collins04(at)cableone.net Guest
Posted: Sun Jan 23, 2011 6:55 pm Post subject: RV8 stick |
I am looking at putting the Tosten control stick in, and an interested the length of the base/stick that was left by others who have used this.
Thanks for the suggestions!
Paul Collins
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
jimboscr(at)yahoo.com.au Guest
Posted: Sun Jan 23, 2011 11:24 pm Post subject: RV8 stick |
Hi Paul
I am using the Tosten grip and there are a couple of options that I have been looking at. The first was a bend in the stick by a bloke in the U.S. However he no longer does the bending, but he published the
dimensions. Some didn't like these and some others came up with an alternative. (see the following web site) This guy found bending to be destructive and wasn't happy with the location of the bends so he worked out his own dimensions and cut and welded the the stick.
http://www.kit-plane-advice.com/front-control-stick.html
I can understand this because I tried to get my rear stick bent here and can't get anyone to bend it. According to the professional "benders" the pipe is an unusual size of molly and no one here will touch it without the exact dies because it will definitely buckle.
So instead of bending I decided to shorten the front stick so it fits under the panel. From the pivot to the top of the stick it is 18cm long. However I may shorten it a little more because the clearance is minimal
The rear stick is even shorter, but due to the sitting position this is not a problem for the rear passenger. It is 9 1/2cm from the bottom of the removable pipe to the top. However I have found that I still need to bend the rear stick with a radius of 2.5 cm to stop it hitting the front seat before full forward travel is reached. I think I will need to either cut and weld or heat and bend.
Have a look at the attachment, I have put a couple of photographs there. Hope this helps your decision.
Cheers
Jim
--- On Mon, 24/1/11, Paul Collins <collins04(at)cableone.net> wrote:
Subject: RV8 stick
To: rv8-list(at)matronics.com
Received: Monday, 24 January, 2011, 1:52 PM
Paul Collins | Quote: |
=nofollow target=_blank>http://www.matronics.com/Navigator?RV8-List
Rv_8_Sticks.doc |
112.5 KB |
448 Time(s) |
rlundin46(at)yahoo.com Guest
Posted: Mon Jan 24, 2011 7:17 am Post subject: RV8 stick |
Hi Jim,
Can you attach the dimensioned drawings to a post? I can't get them big or clear enough to use.
Rick
--- On Mon, 1/24/11, james scritchley <jimboscr(at)yahoo.com.au> wrote:
Subject: Re: RV8 stick
Date: Monday, January 24, 2011, 2:18 AM
Hi Paul
Cheers
Jim
Subject: RV8 stick
Paul Collins | Quote: | | =nofollow target=_blank>http://www.matronics.com/Navigator?RV8-Listet=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution |
Posted: Mon Jan 24, 2011 10:56 pm Post subject: RV8 stick |
Hi Rick
Here is a plan that might be better. (Please see attachment)
Cheers
Jim
--- On Tue, 25/1/11, Richard Lundin <rlundin46(at)yahoo.com> wrote:
Received: Tuesday, 25 January, 2011, 2:13 AM
Hi Jim,
Rick
Hi Paul
Cheers
Jim
Subject: RV8 stick
Paul Collins
stick_bend.doc |
49.5 KB |
448 Time(s) |
jimsherry49(at)gmail.com Guest
Posted: Tue Jan 25, 2011 8:12 am Post subject: RV8 stick |
Hey James,
This guy just bent a stick for my -8. Just a little nick of the powder coat but otherwise okay.
Jim
[img]images/cleardot.gif[/img]from[img]images/cleardot.gif[/img]Mike Cingari <mcingari(at)gmail.com (mcingari(at)gmail.com)> to[img]images/cleardot.gif[/img]Jim Sherry <jimsherry49(at)gmail.com (jimsherry49(at)gmail.com)>
date[img]images/cleardot.gif[/img]Sun, Dec 12, 2010 at 4:48 PM subject[img]images/cleardot.gif[/img]RV-8 stick bending mailed-by[img]images/cleardot.gif[/img]gmail.com signed-by[img]images/cleardot.gif[/img]gmail.com
hide details 12/12/10
Hi Jim,
I am bending sticks as time permits.
Send a new stick, full length and a check for $120 (includes return shipping)
or paypal $130 to me at:
Mike Cingari
2433 Laguna Road
Santa Rosa, CA 95401
2 weeks turnaround time
I will send you an email when I ship it back to you.
Mike
On Mon, Jan 24, 2011 at 11:50 PM, james scritchley <jimboscr(at)yahoo.com.au (jimboscr(at)yahoo.com.au)> wrote:
[quote] Hi Rick
Cheers
Jim
--- On Tue, 25/1/11, Richard Lundin <rlundin46(at)yahoo.com (rlundin46(at)yahoo.com)> wrote:
From: Richard Lundin <rlundin46(at)yahoo.com (rlundin46(at)yahoo.com)>
To: rv8-list(at)matronics.com (rv8-list(at)matronics.com)
Hi Jim,
Rick
--- On Mon, 1/24/11, james scritchley <jimboscr(at)yahoo.com.au (jimboscr(at)yahoo.com.au)> wrote:
From: james scritchley <jimboscr(at)yahoo.com.au (jimboscr(at)yahoo.com.au)>
Hi Paul
Cheers
Jim
--- On Mon, 24/1/11, Paul Collins <collins04(at)cableone.net (collins04(at)cableone.net)> wrote:
Paul Collins |
