Dynon Pitot
Tim Juhl
PostPosted: Fri Jan 21, 2011 11:39 am    Post subject: Dynon Pitot Reply with quote
I have a question for those of you who installed the Dynon Pitot (unheated). How far back from the leading edge did you install it? Also, how far out from the wing root?
Thanks!
Tim
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
Ron Lendon
PostPosted: Fri Jan 21, 2011 7:06 pm    Post subject: Re: Dynon Pitot Reply with quote
Tim,
I remember talking to the folks at Dynon about keeping it away from the boundary layer, so it sticks out a ways from the wing surface but it is in the same position on the wing as the zenith design calls for.
Here is a link to the log entry:
http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=27206&row=802
The 4" length on that entry refers to the length of the pitot tube holder I fabbed up.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
dgardea(at)gmail.com
PostPosted: Sat Jan 22, 2011 1:33 pm    Post subject: Re: Dynon Pitot Reply with quote
Tim,
I installed my Dynon pitot immediately aft of the wing spar just to the outside of rear rib number 5 on the left wing. As Ron mentioned, I believe this is the location recommended by Zenith. A couple pics of the install location are below. Regards //Dave
 Filesize:  43.51 KB
 Viewed:  7291 Time(s)
 Filesize:  47.56 KB
 Viewed:  7288 Time(s)
Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html
Tim Juhl
PostPosted: Sat Jan 22, 2011 5:16 pm    Post subject: Re: Dynon Pitot Reply with quote
Thanks guys, that's just what I needed to know. You both did a nice job of fabricating a mount for the pitot.
Dave, would you happen to remember the principal dimensions (or AC Spruce part number) of the streamlined tubing you used? Looks like 4130 to me.
Tim
______________
CFII
Champ L16A flying
PostPosted: Sat Jan 22, 2011 6:31 pm    Post subject: Re: Dynon Pitot Reply with quote
Tim, glad to be of help .. but I did not fabricate my pitot mast like Ron did (nice job Ron!) I purchased one from SafeAir1 at http://www.safeair1.com/Pmast_1.htm
Dave Gardea
