VOMs again. . .
pwmac(at)sisna.com
PostPosted: Tue Jan 25, 2011 8:16 am    Post subject: VOMs again. . . Reply with quote
Sure Lots of message for good meters. And the HF $4 unit is great for
checking voltages and continuity.
What about a low cost meter that can be used for low resistance
measurements? No need to go down to less than ~2 ohms. But a 20k
lower scale dosen't do much for my needs and I have to drag out my
ancient VTVM to see the resistance. I sure would be nice to have a
handy VOM that gets some low R values.
Any suggestions?
Like to measure sensors on my truck that are supposed to be 3 ohm.
and the truck is 1000 miles from the VTVM because I only carry the
cheepy VOM and leave the VTVM home. - Sigh.
PaulW
mdnanwelch7(at)hotmail.co
PostPosted: Tue Jan 25, 2011 9:01 am    Post subject: VOMs again. . . Reply with quote
Any suggestions?
PaulW
Paul,
  When this subject came up a couple of months ago, I had recommended
the Etek digital VOM, model #10709, sold at Walmart.  It has a good feel in
your hands, and several extra functions (built-in flashlight, temp probe, etc.)
that make it a GREAT model for the money.
  I had one I used in doing the electrics for my house I was building.  Someone
ruined it by spilling coffee in it.  I did like it, so I made it a point of going
back to Walmart and getting another one!
  For $21 you simply can't go wrong!
Mike Welch
handainc(at)madisoncounty
PostPosted: Tue Jan 25, 2011 9:23 am    Post subject: VOMs again. . . Reply with quote
The WalMart stores in our area no longer sell that model - what they've got in stock is just junk. Since my wasn't working, I took it back to get it replaced, and they no longer stock it. I'm trying to find another one now since I've got all the leads and everything.
M. Haught
On 1/25/2011 10:57 AM, Mike Welch wrote: [quote] >I sure would be nice to have a
> Any suggestions?
> PaulW
Paul,
Mike Welch
pwmac(at)sisna.com
PostPosted: Tue Jan 25, 2011 11:14 am    Post subject: VOMs again. . . Reply with quote
Mike what was it R scale? Max value?
PW
> Any suggestions?
> PaulW
Paul,
probe, etc.)
building. Someone
point of going
Mike Welch
PostPosted: Tue Jan 25, 2011 11:18 am    Post subject: VOMs again. . . Reply with quote
At 11:07 AM 1/25/2011, you wrote:
--> AeroElectric-List message posted by: paul wilson <pwmac(at)sisna.com>
Sure Lots of message for good meters. And the HF $4 unit is great for checking voltages and continuity.
What about a low cost meter that can be used for low resistance measurements? No need to go down to less than ~2 ohms. But a 20k lower scale dosen't do much for my needs and I have to drag out my ancient VTVM to see the resistance. I sure would be nice to have a handy VOM that gets some low R values.
Any suggestions?
Only my brother-in-law would get such a deal as I
have for you. See:
http://tinyurl.com/4l3tuj6
A few years back we were wrestling with some switch
and relay issues on fielded airplanes that required
accurate measurements below 1 ohm. As you've noted,
most multimeters don't have the resolution to tell
you much about low resistances. Further, the resistance
of the test leads become a significant portion of
the total resistance being measured.
I crafted a series of devices cited in the article
above. This paper was published to the HBC field
service community.
Setting up the adapter to generate a 0.1 amp
constant current means that resistance across
the 4-wire test connections has a voltage drop of
of 100 mV/ohm. So a reading of 1 volt indicates
a resistance value of 10 ohms. LM317 needs to
have about 2 volts of head-room so the 3 cell
instrument should not be depended on for
measurements above 20 ohms. The 4-cell
instrument can go up to 35 ohms. Depending
on resolution of your VOM, you can accurately
resolve very small resistance values. For
example, the HF $4 VOM on the 200 mV scale
displays 199.9 millivolts. The instrument
display offers you 1 milliom resolution at
2.0 ohms full scale.
Many small, low cost VOMs don't have 3/4"
spaced banana jacks. You can buy banana
plugs that mount on screws with a spacing
of your choice
[img]cid:.0[/img]
http://tinyurl.com/4d465gx
Alternatively, you can build the larger
adapter that stands alone and connects
to your multimeter of choice with appropriate
wiring.
Like to measure sensors on my truck that are supposed to be 3 ohm. and the truck is 1000 miles from the VTVM because I only carry the cheepy VOM and leave the VTVM home. - Sigh.
PaulW
Build one of these critters up. You'll
be glad you did. I made up several and
gave them to guys in the shops.
 Filesize:  22.67 KB
 Viewed:  4166 Time(s)
PostPosted: Tue Jan 25, 2011 11:42 am    Post subject: VOMs again. . . Reply with quote
Hi Paul,
20M, 2M, 200K, 20K, 2K & 200.    Marvin was right about them not being
at Walmart, it appears.  I did a Walmart online search, and they didn't come up.
I checked on eBay.  There are two different sellers.  One guy wants $40 + sh.
The other guy wants $32 total.  Walmart sold them at $20-$21, but they were
quite a deal at that, IMO.  Here's the cheaper guy's auction;
http://cgi.ebay.com/ebaymotors/E-Tek-10709-Professional-Digital-Multimeter-_W0QQcmdZViewItemQQhashZitem41563d5b42QQitemZ280619735874QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
> Date: Tue, 25 Jan 2011 11:08:51 -0800
[quote] To: aeroelectric-list(at)matronics.com
Subject: RE: AeroElectric-List: VOMs again. . .
PW
PostPosted: Tue Jan 25, 2011 2:50 pm    Post subject: VOMs again. . . Reply with quote
Any suggestions?
have for you. See:
service community.
of your choice
[img]cid:7.1.0.9.0.20110125164501.01d8a3a0(at)aeroelectric.com.1[/img]
wiring.
PaulW
 Filesize:  22.67 KB
 Viewed:  4161 Time(s)
pwmac(at)sisna.com
PostPosted: Tue Jan 25, 2011 3:17 pm    Post subject: VOMs again. . . Reply with quote
Bob, I remember this article well, which is why I asked if something is out there to buy. I seriously doubt a succesful build of your device considering my abilities.
Maybe you would consider a new product to sell us or even a kit?
Thanks, PaulW
Any suggestions?
have for you. See:
service community.
of your choice
[img]cid:7.1.0.9.0.20110125143417.01e81300(at)sisna.com.1[/img]
wiring.
PaulW
Bob . . . [b]
