		dongirod
				 Posted: Sat Jan 22, 2011 12:10 pm    Post subject: IFALPA's take on the A380 Issue |
				I got this from a friend, not sure of any of the info, but thought it might  be interesting to some on the list.
  Don
 Subject:  IFALPA's take on the A380 Issue
 Here is a review written by IFALPA after  they looked at the stuff that's
 so far come out of the QF A380  incident.
 As far as "Fly-by-Wire" and redundancy go it really doesn't  matter how
 many wires you have going to an item if they are all routed thru  the same
 area! Airbus and Rolls have some serious redesign work ahead of  them.
 It also poses some really troubling questions that have the  potential to
 shake up the entire system from certification authorities  through
 regulators, through airline training departments. It also blows away  the Airbus
 mantra that their jets are so smart that you can stuff an  inexperienced crew
 from Nigeria in the cockpit, and as long as they can keep  the wings level
 until the A/P is turned on, and then slavishly follow what  the totally
 brilliant and foolproof ECAM system tells them is wrong and what  to do in what
 order, all will be well....[Amen to this  comment]
 Qantas A380 Uncontained Engine Failure
 Background
 On  Thursday 4th November a Qantas A380, registration VH-OQA suffered an
 uncontained intermediate pressure turbine wheel failure of the No 2 engine  at
 about 6000 feet on departure from Singapore. The  aircraft returned for
 landing safely but the crew had around 54 ECAM  messages to deal with and a
 substantial loss of systems on board the  aircraft. It took about an hour to
 deal with all those messages.
 There  were, and are, a number of Airworthiness Directives out on the
 engine for  inspection; some are new and some are from previous problems. The
 issue  appears to be oil leaking from the bearing into the Intermediate
 Pressure/High Pressure turbine wheel structural area causing an intense  local
 fire that compromised the structure of the turbines.
 The aircraft  was substantially damaged but landed safely.
 Systems Loss and Damage  Synopsis:
 Investigations are ongoing and there is much speculation in the  media and
 around the industry but the major issue for the ADO committee to consider
 is the secondary damage and systems loss that the aircraft  suffered.
 A brief description follows of the known, and public,  issues:
 • The No 2 engine suffered an uncontained failure of IP rotor which
 separated from the engine and penetrated the wing and body fairing of the
 aircraft.
 • The rotor penetrated the forward wing spar and exited the  upper surface
 of the wing.
 • The main electrical loom in forward section  of wing was cut causing loss
 of engine control (thrust ok) on No 1 and no  ability to shut it down with
 Fire Handle.
 • The power drive unit for the  leading edge devices was severed in the
 same location,
 • The crew were  unable to discharge any fire bottles for engine No 1 and
 No 2.
 • All  electrical hydraulic pumps that side were lost.
 • A piece of rotor penetrated  the body fairing and severed a wiring loom
 in that location.
 • Another  piece of the rotor damaged the aft fuel transfer gallery and
 caused leaks in  the left mid and inner fuel feed tanks – one of which was
 substantial. This  led to a lateral imbalance problem.
 • The crew were unable to jettison or  transfer fuel forward. This led to
 indications of an aft cg problem.
 •  Emergency Outer tank transfer only resulted in the right hand outer
 tank  transferring – the left hand tank failed to transfer - this helped the
 lateral imbalance.
 • There was damage to the fairing housing the RAT,  flaps and flap track
 fairings.
 • Total loss of the Green hydraulic  system,
 • ECAM indicated loss of both electrical hydraulic pumps on No 4  engine
 (Yellow system).
 • Landing Gear required gravity extension.
 •  No anti skid on wing gear hence only emergency brakes; body gear braking
 normal
 • Engines 1 and 4 indicating ‘degraded mode’ – which means no N-1
 rating limit. Requires all engines to be switched to ‘Alternate’ mode with a  4%
 maximum thrust loss.
 • AC bus 1&2 failed.
 • No 2 engine  electrical generator failed as a result of the engine
 failure
 • The APU  was started but the crew were unable to connect the APU bleed
 air or the  generators to the bus system.
 • No 1 air conditioning pack failed.
 •  Autothrust was not available.
 • The satellite phone system would not  work.
 ECAM Management:
 When the failure occurred something like 54  ECAM messages appeared on the
 screen. These set off the Master Warning and  Master Caution many times; to
 the point of distraction of the crew. The  First Office started the stop
 watch when the first master warning went off  and from there it took the crew
 50 minutes or so to clear the messages down  to the Status page. Management
 of the ECAM was an issue with the ECAM  calling for a transfer of fuel into
 obviously leaking tanks to cure a fuel  imbalance. Forward transfer was also
 not possible which generated an ECAM  for an aft CG problem that could not
 be rectified. The ECAM also called for  a Fuel Quantity Management System
 reset which, when carried out, regenerated  all the error messages. For non -
 Airbus pilots the Status page is normally  where ECAM actions are stopped
 and Normal checklists are used, Operational  Engineering Bulletins are
 considered, resets to recover systems are  attempted and any pilot initiated
 abnormal checklists are  used.
 Preparation for Landing:
 It took the crew some time to prepare  the aircraft for landing. The
 Landing Performance Application of the  Electronic Flight Bag did not appear to
 generate correct information which  resulted in the crew carefully entering
 eight landing alerts and  recalculating the landing performance. The end
 result was that the predicted  approach speed was around 167 knots and landing
 distance 3850 meters on the  4000 meter runway. Aircraft handling checks were
 carried out in both the  clean and landing configuration with adequate
 control response and margin  demonstrated. This was despite a lateral imbalance
 of around 10 tonnes and a  message indicating an aft cg issue.
 Landing:
 Given the loss of  hydraulics the aircraft was in a degraded mode with only
 one aileron working  on one wing and two on the other with limited spoiler
 capability. Autothrust  was not available and manual thrust was used with
 the engines in the  alternate mode. Also no leading edge slats were available
 and the gear had  to be extended by gravity. Despite this the approach to
 landing went as  planned expect for a “Speed, Speed” call by the warning
 system. The reason  for this is unknown but it was cancelled by thrust
 application. Touchdown  was reported as very smooth and the aircraft speed was
 brought under control  with about 600 metres to run. The aircraft was allowed to
 roll near to the  end runway to position it near the fire trucks. When the
 aircraft finally  stopped the brake temperatures quickly rose to 900 degrees
 and a few tires  deflated.
 Post landing:
 When the aircraft stopped the crew attempted  to shut down the No 1 engine
 but were unable to do so with either the fuel  switch or the engine fire
 handle. Fuel was leaking from the left hand wing  and pooling around the hot
 brakes. The fire crew were organized to smother  the fuel with foam and the
 decision was made not to evacuate the aircraft  given the running engine, the
 pooling fuel, the potential for serious  injuries and the presence of the
 fire crews who were attempting to stop the  No 1 engine by running a stream
 of water down the intake. When the engines  were finally shut down the
 aircraft went “dark” due to the inability to  connect the APU generators to the
 bus  system..
 Issues  for Consideration:
 This event raises a number of issues for consideration by  the ADO
 committee, Rolls Royce, Airbus and the industry in general. There is no  doubt that
 the aircraft was badly damaged by the IP rotor burst. In fact, it  is
 fortunate that this incident did not end up like the DC-10 in Sioux City Iowa [Or
 American at O'Hare]. >From an  aircraft damage tolerance point of view it
 is a tribute to the A380, modern  design criteria and the redundancy
 available later generation aircraft.  Certainly the fact that the very experienced
 crew consisted of three  Captains, a highly experienced First Officer and a
 very experienced  ex-military Second Officer enabled tasks to be shared
 including flying the  aircraft, dealing with the huge amount of ECAM messages,
 communication and  performance calculations. The First Officer managed the
 ECAM and, at times,  decisions were made to ignore or not do certain ECAM
 procedures that did not  seem logical such as transferring fuel into leaking
 tanks. It is worth  noting that there were three captains present because the
 Pilot-in-Command  was being Annual Route checked by a trainee Check Captain
 who was being  supervised by another Check Captain.
 Without going into significant  explanatory detail the following poses the
 following questions for  consideration:
 Design:
 • Given this and a number of other uncontained  turbine rotor failures
 should transport category aircraft be designed to  withstand an engine rotor
 burst? Or is this impracticable?
 • Conversely,  is it possible to design for rotor containment or mitigation
 by the engine  in the event of a burst?
 • Can engine monitoring systems be developed to warn  of an impending
 catastrophic failure? (e.g. a combination of vibration/  rapid core temperature
 changes/parameters out of limits)
 • Rolls Royce  have mentioned engine self protection systems to shut down
 engines in order  to minimise the effect of a rotor burst. How would that be
 implemented?  Would warning be given? How critical would an unexpected
 shutdown be? What  would the false warning rate be?
 • Why did some apparently unrelated systems  fail in this incident? (e.g.
 Yellow system hydraulic pumps on engine No 4)  Is there a common data
 management source that is failing under overload or  was it damaged in the
 incident?
 • Are modern aircraft so complex that  failures tend to be multi-modal and
 thus confusing to the crew?
 • If an  electrical loom to an engine is cut the fail safe mode is to run
 on. What if  the engine runs on at high thrust?
 • If there had been an engine fire the  crew would not have been able to
 use the fire bottles because of the cut  loom. Is this system truly redundant
 and effective?
 • Given the loss of  systems in the wing should the main electrical loom be
 relocated or systems  separated to a secondary loom to improve redundancy?
 • The crew were unable  to transfer fuel and there was a substantial fuel
 leak from the left wing.  What if these failures had occurred in mid ocean?
 Operational  Philosophy:
 • There were many ECAM messages occurring in the initial failure.  The
 constant alerts were distracting and the need to cancel them detracted  from the
 procedures.. Should a semi-permanent cancel mode be available? The  crew
 know they have a problem.
 • Did the ECAM correctly prioritise the  alerts? Probably not known at this
 stage but certainly a few ECAM messages  appeared incorrect in the
 circumstances (e.g. Fuel transfer into leaking  tanks for imbalance).
 • Is the modern trend to complete all ECAM/EICAS  actions too time
 consuming and distracting to the crew to the detriment of  prioritising the flying
 of the aircraft and the landing?
 • Should there  be an abbreviated ECAM/EICAS procedure that achieves a safe
 mode for landing  in the event of an emergency return?
 • Is modern aircraft operational  philosophy too automation and functional
 system reliant?
 Training and  Experience:
 • This was highly experienced crew. Should this type of failure  be
 considered when pairing a 240 hour MPL or cadet pilot graduate with a  relatively
 new Captain? Or is the probability too remote and thus  acceptable?
 • The crew reported in this case that crew resource management  was very
 effective and that there was zero cockpit gradient. The crew were  adaptive in
 dealing with the multiple and complicated ECAM messages. Should  crew
 resource training be modified to include crew recognition of the  extreme nature
 of the emergency and thus to not slavishly follow checklist  procedures to
 the detriment of a timely return to landing?
 • Given the  move to evidence based training should training scenarios
 include multi-mode  failures so that crews can cope with unusual events or are
 they so rare as  not to warrant this type of training?
 Conclusion:
 This incident could  easily have been an accident; many of the systems
 failures the crew had to  deal with would be classed as an emergency on their
 own (e.g. uncontained  engine failure, loss of hydraulics, multiple bus
 failures and leading edge  failure) let alone in combination. The fact that it
 wasn’t an accident is  probably testament to the redundancy built into the
 A380 design and it is  certainly due to the training and competency of a very
 experienced crew  operating in a team environment. There are many positive
 lessons to be  learned from this event.
 Captain Richard Woodward
 Executive Vice  President Technical  Standards
 IFALPA
  |  | - The Matronics Commander-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Commander-List |
		wjrhamilton(at)optusnet.c Guest
				 Posted: Sat Jan 22, 2011 3:58 pm    Post subject: IFALPA's take on the A380 Issue |
  Don
  same
  Airbus
  crew
  level
  in what
  Background
  engine at
  a
  to
  The
  local
  and
  consider
  the
  aircraft.
  surface
  of the wing.
  loss
  with
  Fire Handle.
  same location,
  and
  No 2.
  loom
  in that location.
  was
  to
  helped the
  lateral imbalance.
  track
  fairings.
  engine
  (Yellow system).
  braking
  normal
  N-1
  mode with a 4%
  failure
  bleed
  ECAM Management:
  the
  to
  crew
  Management
  into
  also
  not
  non -
  initiated
  appear to
  entering
  landing
  were
  imbalance
  Landing:
  only
  spoiler
  available
  landing went as planned expect for a “Speed, Speed†call by the
  warning
  speed was
  allowed to
  the
  degrees
  Post landing:
  engine
  hot
  the
  the
  stream
  aircraft went “dark†due to the inability to connect the APU
  generators to the
  bus system..
  doubt that
  Iowa [Or
  experienced
  a
  messages,
  the
  leaking
  the
  Captain
  the
  Design:
  rotor
  mitigation
  temperature
  down
  be
  (e.g.
  the
  incident?
  and
  run
  to
  redundant
  and effective?
  loom be
  redundancy?
  fuel
  ocean?
  from the
  this
  the flying
  safe
  functional
  system reliant?
  relatively
  very
  adaptive in
  nature
  to
  or are
  Conclusion:
  their
  that it
  the
  very
  positive
  IFALPA
 Folks,
 The IFALPA VP who wrote this is also a QANTAS captain.
 The details are correct, if abbreviated, the complete analysis of the interacting multiple failures are not yet complete, but the limitations of the "computer knows best" Airbus approach is showing its limitations here.
 As another QF mate of mine said of Airbus: "Its all about democracy, and the computers have 51% of the vote".
 For those of you familiar with the B777, in a "apples and apples" event in the 777, the likely cockpit complications would be considerably less.
 The normal crew for the A380 is still two pilots, with an event such as this, life for two pilots would have been very busy.
 One comment, about cockpit authority gradient, a flat (indeed almost non-existent) gradient is almost achieved in QANTAS, it certainly helps.
 I know all the crew involved, except the S/O, two are ex-students of mine ( the supervising Senior Check and the operating Captain) and it is clear even to the detractors of the "real" QANTAS, that the crew and years of training showed.
 This is not stopping the senior management (none are pilots or engineers) dumbing down the flight operation, indeed it seems much of the operation is gradually being moved to Singapore, initially the Jetstar division, to be operated by short term contract pilots, with training being done by outside contractors.
 Once again, accountants can tell you the cost of everything, but the value of nothing.
 Bill Hamilton
 QF Check and Training Captain, retired.
		deneals(at)deneals.com Guest
				 Posted: Sat Jan 22, 2011 5:34 pm    Post subject: IFALPA's take on the A380 Issue |
				Here are comments (in bold) I received after I forwarded that report to a "mate" of mine that is an Airbus capt for UPS (also ex- Central Air):
  "• Is the modern trend to complete all ECAM/EICAS actions too time
  the flying of the aircraft and the landing? *YES*
  *I would just ignore the ecam, Land asap and make sure the gear is down before touchdown.
  *I've found many scenarios in Sim training where the ECAM becomes a
  burden. When you're done with the ECAM items, you still have to
  supplement it with the paper checklist and figure out the proper point
  to enter the checklist. We have 6 known anomaly's on our A300's that we
  are told to ignore. I would rather use the Paper checklist and forget
  about ECAM.
  On 1/22/11 5:55 PM, "William J Hamilton" <wjrhamilton(at)optusnet.com.au> wrote:
  > Folks,
  > showed.
  > contractors.
  > nothing.
  > Regards,
  > Bill Hamilton
				 Posted: Sat Jan 22, 2011 6:03 pm    Post subject: IFALPA's take on the A380 Issue |
				Here are comments I received after I forwarded that report to a "mate" of mine that recently retired as a manager in Boeing’s (nee McDonnell Douglas’) Phantom Works:
  ------ Forwarded Message
  Great report. Really interesting – fascinating. Here are a few of my thoughts:
  - You can contain blade failures, but not rotor failures. I have first hand experience with two rotor failures – F100 engine #169 which failed on the test stand at St. Louis, and an F404 engine in F-18 TF2 that failed in flight and took out the other engine, causing loss of the aircraft.  The pilots, Garry Post and ???, both survived. Rotors always fail in thirds, and the energy of the failed components is so incredible that the weight associated with containment is prohibitive.
 - These guys were damn lucky in addition to being highly skilled. A lesser skilled crew probably would not have brought the aircraft back. It was incredibly fortunate that there were three Captains onboard – what are the odds of that?
 - Not to pick on Airbus, but I don’t understand how taking out one wire bundle could cause the loss of function. The spec as I remember is that redundant wire bundles have to be routed a minimum of 18 inches apart.
  Thanks for sharing!
  ------ End of Forwarded Message
		nico(at)cybersuperstore.c Guest
				 Posted: Sat Jan 22, 2011 8:00 pm    Post subject: IFALPA's take on the A380 Issue |
				Hi Don,
  Thanks for forwarding. Fascinating reading.
  Nico
    From: owner-commander-list-server(at)matronics.com  [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of  dongirod
 Sent: Saturday, January 22, 2011 12:08 PM
 To:  Commander-List Digest Server
  Don
 Background
 aircraft.
 of the wing.
 Fire Handle.
 same location,
 No 2.
 in that location.
 lateral imbalance.
 fairings.
 (Yellow system).
 normal
 failure
 ECAM Management:
 Landing:
 Post landing:
 bus  system..
 Design:
 incident?
 and effective?
 system reliant?
 Conclusion:
 IFALPA
 href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
