeated flight tests. In no case does
either IAS or AOA directly measure the
the conditions (shape) that set flying qualities
of particular wing under conditions that
exist right now.
So while the heated instrument is indeed
performing as advertised in spite of icing
elsewhere on the airplane, prior CALIBRATIONS
for the sweet-spot are no longer valid. It's
perfectly GOOD information. IAS is correct.
AOA is correct. But the rules of application
have changed in ways that are difficult to scale
without taking off our GA pilot's hat and
putting on the engineering test pilot's hat.
Here the debate becomes purely personal.
Do you understand what's necessary to re-
interpret this data before you attempt a
landing? If so, it's your choice. But if
not so sure, then what behaviors (plan-b)
are most likely to produce a happy outcome
while ignoring previous calibrations of
compromised sweet-spots.
Mark Sletten
PostPosted: Sun Feb 13, 2011 7:44 am    Post subject: Re: AOA indicator Reply with quote
kuffel(at)cyberport.net wrote:
It will still tell me accurately if my angle of attack is well above stall with clean wings. While I don't know what my stall margin actually is at the moment I'm certainly better off than with no or incorrect AOA information.
That depends on how you interpret and use the data it provides. If you are flying with an iced wing, the only data even the most accurate AOA indication provides is that the wing is not stalling at the current AOA.
An AOA indicator is only that; an indicator. It tells you the current angle of attack. Its only value lies in knowing a second crucial piece of data: at what AOA the wing will stall. If your wing is iced you no longer have the second crucial piece of data.
Given that you have not stalled, the AOA indicator is not providing data you don't already have, that you have, in fact, not stalled. How does an accurate AOA indication help in this scenario?
Mark Sletten
pwmac(at)sisna.com
PostPosted: Sun Feb 13, 2011 8:14 am    Post subject: AOA indicator Reply with quote
Bingo
Bob, Thanks for the summary
PaulW
exist right now.
raymondj(at)frontiernet.n
PostPosted: Sun Feb 13, 2011 8:45 am    Post subject: AOA indicator Reply with quote
***Disclaimer: I've never had an icing encounter in an airplane. The
following is pure speculation based on several icing encounters I have
had in cars.***
I think the value that a working AOA or AI has after an icing encounter
is to allow you to return to a known AOA or airspeed. The knowledge
that your airplane will fly at a particular AS/AOA even with the ice
load that has accumulated, has value if you deviate from the point while
distracted by other tasks. It allows you to return to a point where you
know the aircraft will fly. During any change in attitude it would give
a known AOA/AS value that can be adhered to to assure continued flight.
Clearly ANY deviation from that know AOA/AS carries additional risk.
I'm guessing that some of the intuitive clues that help seat of the
pants flying might be altered by an ice accumulation. The specific one
I'm thinking of is the sounds. I know this to be true in cars. I believe
this is another reason to take steps to avoid having to fly the aircraft
without an AOA/AS.
Raymond Julian
Kettle River, MN
Mark Sletten
http://forums.matronics.com/viewtopic.php?p=330881#330881
PostPosted: Tue Feb 15, 2011 4:33 pm    Post subject: AOA indicator Reply with quote
Aviation on http://www.oshkosh365.org
have to see what issue it was in. Do you remember what month?
Sorry, no. It was mentioned on another forum.
Had an EAA membership for 20+ years but gave it
up about 10 years ago. So if anyone could find
and capture the article, I'd sure appreciate it.
PostPosted: Wed Feb 16, 2011 6:44 am    Post subject: Re: AOA indicator Reply with quote
Bob,
I did a search of past EAA articles and found the following pertaining to AOA:
Better Way to Fly - May 1998
Carrier Pilots' Secret - July 1999
Test Pilot: Angle of Attack - April 2001
Test Pilot: Angle of attack and lift/drag - May 2001
Test Pilot: Angle of Attack - November 2003
Shop Talk: Angle of Attack Indicator - December 2008
I could not find anything in 2005 about AOA. The December 2008 article by Dave Barker might be the one that you are looking for. It describes how to build the AOA sensor using a hall effect transducer and LED bar graph display.
Here is a link to the December 2008 EAA article: http://www.oshkosh365.org/saarchive/eaa_articles/2008_12_21.pdf
Below are links to the author's website. Dave Barker's pdf gives more detailed construction details than the EAA magazine article.
http://www.barkeraircraft.com/files/AOA_rDisplay.pdf
http://www.barkeraircraft.com/AOA_kit.html
Although Dave Barker no longer sells AOA kits, he still has some circuit boards available. There is a link to his email address on his website.
Joe
Joe Gores
PostPosted: Wed Feb 16, 2011 9:36 am    Post subject: AOA indicator Reply with quote
At 09:44 AM 2/16/2011, you wrote:
Bob,
<snip> thanks to all who responded to my query about S.A.
articles. I now have several. It's interesting/useful to see
what kinds of things have been published for the OBAM aviation
community. I've added all your contributions to my library.
PostPosted: Wed Feb 16, 2011 2:29 pm    Post subject: AOA indicator Reply with quote
Are they online somewhere? Or am I looking in the wrong place?
Raymond Julian
Kettle River, MN
> <fran4sew(at)banyanol.com>
> Bob,
> to AOA:
Goto page 1, 2  Next
Page 1 of 2
